XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme Mods > Xtreme Motherboard Vmods
Reply
Old 08-11-2007, 06:38 AM   #1
symphy
symphy's Avatar
Send a message via ICQ to symphy Send a message via MSN to symphy
680i (eVGA, XFX, BFG...) A1 / D00 Rev. VCORE AND VDROP DONE!
Hello there,
I didn't find those mods on the net, so... i figured them out together with a friend.
Tested by me.
Vcore Readout is at every solid state capacitor around the CPU socket (I took the + contact).
It was not too difficult, but PLEASE community, PLEASE SHARE what you have! A lot of easy mods are missing here even i know that they are done!
symphy is offline   Reply With Quote
Old 08-15-2007, 02:07 PM   #2
pepinorang
pepinorang's Avatar
Thanks to share it, it was really needed
Bye
p€p|n0r@ng
__________________
***The Overclocking Knight*** ***Overclocking-Masters Team***
WR Q64 http://valid.x86-secret.com/show_oc.php?id=248613
WR QX6850 4 cores http://valid.x86-secret.com/show_oc.php?id=249000
WR X3070 http://valid.x86-secret.com/show_oc.php?id=243982
pepinorang is offline   Reply With Quote
Old 08-17-2007, 11:07 AM   #3
pumbertot
100kohms for vdroop, you could prob get 80kohms with a good B pencil so should work no?
__________________
pumbertot is offline   Reply With Quote
Old 08-17-2007, 11:09 AM   #4
Cpt.Planet
Simon says EnJoYs a nub
Cpt.Planet's Avatar
Send a message via AIM to Cpt.Planet Send a message via MSN to Cpt.Planet
Vcore mod works. I didnt get a chance to test the vdroop. Thanks
__________________
Originally Posted by 3oh6
damn you guys...am i in a three way and didn't know it again
Follow TechREACTION on Twitter
Cpt.Planet is online now   Reply With Quote
Old 08-17-2007, 05:27 PM   #5
nugzo
Ultra Durable
nugzo's Avatar
Send a message via MSN to nugzo
Damn Vdrop and vdroop are now gone with #2 pencil. Thank you OP very much! 1.50 set in bios, 1.50 in windows and 1.51 under full load small fft!
__________________
Under Construction. EX58a-UD7 in route. Currently Running:
EVGA X58 Classified 759 (3-way x16 SLI +physX)
Intel Core i7-950 Bloomfield @ 4.2Ghz (24x175)
G.SKILL Perfect Storm 12GB (6 x 2GB) 1745 8-8-8-21
Cooler Master Storm Sniper
Thermaltake 1000w PSU
2-128GB gskill Titan SSD RAID 0
2-1TB Seagete 32mb RAID 0
1-1TB Western Digital
1- Plextor PX-B320SA Blue Ray
1- Plextor PX-880SA 24x DVD/RW
2- EVGA Nvidia GTX-295 Quad SLI
TRUE w/2-SCYTHE S-FLEX™ "SFF21G" 120mm Fans
Acer 27" B273HU LCD / ASUS 24" LCDe
nugzo is offline   Reply With Quote
Old 08-17-2007, 05:28 PM   #6
nugzo
Ultra Durable
nugzo's Avatar
Works great with #2 pencil!!
__________________
Old 08-17-2007, 07:51 PM   #7
nugzo
Ultra Durable
nugzo's Avatar
OP you should start a thread in intel section with this same topic... TONS of people need this info. If others were like me, they don't even know this forum section exists. I found it by accident. Thanks again for the valuable info!
__________________
Old 08-18-2007, 12:17 AM   #8
uclajd
uclajd's Avatar
Can someone elaborate where you draw the mod? I've used a 2B on a video card before. Where do you draw the lines?
__________________
<----- REST IN PEACE, KIT. 1993-2007.
uclajd is offline   Reply With Quote
Old 08-18-2007, 01:19 AM   #9
nugzo
Ultra Durable
nugzo's Avatar
picture in first post shade between the 2 red x's
__________________
Old 08-18-2007, 01:21 AM   #10
evoic
evoic's Avatar
Unless I'm understanding incorrectly, you can use the blue to blue in a straight line of shading or the red to red, either should work the same.
Try 3 passes pressing light-to-medium and then check your Windows voltage vs. BIOS setting and also under load.
If still drooping, add 1 pass and check again.
Repeat as necessary.
evoic is offline   Reply With Quote
Old 08-19-2007, 07:14 AM   #11
dinos22
...you two characters
dinos22's Avatar
thanks heaps the mod works great
Q6600 3.5GHz@1.3815v set in bios >>>> 1.368v IDLE/LOAD (previously 1.344v IDLE > 1.294v load LOL
__________________
Team.AU
Got tube?
Originally Posted by Gautam View Post
In the old days, LN2 benching was "cheating". Then LOD was "cheating". And so on and so forth...
dinos22 is offline   Reply With Quote
Old 08-19-2007, 09:25 AM   #12
T_M
Xtreme Gigolo
T_M's Avatar
Thanks for doing the hard work
Once i've soldered mine up i'll post a clearer picture for people.
__________________
Team.AU
T_M is offline   Reply With Quote
Old 08-19-2007, 12:42 PM   #13
MikeMK
MikeMK's Avatar
Great job! Ive been looking for a simple vmod for the last month!!! I get shocking vdroop underload on my EVGA. Gonna give this a shot
__________________
System Specs:
Core i7 920 @ 4.4ghz
Gigabyte X58A-UD7
3x2gb Corsair Dominator GT 2000Mhz DDR3
2x Sapphire Radeon HD5870
Asus Xonar Essence STX
Intel X25M 160gb SSD
Seagate 7200.12 1TB HDD
Thermaltake Toughpower 1200watt.
Watercooling Specs
Switech GTZ, Thermochill PA120.3, DDC Ultra w/petra top, EK Multires 250 2x EK 5870FC
MikeMK is offline   Reply With Quote
Old 08-19-2007, 02:39 PM   #14
Dualist
Dualist's Avatar
Thank you so much..!!
__________________
Originally Posted by [XC] Hicks121 View Post
Ahhh keep it CD. You can never have enough pussy.
נְפִילִים
Dualist is offline   Reply With Quote
Old 08-20-2007, 07:39 AM   #15
treatmentx
treatmentx's Avatar
Any update on this? Can someone post a clearer picture for where I should be penciling in? #2 or B pencil?
treatmentx is offline   Reply With Quote
Old 08-20-2007, 11:05 AM   #16
T_M
Xtreme Gigolo
T_M's Avatar
Just hard modded vcore, vdroop, vdimm and all working well.
Reproduced picture for clarity - all credit goes to symphy
__________________
Team.AU
Old 08-20-2007, 07:27 PM   #17
Metric
I am Xtreme
Metric's Avatar
Send a message via Skype™ to Metric
Many thanks for the vdroop mod. Board use to droop 0.075 - 0.08 under load! Now it's the same idle or load
I'm having trouble fixing the vdrop in Windows (Still around 0.02). Is the vcore mod supposed to fix this, or am I missing something?...
__________________
X3DM&R : FLICKR : DA : MURDERBOX
Metric is offline   Reply With Quote
Old 08-21-2007, 12:11 AM   #18
treatmentx
treatmentx's Avatar
With the clearer pictures, it appears that it's a resistor?? So how would one draw a line over a resistor with a pencil? Can someone just draw a "dot dot dot" line across the points that needs to be done over with a pencil? I feel like I'm missing something... drawing over resistor seems a bit confusing to me.
Old 08-21-2007, 12:26 AM   #19
m0da
m0da's Avatar
Send a message via AIM to m0da
seriously, just draw a path from the red spots. think of the red spots as metal and you want to connect them together with your pencil's graphite. just draw away and check your voltages
__________________
m0da is offline   Reply With Quote
Old 08-21-2007, 12:54 AM   #20
dinos22
dinos22's Avatar
__________________
Team.AU
Got tube?
Old 08-21-2007, 01:02 AM   #21
T_M
Xtreme Gigolo
T_M's Avatar
Its already explained, but yeah pencil mod means just draw across the top of the resister along it's length from metal tip to metal tip. The amount of graphite you deposit (thickness and dark-ness of your pencilling) will vary the amount of resistance
__________________
Team.AU
Old 08-21-2007, 09:43 AM   #22
Bei Fei
Bei Fei's Avatar
Can someone post a pic of the finished pencil mod please. *runs off to get 2b pencil*
__________________
i7 920 @ 4.2
Bloodrage
GTX 285
OCZ Blade 2133
PC&P Turbo-Cool 860
Custom Case
- Koolance AC-350 - Typhoon III - XSPC-360 -
USA National Debt
Bei Fei is offline   Reply With Quote
Old 08-21-2007, 10:16 AM   #23
The Nemesis
The Nemesis's Avatar
My pencil mod is not showing up very much. But working very well.
__________________
WorkStation
» Intel Core 2 Quad Q9450 L810B906@ 3.8GHz 1.35v » CoolIT Systems Domino A.L.C. » Asus Maximus II Formula » Visiontek All in Wonder HD Premium » 2GB Crucial 8500's 16FD's w/OCZ ramcool
» One Western Digital Raptor WD740ADFD » Samsung SH-S183L» Creative Audigy 2 Platnium » 700w OCZ GameXStream » Antec 900
The Unicorn
» Intel i7 920 3849B028 » Asus Rampage II Gene » BFG GTX 280's SLI » 6GB Kingston HyperX T1 Series » Antec Quattro 1000w PSU » Antec P180 Mini White
» Cooling : Swiftec Apogee GT w/i7 Mounting Adaptor » Swiftech MCW-NBMAX Northbridge Cooler » Swiftec MCP350-DDC1 » Swiftech MCR220-QP Res w/Scythe SlipStreams 110CFM
The Poseidon (Under Going Refit)
» 3GB Corsair Dominator TR3X3G1866C9DF » Tagan /\+ CS Black Pearl WCR
» Cooling : Thermochill PA120.2 w/Scythe SlipStreams 110CFM
The Yamato (BenchStation)
» Intel i7 950 3847A991 » EVGA Classified 760 » Two EVGA CO-OP Edition GeForce GTX 295's Quad SLI or Two Sapphire 5850's CF» 6GB Corsair Dominator GT TR3X6G1866C7GTF » Corsair 850HX 850W PSU » Microcool Banchetto 101
» Cooling : Dragon F1 Extreme Edition(LN2) » Custom SS by RunMc » Swiftech's Apogee GTZ » Swiftec MCP355/Laing DDC-2 w/XSPC Acrylic Reservoir » Swiftech MCR320 QP w/Scythe SlipStreams 110CFM
The Nemesis is offline   Reply With Quote
Old 08-21-2007, 10:22 AM   #24
Cpt.Planet
Cpt.Planet's Avatar
It doesnt really show up but you should check it with a multimeter then check your voltages with one once your done.
__________________
Old 08-21-2007, 10:22 AM   #25
JAG87
JAG87's Avatar
vdroop mod done.
before:
1.40 in bios = 1.35 in windows idle = 1.30 under max load
1.45 in bios = 1.40 in windows idle = 1.35 under max load
1.50 in bios = 1.45 in windows idle = 1.40 under max load (had to use this for 3.6)
1.55 in bios = 1.50 in windows idle = 1.45 under max load
after:
1.40 in bios = 1.38 in windows idle = 1.40 under max load (now stable at 3.6)
1.45 in bios = 1.43 in windows idle = 1.45 under max load
1.50 in bios = 1.48 in windows idle = 1.50 under max load
1.55 in bios = 1.54 in windows idle = 1.55 under max load
Simply fantastic. Now my cpu is stable with 1.40 set in bios, which is 1.38 in windows instead of 1.45!!! everyone with an A1 board should be doing this mod. it gives you a slight reverse vdroop which is excellent. I had to pencil the resistor about 6-7 times before I got the perfect voltages. On the last pass I put too much lead, and I was getting +0.1 under load compared to bios. So I shut down, stuck my finger onto the resistor and wiped a bit of graphite off. Now load voltage is exactly the same as bios setting. This is pretty much one of the biggest flaws that the 680i reference board has, and you can fix it with a pencil. ZOMG im so happy, thank you OP.
__________________
The Gamer:
Intel Core i7 920 | EVGA Classified E759 | G.Skill 6GB DDR3-1600 | nVidia GTX 280 3-way SLI | WD VelociRaptor 300GB | Enermax Revolution 1050W | Dell UltraSharp 3007WFP-HC
The Server:
Supermicro X7SLA-H | Corsair 2GB DDR2-533 | Supermicro AOC-SASLP-MV8 | WD 2TB Green x 5 | Enermax Modu 82+ 425W
The Player:
Dell Latitude E6400 | nVidia Quadro NVS 160M DisplayPort | Pioneer Kuro PDP-5020FD
JAG87 is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
