Results 1 to 25 of 47
Thread: Reservoirs vs T-lines in Flow Rate = Insignificant
Threaded View
    Xtreme X.I.P.
    Jun 2007
    Bend, Oregon
    I was curious about how T-lines compared to Reservoirs and I also needed some equations to plug into my estimator spreadsheet I've been working on, so in spirit of my curiosity, I ran pressure drop curves. The end result is that I found that T lines are less restrictive, but both in general are SOO small, you really shouldn't worry about it.
    The contenders:
    Don't you like the tractor? And hey...I kind of like the coke bottle, maybe I'll make a good one for real..
    And the resulting graphs:
    Now for the reality of what this small pressure drop means:
    D-tek Fuzion, MCW60, MCR320, D5, 7' of 1/2" ID tubing = 1.68 GPM
    D-tek Fuzion, MCW60, MCR320, D5, 7' of 1/2" ID tubing + 1 T-line = 1.66 GPM
    D-tek Fuzion, MCW60, MCR320, D5, 7' of 1/2" ID tubing + 1 Reservoir = 1.64 GPM
    I already have these worked into the next flow rate estimator release, but the bottom line is...neither one amounts to any noteable loss.
    I wouldn't base your decision on flow rate, back to personal preference..
