Page 1 of 8 1234 ... LastLast
Results 1 to 25 of 195
Thread: Dfi P35
    Xtreme Cruncher
    Jan 2007
    Massachusetts
    Dfi P35
    http://us.dfi.com.tw/Press/press_hea...60.jsp&SITE=US
    The developing speed of PC industry is incredible fast in these years. It just likes: CPU transformation, which is transit from dual core to quad core, the FSB from 800/ 1066MHz up to 1333HMz. On the other hand, VGA just started the competition between SLI & Crossfire, and then additional physics rendering function involves the war…Also, the generation of memory is from DDR and all the way down to DDR3 era. All these changes have happened within 2 years; likewise, DFI also has transformed a lot in product design. The first revolution is to replace traditional mosfit with digital PWM. And then, “EZ clear” for users to clear CMOS in a easier way. Further, DFI tried to use a separate advance audio device (Karajan audio and Bernstein) in LANParty motherboard. Now, DFI are intended to gathering those advance features together in a brand new model, the LANParty UT P35-T2R.
    CPU, FSB and chipset's structure
    DFI LP UT P35-T2R/T3R supports Intel's dual and quad core processors. It is compatible with FSB 1333MHz. The benefit of the low power consumption from core 2 dual series makes a better operate environment . The highest FSB1333MHz increase the probability to get a highest OC record. The board adopts P35 + ICH9R chipsets as North and south bridge. Further, P35 supports DDR3 memory and Intel's next generation 45nm process CPU. That is a powerful upgrade for Intel platform. In addition, the chipset also supports latest Matrix Storage technology and HAD audio technology, which maximized the storage and audio output ability.
    The secret weapon: DFI unique heat pipe assembly
    The designer of DFI LP UT P35 series has created a whole new “weapon”, a heat pipe assembly from SB, NB then extend to PWM. The design of DFI's new heat pipe is totally different to others in market.
    It uses a copper-made pipe to connect independent heat sinks of SB, NB and PWM together. Then, there will be an extension joint (Transpiper) to carry the heat out from the chassis. The Transpiper can be extended to where outside the PSU fan. That means the air flow from the PSU fan will be help to carry out the heat from Transpiper. Otherwise, the heat air flow will be stuck inside the chassis and that will jeopardize the stability of the system. This is a magnificent breakthrough of heat pipe assembly design.
    Unique arrangement for Crossfire + Physics rendering
    Since the Physics rendering technology has been revealed in PC market, gamers are all to pay close attention to it. Meanwhile, DFI was put it into LANParty motherboard as an advance features and that shows the gigantic power of Crossfire + Physics rendering. But 3 VGA cards bring a lot of heat as the same time. Hence, the arrangement of 3 VGA slots (2 CF + 1Physcis) seems especially essential for the system. If the spaces between 3 VGA slots are not enough, that'll cause heat dissipation problems. Therefore, DFI propose a perfect solution for that; the designer separated each of the slots with 2 additional PCI slot space. That means the 3 VGA slots located evenly in the board. That's a big improvement for efficient heat dissipation of VGA area between those “thick cards”(ex.1900, 2900).
    Ultimate 8-phase Digital PWM
    DFI is never satisfied to use any components of inferior quality. For this brand new model LP UT P35-T2R, DFI chooses to use an utmost 8 -phase Digital PWM in place of the advance 6-phase PWM. A digital PWM uses components to supply stabilized current, which accommodate enthusiasts ' needs in OC or Gaming. DFI UT P35 series provides sufficient current for the processor. Aside from this, the new heat dissipating fins of the PWM circuit further stabilize current flow to the system.
    The cutting-edge audio solution- “Bernstein Audio”
    Leonard Bernstein, best-known conductor and music composer of USA i n 50's of 20 century. Bernstein represents the supreme authority of classical music in Northern America. LP UT P35 series is equipped with this brand new “Bernstein Audio” module. In fact, the board's designer uses a new way to generate this module. For easier installation, designer moved this module close to “PCI slots area” for easy to mount in PCI bracket. Second, it obtains a perfect noise reduction than Karajan's. As all we know, no matter Pro-gamers or power users who used to enjoy music and movie with their PCs must have highly requests about the quality of their audio output device. Hence, how much the noise can be reduced is what they concerned about in high priority. DFI's Bernstein audio module is intents to improve this kind of issue; it uses a unique way to separate the “signal” of audio module and motherboard, which makes the electric interfere of audio output decrease to minimum level.
    Bernstein audio adopts Realtek ALC885 high definition codec. It is certified by Microsoft Vista Premium. In addition, ALC885 features a DAC SNR of 106dB and ADC SNR of 101dB. Then, the codec also supports sampling at highest 192 KHz, 10 DAC channels, 3 Stereo ADC channels (7.1 + 2 channels) and 24bit PCM. Besides, it provides “Full-rate Lossless Content Protection Codec”, which's able to decrypt Content Protection for HD-DVD in the future, if not; the sound quality of DVD will be a step lower than the standard.
    Supports DDR2/ DDR3 memory
    The substitution of memory's each generation is being faster and faster. We still remember that; the market leads us to replace our memory to DDR2 while we're just used to use DDR. Then, we're finally figure out what exactly DDR2 is, meanwhile, the module manufacturer teaches us to choice DDR3 and try to say goodbye to DDR2… Hence, DFI is considerate of power users' unique demand. LP UT P35 series is ready to launch DDR2 and DDR3 models to satisfy power users' request. The LP UT P35 T3R (DDR3) will be launch into market right after LP UT P35 T2R.
    Versatility BIOS options
    Enthusiasts are always found great pleasure when they are able to squeeze a little more performance from their system through overclocking. For this reason, the designer of DFI LP UT P35-T2R offers a versatility BIOS options for enthusiasts to enjoy during they overclocking. So, the voltage options are the key point, which includes: memory voltage options, NB & SB options, CPU Vcore option and HT voltage options. That would make enthusiasts an unlimited OC environment. Besides, the unique CMOS Reload can help users to store different OC settings in BIOS. Further, LANParty series motherboard adopts high quality capacitors and components for an advance OC “physical structure”.
    Teaming function & Dual Gigabit LAN
    At the very beginning, LANParty series provides Dual gigabit LAN to gamers as a basic feature. Nowadays, it is almost a “must” when users want to grab information such like DVD content, huge capacity games or fighting with buddies on LAN game. For that reason, DFI LP UT P35-T2R provides another unique function to all the heavy user of Internet/ LAN - the Teaming function. It makes the dual LAN Ports' bandwidth to combine together as one. Then the bandwidth will be two times large than original one. Moreover, if one of the LAN port crashed, the other one will be carry on the processing task over Internet or LAN. Therefore, teaming function is brings you a wider and safer LAN transmission environment.
    Edit Two:
    Lemon and lime anybody? Interesting heatpipe/heatsink thing though.
    xtreme energy
    Oct 2004
    Europe, Latvia
    Nice!
    JSP Error:
    Request URI:/Press/press_header_content_us.jsp
    Exception:
    java.io.FileNotFoundException: d:\oracle92\apache\apache\dfi_web\Upload\News\US\a rch460.jsp (The system cannot find the file specified)
    at java.io.FileInputStream.open(Native Method)
    at java.io.FileInputStream.(FileInputStream.java:64)
    at oracle.jsp.provider.JspFilesystemResource.fromStre am(JspFilesystemResource.java)
    at oracle.jsp.provider.JspFilesystemResource.fromRead er(JspFilesystemResource.java)
    at oracle.jsp.app.JspAppLoader.reloadPage(JspAppLoade r.java)
    at oracle.jsp.app.JspAppLoader.loadPage(JspAppLoader. java)
    at oracle.jsp.app.JspAppLoader.getPage(JspAppLoader.j ava)
    at oracle.jsp.app.JspApplication.dispatchRequest(JspA pplication.java)
    at oracle.jsp.JspServlet.doDispatch(JspServlet.java)
    at oracle.jsp.JspServlet.internalService(JspServlet.j ava)
    at oracle.jsp.JspServlet.service(JspServlet.java)
    at javax.servlet.http.HttpServlet.service(HttpServlet .java:588)
    at oracle.jsp.provider.Jsp20RequestDispatcher.include (Jsp20RequestDispatcher.java)
    at oracle.jsp.runtime.OraclePageContext.include(Oracl ePageContext.java)
    at _press._press__header__content__us._jspService(_pr ess__header__content__us.java:153)
    at oracle.jsp.runtime.HttpJsp.service(HttpJsp.java)
    at org.apache.jserv.JServConnection.processRequest(JS ervConnection.java:456)
    at org.apache.jserv.JServConnection.run(JServConnecti on.java:294)
    at java.lang.Thread.run(Thread.java:484)
    Jan 2005
    Stafford, UK
    Green slots; interesting...
    VENOM: DFI LP LT X38-T2R ~ Core 2 Duo E8600 @ 4.00GHz ~ 4GB OCZ Blade LV DDR2-1150 ~ Radeon R9 380 4GB ~ Crucial C300 64GB ~ Seasonic X-750 ~ Dell U2913WM 29" ~ Win 7 Ultimate x64
    LAIKA: Alienware Alpha R2 ~ Core i5-6400T @ 2.20GHz / 2.80GHz ~ 16GB Ballistix Sport LT DDR4-2133 ~ GeForce GTX 960 4GB ~ Crucial MX300 275GB ~ LG OLED55B7A 55" TV ~ Win 10 Home x64
    BLADE: Razer Blade 14" (2013) ~ Core i7-4702HQ @ 2.20GHz / 3.20GHz ~ 8GB DDR3-1600 ~ GeForce GTX 765M 2GB ~ Samsung 840 EVO mSATA 500GB ~ Win 7 Ultimate x64
    E-MAIL
    Xtreme Cruncher
    Jan 2007
    Massachusetts
    Sumanji, you're getting the pictures?
    Edit:
    Oh, the front one loads.
    Feb 2007
    USA
    hmmm Victor posted pics of p35 back in the day and it wasn't green
    Jun 2006
    nice...but why DFI is so late lately
    Xtreme Cruncher
    Jan 2007
    Massachusetts
    Quote Originally Posted by Nooc View Post
    I think that was X38.
    Feb 2007
    USA
    Quote Originally Posted by OCFX View Post
    why lately? they've always been late. They released the first nf2 and nf4 mobos long after it's debut, but at least they were quality. DFI, take your time
    Mar 2005
    Chicago, IL
    Perfect timing since its few days till July 22, I hope I will be able to buy both E6850 and the board.
    Q6600 3.6Ghz @ 1.276v | DFI LP LT P35 | Ballistix Tracer PC2-8500 600Mhz @ 2.074v | GeForce 260 GTX | Auzen X-Fi Prelude | PCP&C 750 | Arch Linux ~ WinXP
    AMD Athlon 64 X2 3800 | DFI LANParty NF4 SLI-DR | 2x512MB G.SKILL PC3200 BH-5 | OCZ PowerStream 520W | Palit GeForce 9600 GT | Gentoo
    Long Live DFI.
    Sep 2006
    Where are the pictures?
    ░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░ Intel i7 3770k
    ░░░░░░▄▄▄▄▀▀▀▀▀▀▀▀▄▄▄▄▄▄░░░░░░░░░ ASUS GTX680
    ░░░░░░█░░░░▒▒▒▒▒▒▒▒▒▒▒▒░░▀▀▄░░░░░ ASUS Maximun V Gene
    ░░░░░█░░░▒▒▒▒▒▒░░░░░░░░▒▒▒░░█░░░░ Mushkin 8GB Blackline
    ░░░░█░░░░░░▄██▀▄▄░░░░░▄▄▄░░░█░░░░ Crucial M4 256GB
    ░░░▀▒▄▄▄▒░█▀▀▀▀▄▄█░░░██▄▄█░░░█░░░ Hitachi Deskstar 2TB x2
    ░░█▒█▒▄░▀▄▄▄▀░░░░░░░░█░░░▒▒▒▒▒█░░ FSP 750W Gold
    ░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░ Fractal Arc Mini
    Mar 2005
    Florida
    ya i'm not seeing anything here.....
    C2Q Rig.... C2Q Q6600 @ 3.6ghz | Abit IP35 Pro | 2 x 1gb G.Skill DDR2 PC6400 | eVGA 8800gts 320 x 2 | Silverstone TJ-09
    i7 Rig.... i7 920 @ --ghz | eVGA x58 | 3 x 1gb G.Skill DDR3 1600 | eVGA -------- | Caseless
    FAH Quad / GPU Farm....To be continued....
    My Folding Stats...
    Oct 2005
    U.K.
    i'll be surprised if we see them in stores this month
    the link works for me
    i950 (3035B684)
    Gigabyte EX58A-UD3R
    3x4GB G.Skill PC3-12800 7-8-7-24
    HIS Radeon HD 6970 2GB & Dell 3007WFP-HC
    Asus Xonar DX
    128GB C300, Velociraptor & Sammy F3's
    Corsair AX850W
    Windows 7 Ultimate x64 SP1
    Aug 2006
    Southern California. USA.
    Re-hosted pics.
    Mar 2005
    Florida
    DFI sprite edition....cool
    My Folding Stats...
    Nov 2003
    france -- lille
    the link doesn't work with opera firefox2 and IE7
    Xeon 3060 L631B115 max 4680 superpi SS 10.904
    Asus P5B deluxe + vdrop vcore vddr2 vmch mods
    2x1go crucial ballistix pc8000
    2x1go crucial ballistix pc6400
    8800 gts 320 // x800xl // 9250 pci
    corsair hx 620 // seasonic s12 500
    DOD chilly1 R402a
    watercooling // zalman9700
    Xtreme Guru
    Apr 2005
    Finland
    So when will this be available I wonder? If they could get it out soon then DFI would be unusually quick to launch a board based on current gen chipset (by DFI's own schedule). The link worked for me (Firefox 2.0.0.5)
    I hope this board would be available within 2 weeks or so then I might actually pick it up.
    Intel? Core i5-4670K @ 4.3 GHz | ASRock Extreme6 Z87 | G.Skill Sniper 2x8GB @ DDR4-1866 CL9 | Gigabyte GTX 970 OC Windforce 3x | Super Flower Titanium 1000W | ViewSonic VX2268wm 120Hz LCD | Phanteks PH-TC14PE | Logitech MX-518 | Win 7 x64 Professional | Samsung 850 EVO & 840 Pro SSDs
    If all people would share opinions in an objective manner, the world would be a friendlier place
    Apr 2005
    still server error
    Gaming: SaberThooth X79,3930k,Asus6970DCII_Xfire,32gb,120OCZV3MaxIOPS, ThermaTake Chaser MK1
    HTPC:AMD630,ATI5750,4gb,3TB,ThermalTake DH103
    Server: E4500,4GB,5TB
    Netbook: Dell Vostro 1440
  18. #18
    Dec 2006
    Hm... interesting to see what DFI will do with p35, but again, by the time its out there would be a better asus x38 board...
  19. #19
    Xtreme Mentor
    Aug 2006
    HD0
    DFI ~= ASUS ???
  20. #20
    Sep 2006
    Quote Originally Posted by DFI View Post
    LOL
    DVD content? What are they getting at?
    I also never thought that DFI would take the win for the heatpipe contest.
  21. #21
    Xtreme Mentor
    Aug 2006
    HD0
    Quote Originally Posted by FatHippo View Post
    willing to bet that DFI's P35 design will be drop in compatible with x38
  22. #22
    OC Jedi (on stand-by)
    Jan 2005
    Germany
    Interesting design to say the least...
    But what are the heatpipes/fins on the back of the case supposed to cool? PSUs do not create a immense air stream and the air that comes out of PSUs is hot
    The green slots look, oh well.. different
    オタク
    "Perfection is a state you should always try to attain, yet one you can never reach." - me =)
  23. #23
    Xtreme Cruncher
    Jun 2005
    MA, United States
    I think the heatpipe design is ridiculous IMHO, how much heat can be transfered through plates you screw together in series like they have set up? Give me their 680i cooling solution any day of the week over this
    Heatware | Abit IP35 Pro | Intel E6750@3.8Ghz 1.56v | Storm R2 | Ballistix DDR2-8500 | Sapphire HD3870 512MB@TBA | MCW60 | WD Raptor 74GB | WD2500KS | OCZ GameXSteam 600w | SoundBlaster Audigy 2 ZS | DT770/80Pro | WinTV PVR-250 | Antec P180 | 7 Yate Loon D12SL-12 | AQ50Z | PA120.2 Custom Painted | BIP GTS 120mm | MasterKleer 7/16 Tubing | VX924 | G15 Keyboard/G5 Mouse/Steelpad QCK+
  24. #24
    Apr 2006
    Central California
    Quote Originally Posted by kuhla View Post
    Re-hosted pics.
    I honestly got a sudden urge to drink a sprite. Is this that "Sublymonal Advertising" they've been going on about?
  25. #25
    Feb 2005
    Indiana
    I don't really care for the heatpipes...but lets wait and see. I'm personally excited at the new color scheme. And the three PCIe slots.
