Results 1 to 4 of 4
Thread: 775 Mobo Backplate Recommended - Yes! (Photos)
    Banned
    Oct 2006
    Houston, Texas
    The last time I tore down my rig, I added two MCW30s (hard mounted) and two EK MOSFET Blocks. I also did some flow tests.
    http://www.xtremesystems.org/forums/...ghlight=snyxxx
    When I mentioned that the MOSFET blocks were difficult due to the Mobo bending, a few wise people commented on using a back plate. After looking at it again, man, should have seen that much bending - duh.
    I bought a Scythe back plate from Petra and can show some before and after.
    Before Photos:
    http://www.xtremesystems.org/forums/...1&d=1185940003
    http://www.xtremesystems.org/forums/...1&d=1185940045
    http://www.xtremesystems.org/forums/...1&d=1185940074
    http://www.xtremesystems.org/forums/...1&d=1185940111
    Storm Mounted Only
    http://www.xtremesystems.org/forums/...1&d=1185940139
    Back plate really works great. No bending at all from the storm mount as before. It is not all golden, see next post for after pictures.
ID:	62385   Click image for larger version.
ID:	62386   Click image for larger version.
ID:	62387   Click image for larger version.
ID:	62388   Click image for larger version.
    Banned
    Oct 2006
    Houston, Texas
    Here are some after photos. The EK MOSFET blocks mounting cranks in end moments and squishes the end chips and it barely touches the middle chips. See the thermal pads. It is a difficult install and it is all by feel.
    Eddy needs to provide a small back plate for these.
    I am going to chop up one of my extra back plates and make my own.
    http://www.xtremesystems.org/forums/...1&d=1185940360
    http://www.xtremesystems.org/forums/...1&d=1185940515
    http://www.xtremesystems.org/forums/...1&d=1185940473
    http://www.xtremesystems.org/forums/...1&d=1185940490
    http://www.xtremesystems.org/forums/...1&d=1185940508
ID:	62390   Click image for larger version.
ID:	62391   Click image for larger version.
ID:	62392   Click image for larger version.
ID:	62393   Click image for larger version.
    May 2006
    Nice.
    Am I right to say that the backplate stopped your mobo from bending, but now the backplate bends itself?
    Core2Duo E6600 @ 3.0 - Load @ 32c°| Gigabyte P35 DS3P | 2gb Crucial Ballistix Pc2-8500| eVGA 8800GTX| X-fi Fatal1ty | OCZ GameXStream 600w | Custom Watercooled | Custom-built Case
    Dtek Fuzion | DD Maze4 Acetal | Swiftech MCR-320 | DD D5
    3dMark01 3dMark05 3dMark06 Aq3 SuperPi
    Quote Originally Posted by Movieman View Post
    I don't beleive in passive cooling.
    Banned
    Oct 2006
    Houston, Texas
    Thanks. No there is no back plate bending at all. It really stopped the storm mounting from bending the mobo as before. There is foam on the back plate to electrically isolate it from the mobo to prevent shorts I guess. It looks as though the back plate is bending in one picture, but it is only this foam pad compressing at the four corners where the bolts are, but not at the middle.
    The mobo is not bent at all from the storm, but the EK MOSFETS still induce some bending.
