Only the 2nd one of these I've seen on XS AFAIK ?
System:
- Intel Xeon X3230 QYPT GO L713A290 ES
- Swiftech G4 Storm/Thermochill 120.3/MCP655
- Asus Blitz Extreme 0601 bios
- 128MB Gainward FX5200 PCI
- 2x1GB OCZ PC3-14400 Platinum - DDR3-1800 rated at 8-8-8-27 at 1.9v
- 500GB Seagate 7200.10 SATA on SATA1 Port
- LiteOn 165H DVD Burner
- Sony FDD
- 1KW OCZ ProXStream
- WinXP Pro SP2
Xeon G0 LGA775 cpus come in three models which seem to have slight higher rated TDP of 100W vs the Q6600 G0 stepping @95W:
Intel Xeon X32xx Quad Core G0 stepping:
- Intel Xeon X3230 2.66Ghz - SLACS - G0 - 100W / TDP 85C - 1.100-1.372V
- Intel Xeon X3220 2.40Ghz - SLACT - G0 - 100W / TDP 85C - 1.100-1.372V
- Intel Xeon X3210 2.13Ghz - SLACU - G0 - 100W / TDP 85C - 1.100-1.372V
Intel Xeon X32xx Quad Core B3 stepping:
- Intel Xeon X3220 2.40Ghz - SL9UP - B3 - 105W / TDP 85C - 1.100-1.372V
- Intel Xeon X3210 2.13Ghz - SL9UQ - B3 - 105W / TDP 62C - 1.100-1.372V
Intel Core 2 Quad line:
- Intel Core 2 Quad Q6600 2.40Ghz - SL9UM - B3 - 105W / TDP 62.2C - 1.100-1.372V
- Intel Core 2 Quad Q6600 2.40Ghz - SLACR - G0 - 95W / TDP 71C - 1.100-1.372V
- Intel Core 2 Quad Q6700 2.66Ghz - SL9CQ - G0 - 95W / TDP 71C - 1.100-1.372V
Intel Core 2 Extreme (Quad core):
- Intel Core 2 Extreme QX6850 3.00Ghz - SLAFN - G0 - 130W / TDP 64.5C - 1.100-1.372V
- Intel Core 2 Extreme QX6800 2.93Ghz - SLACP - G0 - 130W / TDP 64.5C - 1.100-1.372V
- Intel Core 2 Extreme QX6800 2.93Ghz - SL9UK - B3 - 130W / TDP 54.8C - 1.100-1.372V
- Intel Core 2 Extreme QX6700 2.66Ghz - SL9UL - B3 - 130W / TDP 65C - 1.100-1.372V
Let's see how stock temps are... as we can see stock VID = 1.275v and AUTO vcore in bios confirms it at 1.248v real vcore when AUTO vcore is set. This is same VID as my Q6600 B3 ES cpu as well which managed on water cooling to be Wprime 32M + 1024M passable @3920Mhz at 1.616v in <14C ambients.
10x266FSB at stock VID = 1.275v
Room temp = 22.4C
Idle
Load
Post Load Idle
