Results 1 to 25 of 48
Thread: New Q6600 G0 Build Failing at Stock Speeds in Prime95
Threaded View
    Jul 2007
    This sounds like a processor issue but I'm not sure. I just built this system yesterday and it seems to be stable but when I run prime95 it will cause my system to crash in both XP and x64 Vista. I have tried the different types of stress tests running 4 processes but it will usually crash in 10-30 minutes. Temps don't seem that high even though it's really hot in my room. I can barely detect any warmth when touching my Tuniq Tower and the only parts that seem hot were the 8800GTX which was idling at about 58c and the ram. In core temp which I can't get to work much none of the cores were over than 51c when it crashed in Vista.
    I tried running the latest memtest for 6 hours and it didn't get any errors. I tried bumping the processor and ddr2 voltage up a little but it made no difference. The only other thing I could think of is after I was running memtest for a while it looks like everything was powered off and my UPS went out so maybe the system is not getting good power from the UPS or the outlet it's plugged into. A few days ago the UPS reported outages in my other computer that it recovered from so I'm going to try another outlet next.
    Any suggestions?
    Edit: It has been running for about an hour using the test with the small FFT and it probably hasn't crashed yet because it's a less stressful test. I will try to add a picture of core temp in a little.
    Shot at 2007-08-01
    G0 Q6600 w/Tuniq Tower
    ABIT IP35 Pro
    CM Stacker 832
    G.SKILL 4GB(2 x 2GB) DDR2 800
    Evga 8800GTX
    PC POWER and COOLING Silencer 750 Quad
    bluegears b-Enspirer 7.1
    XP & Vista x64
