Results 1 to 19 of 19
Thread: G.Skill 800 HZ Getting worse and worse?
    Jan 2005
    Las Vegas, Nevada
    Just as the title says, from what I've seen including my experiences, newer sets of G.Skill 800 HZ are clocking worse in general....I havent seen anyone a brand new batch of HZ clocking over about 1060, for example, mine is BARELY stable @ 1068, 5-7-7-20 , and 2.4v and a 120mm fan about an inch off of em keeping them ice cold.
    1. Intel 2500k @ 4.4 / ASUS P8P67 Deluxe / G.Skill 1600 2x4GB / eVGA GTX570 / Hitachi 2x1TB RAID 0
    2. Intel Q9400 @ 3.2 / ASUS Maximus II Formula / G.Skill 1066 2x2GB / eVGA GTX460 SE @ 750/1820 / Hitachi 2x160GB RAID 0
    3. Intel Q6600 @ 3.0 / ASUS P5K-E / G.Skill 1066 2x2GB / Diamond HD4850 / Hitachi 4x320GB RAID 0
    4. Intel E8200 @ 3.2 / ASUS P5Q Deluxe / OCZ 800 Platinum 2x1GB / eVGA GTX260 SC @ 648/2180
    5. Intel E8200 @ 3.2 / DFI P35-T2RL / G.Skill 800 HZ 2x1GB / eVGA 8800GT @ 675/1950
    6. AMD X4 635 @ 2.9 / MSI 785GT-E63 / G.Skill 800 HZ 2x1GB / ATI HD4200
    7. Intel i3 @ 2.13 / Intel PM55 / Samsung 1066 2x2GB / Intel HD Graphics
    8. Intel 2.8E @ 2.8 / ASUS P4C800 Deluxe / HardCoreCooling 2x512mb 4000 / ATI X850XT
    9. Intel P3 800mhz / Intel i815 / Crucial 1x256mb / ATI 9700 Pro
    May 2007
    Athens - Hellas
    probably yes..older batches are more stable and better o/ckers i guess.
    i have my HZ (bought them few months from first coming to stores) at 1080mhz @ 5-4-4-5 @ 2.3V without any active cooling.
    [SIGPIC][/SIGPIC]
    Jan 2005
    daytona beach florida
    i just sold off my good clocking hz's....had those since last year...sry to hear this.
    Q6600 L723A (400 x9)
    Evga 780i P02
    G.skill 8 GB
    Evga GTX 280
    Raptor X (3) 150's Raid 0
    Targen BZ 1100w
    Thermalright Ultra Extreme 120
    Vista Ultimate x64
    Xclio
    Aug 2006
    I bought mine also few months ago,
    It runs like crazy
    4 4 4 12@600 2.5v
    cpu z validation : http://valid.x86-secret.com/show_oc.php?id=229887
    4 4 4 12@550 2.2v
    cpu z validation : http://valid.x86-secret.com/show_oc.php?id=229860
    Xtreme Guru adamsleath's Avatar
    Nov 2006
    Brisbane, Australia
    mm bad news about later batches if this is typical
    have tested mine at 1125 5-5-5-15 @ 2.1v
    bought 19th June '07
    i7 3610QM 1.2-3.2GHz
    Aug 2006
    Quote Originally Posted by adamsleath View Post
    may be your is not D9 chip, I heard that there is no more D9 chip used for later batches,
    Nov 2006
    Brisbane, Australia
    heh im not worried about my ram im happy with mine my sticks perform better than a pair of 9136's i sold & the hz's were less than half the price.
    Jan 2005
    Las Vegas, Nevada
    heh well both of my sets were D9, but still clocked badly, tried them on 2 different motherboard to ensure it wasnt a problem on my end, also the quality of the heat spreaders is sad, if I kept them without a fan even on stock voltage, they would probably burn out in 1 second, it was DEATHLY hot, I would get a serious burn if I kept my finger on it for more than a few seconds
    May 2007
    Athens - Hellas
    with the cpu 3700mhz and the HZs at 1157mhz with 5-5-5-5 / 4:5 do you think this result is normal???
    the result is with buffering enabled.
Name:	sandra buff..jpeg
    [SIGPIC][/SIGPIC]
    Nov 2006
    Brisbane, Australia
    hehe never seen anything above 8600 sandra with mine at 1187MHz @ 3.8GHz [475x8] how do you enable buffering?
    May 2007
    Athens - Hellas
    it`s the default options configuration....
    i guess this result isn`t real enough...
    i rerun it with some progs running at the background and i got 10880...
    [SIGPIC][/SIGPIC]
    Nov 2006
    Brisbane, Australia
    ill never see a figure that high with what i have; i wunda y such a large difference. mine sux compared with yours. everest gives me higher readings... i bet if you run everest read test yours will be very high...
    anyway i still think 1125 is good for 800 ram at 2.1v
    May 2007
    Athens - Hellas
    What version of sandra are you using?
    i have the Lite XI.
    maybe it has a bug or sth..
    [SIGPIC][/SIGPIC]
    Nov 2006
    Brisbane, Australia
    yeah we have the same prog and version...
    whats sth?
    May 2007
    Athens - Hellas
    sth = something..
    [SIGPIC][/SIGPIC]
    Nov 2006
    Brisbane, Australia
    if the prog is correct however that means my ram is bandwidth limited by something...i s'pose it's just the hardware combo.
    Aug 2006
    here is mine 8260mb/s
  18. #18
    Nov 2006
    Cruz Alta - CBA - Argentina
    Here mine HZ..
    DDR2 1164 - 5-5-5-15-3-35-3-3-3 @ 2.2vdimm
    DDR2 1000 4-4-4-12-3-35-3-3-3 @ 2.0vdimm
    i bought this kit two days ago. But i don't kwon when this kit has been shipping to Argentina
    iMac 24''
    BNDMOD @
    Cruz Alta (Cba.) Argentina
  19. #19
    G.Skill USA Tech
    Sep 2005
    i gotta said...... look at the DDR1 micron..... and their DDR2....just like that...good overclock... but failing rate is about 3 times more than cheap cheap PSC chips
    Feel free to contact ustech@gskillusa.com or use our G.Skill Q&A Sub-Forum, if having any questions about G.Skill products
    Check out our items on NewEgg
