Really sorry for any inconvenience caused yesterday because of the link broken.![]()
(1) The Package
(2) The heatpipe and PWM Heatsink
(3) The back panel
(4) A look with a large heatsink VGA card
(5) BIOS
using AMI,
Jumperfree
Strap settings: 200, 266, 333, AUTO
Vcore Settings: 1.1V~1.7V, AUTO
CPU PLL Voltage: 1.5~2.2V, AUTO
FSB Termination Voltage: 1.2~1.5V, AUTO
Vdimm: 1.8V~2.55V, AUTO
NB Voltage: Auto, 1.25V - 1.95V
CPU Voltage Reference:
NB Voltage Reference:
CPU Voltage Damper: ENABLE can reduce the Vdroop
DRam Command Rate:
Transcation Booster: 0, 1, Level 1 is faster
DRam Static Read Control: I Disable it when clocking higher FSB
Hardware Monitioring: not enough information as ROG series
(6) Test with a E6600
Set Up
CPU: Intel E6600 L628B
MB: Asus P5K Premium
RAM: Team Xtreem DDR667 C3 1G X 2
Display Card: Nvidia 8800GTS 640M
WaterCooling:
Laing D5 Pump
BlackIce GTX Extreme 240
Dtek FuZion
Thermal Interface: LiquidPro
VDroop test:
CPU Voltage Damper Enable
BIOS VCORE = 1.3875V
Window Idle = 1.3600V
Full load = 1.3600V
Test on 450FSB X 8: 3600MHz, RAM@ 1125MHz, CL4-4-4-5
Except Vcore, VDimm, other voltages are the lowest in the BIOS
Transcation Booster: Disable
Ortho 15mins.
Superpi 1M: 14.109s
Superpi 32M: 13mins.36.703s
Sandra Bandwidth:
Int. Buffered: 8258MB/s
Float Buffered: 8286MB/s
Transcation Booster: Enable, Level 1
Superpi 1M: 14.078s
Superpi 32M: 13mins.26.610s
Sandra Bandwidth:
Int. Buffered: 8530MB/s
Float Buffered: 8568MB/s
We can see the performance is boosted.
1.52V, 4G (445 X 9), ram: 1112.6MHz CL4-4-4-5
Superpi 1M: 12.766s
Superpi 32M: 12mins.29.5s
4140MHz, superpi 1M passed: 12.422s
500FSB:
NB strap: Auto
5000FSB X 7 = 3500MHz, RAM @ 1000MHz
Transcation Booster: Enable Level 1, please also take a look of the Performance Level it changed by the MB.
Superpi 1M: 14.515s
Superpi 32M: 13mins.53.884s
Sandra Bandwidth:
Int. Buffered: 8471MB/s
Float Buffered: 8496MB/s
(7) Temperature of MB
Location of MB temp. sensor (PC Probe II)
http://support.asus.com.tw/faq/faq_r...Language=zh-tw
Location of T1
Location of T2
Location of T3
I missed the photo, it is at PWM right in front of the back panel![]()
Full load Test:
Naked case, some air flow to T1 due to the PSU fan right beside the T1 location
T1: 34deg. C (PWM with a separate heatsink)
T2: 52deg. C(NB)
T3: 46deg. C (PWM with Heatpipe)
Room Temp: 25deg. C
Asus PC Probe II , MB temp: 37deg. C
(8) Overclocking of RAM:
@266Strap
2.25V @ DDR1200 CL5-5-5-12
@266Strap
2.50V @ DDR 1250 CL5-5-5-12
Q6600 G0 Test
1.36V @ 3600MHz, dual ortho Large FFT 30mins passed
1.58V,@ 4GHz Large FFT 24mins dual ortho passed
1.62V,@ 4GHz Small FFT 30mins dual orthos passed
500FSB X 7 Test: not easy to push to 500FSB for my Q6600
Changed to a lower temperature condition and test the clock:
WaterCooling + air conditioner direct blowing
Laing D5 Pump
Dtek FuZion
4320MHz passed Superpi 1M:
4367 CPUZ Validation:
