Originally Posted by
jayhall0315
The question about whether you want a pump with more head pressure (like the DDC + 18 watt version) or a pump with more flow (like the MCP 655); or likewise whether it is better to have a high impingement block (like the Storm) with reduced flow or a low impingement block (like the Fuzion) with greater flow or a block that might be somewhere in between, like the Apogee GT, turns out to be surprisingly difficult to give a one sentence answer to. These exact questions that many of you have wrestled with when choosing your blocks or pumps in a slightly different context are the same questions that stumped the ancient Romans when building aquaducts to bring water into Rome. That is because the two critical components in the performance of your water loop, pressure and flow are COUPLED. That is why it is so difficult to have an intrinsic or instinctual feel for what is going on (believe me when I say that this was also argued about fiercely until the matter was finally laid to rest in the early 1800s). Consider for a moment this quandry: If I have a high flow waterblock with almost no pins on it, the water should move across its surface quicker (since there are no pins to block its flow) allowing the water to flow over the block's smooth surface and take more heat away, right? But wait, if the block has very tall copper pins sticking up from the base or a wide area of pins (like the Apogee GTX) they provide much greater surface area for transmitting heat into the passing water, right? But then again, those pins sticking up are blocking the flow of some of the water, right? So, now which block design is the best?
More to come this evening,
Jay
