Results 1 to 8 of 8
Thread: Super PI XS mod fail @ stock speed/voltage
    May 2004
    UK, London
    Hi
    I've just tried 1M Super PI (Xs mod ver) on my new rig. And it is failing at default voltages/stock speed.
    What is odd that i can run stable 4 threads of prime95. And while I'm priming i can run Super PI and then it doesn't crash.
    i3770K@ 4.4 - 1.25v - TR120 Black+ Scythe GT AP-14
    Crucial Ballistix Tracer 4x4096 DDR3 1866Mhz
    Asus P8Z77-v Deluxe
    PowerColor HD R290 moded to X
    Samsung SSD 256GB 840 Pro
    Samsung HDD 7200RPM 2TB (2x1TB) SA(N)TA
    Corsair HX 650W
    Antec P182 +3x Scythe -800-1200RPM
    Asus 27" VN279QLB
    Logitech G100S, CM Storm Quick Fire TK
    Win 8.1
    I am Xtreme
    Sep 2006
    You need 1.4 volts on the Nb for the PC to stabilize at stock speeds with 4 gigs ? but you run your ram highly overclocked ever thought of heat being an issue or degradation ?
    If SuperPi isn't stable that is not a 100 stability sign, funny though the Prime works for hours... one of the reasons I run many benchies to test PC stability...
    Question : Why do some overclockers switch into d*ckmode when money is involved
    Remark : They call me Pro Asus Saaya yupp, I agree
    May 2004
    UK, London
    Oh sorry for miss leading signature. Actually what is there is what I could achieve with my previous mobo with 4 sticks. On the Asus I can clock them same with prime stable.
    Now for testing new cpu(received it yesterday) i restored memory to default stock V and speed to PC5300. And Super PI is failing instantly. Its not even that it is saying there's an error in calculation. It just exiting program instantly with application error.
    Quote Originally Posted by Leeghoofd View Post
    Asus P8Z77-v Deluxe
    Corsair HX 650W
    Asus 27" VN279QLB
    Win 8.1
    I am Xtreme
    Sep 2006
    I think it's more Vista SuperPi related then anything else, have you tried with eg 2 dimms does superpi run then or does it crap out in the same manner ?
    May 2004
    UK, London
    Its not Vista, because I've changed my mobo from MSI P35 Neo and it was working fine on the very same system.
    Basically what changed is my cpu and mobo everything else is same and i can't get Super PI working at stock volt/speed cpu/mem at all.
    Asus P8Z77-v Deluxe
    Corsair HX 650W
    Asus 27" VN279QLB
    Win 8.1
    I am Xtreme
    Sep 2006
    mmm mostly Asus boards have tighter latencies programmed then eg EVGA or MSI, can you fill in your setttings in the following template :
    JumperFree Configuration Settings
    AI Overclocking: Manual
    CPU Ratio Control: Manual
    - Ratio CMOS Setting: 9
    FSB Frequency:
    PCI-E Frequency:
    DRAM Frequency: AUTO (at 266FSB defaults to 2:3 for AUTO)
    DRAM Timing Control: Manual
    CAS# Latency:
    RAS# to CAS# Delay:
    RAS# Precharge:
    RAS# Activate to Precharge:
    TWR: AUTO
    TRFC: AUTO
    TWTR: AUTO
    TRRD: AUTO
    TRTP: AUTO
    Transaction Booster: AUTO
    Boost Level: (only displayes when Transaction Booster is set to Disable or Enabled)
    Clock Over-Charging Mode: AUTO
    CPU Spread Spectrum: Disabled
    CPU Voltage: AUTO
    CPU Voltage Reference: AUTO
    CPU Voltage Damper: AUTO
    CPU PLL Voltage: AUTO
    DRAM Voltage:
    FSB Termination Voltage: AUTO
    North Bridge Voltage: AUTO
    North Bridge Voltage Reference: AUTO
    South Bridge Voltage: AUTO
    Advance CPU Settings
    C1E Suppport: Disabled
    Max CPUID Value Limit: Disabled
    Vanderpool Technology: Disabled
    CPU TM Function: Disabled
    Execute Disable Bit: Disabled
    PECI: Enabled
    May 2004
    UK, London
    Here is the screen shot, where you can see all my settings.
    http://img341.imageshack.us/my.php?i...pierrorgm3.jpg
    Asus P8Z77-v Deluxe
    Corsair HX 650W
    Asus 27" VN279QLB
    Win 8.1
    May 2004
    UK, London
    Leeghoofd
    Oh and my settings for this test looks pretty much as your template.
    Asus P8Z77-v Deluxe
    Corsair HX 650W
    Asus 27" VN279QLB
    Win 8.1
