Results 1 to 9 of 9
Thread: Asus P5K-Deluxe & E6700 Batch# L633A557 Overclocking Success: Low volts & High Clock!
    May 2007
    Richmond (GVA), BC, Canada
    After weeks of tweaking and Orthos stress testing, I think I've found my perfect sweetspot for my P5K-Dlx + E6700 combo.
    Please feel free to use my OC BIOS configuration below for reference purposes. I'd like to also give out my special thanks to EVA2000 and numerous other members who gave out their generous tips and pointers.
    This is what makes the whole OC community so great
    JumperFree Configuration Settings
    AI Overclocking: Manual
    CPU Ratio Control: Manual
    - Ratio CMOS Setting: 8
    FSB Strap to Northbridge: AUTO
    FSB Frequency: 466
    PCI-E Frequency: 105
    DRAM Frequency: DDR2-1166
    DRAM Command Rate: 2T
    DRAM Timing Control: Manual
    CAS# Latency: 5
    RAS# to CAS# Delay: 5
    RAS# Precharge: 4
    RAS# Activate to Precharge: 5
    TWR: 3
    TRFC: 30
    TWTR: 3
    TRRD: 3
    TRTP: 5
    DRAM Static Read Control: ENABLE
    Transaction Booster: AUTO
    Boost Level: (only displays when Transaction Booster is set to Disable or Enabled)
    Clock Over-Charging Mode: AUTO
    CPU Spread Spectrum: Disabled
    CPU Voltage: 1.4500
    CPU Voltage Reference: x0.63
    CPU Voltage Damper: Enabled
    CPU PLL Voltage: 1.7
    DRAM Voltage: 2.2
    FSB Termination Voltage: 1.40
    North Bridge Voltage: 1.55
    North Bridge Voltage Reference: x0.61
    South Bridge Voltage: 1.2
    Advance CPU Settings
    C1E Suppport: Disabaled
    Max CPUID Value Limit: Disabaled
    Vanderpool Technology: Disabaled
    CPU TM Function: Disabaled
    Execute Disable Bit: Enabled
    PECI: Enabled
    USB Configuration
    USB Functions: Enabled
    Legacy USB Support: Disabled (need to enable it to detect USB flash drives)
    Xtreme Air-Cooled OC System:
    Mobo: Asus Rampage Formula (X38 Edition) Rev 1.03G (BIOS: 0803)
    CPU: C2Q Q6600 "G0" L723A765, VID 1.2625, 3720mhz, FSB 465*8, Vcore: 1.464, Idle/load temp: 31c/64c
    CPU Heatsink: Thermalright Ultra120 Xtreme lapped (2* Scythe S-Flex SFF21F S-FDB 120mm Push-Pull configuration)
    RAM: Kingston HyperX T1 2x2GB PC2-8500 (DDR2-1116)(5-5-5-15-3-52-6-3-8-3-5-4-6-4-6-14-5-1-5-5)(2.264 Vdimm)(Rated @ 2.3v default clock)
    HDD: Western Digital Caviar Black 640GB WD6401AALS-00L3B (AHCI)
    Video Card: XFX 8800GTS 320mb Xtreme, Core 612 Shader 1420 Mem 900 (Stock cooling)
    Sound Card: Auzentech Meridian 7.1 (8788 chipset)
    DVD: Pioneer 212D SATA DVD-RW
    PSU: Corsair HX620W Modular
    Xtreme Air Cooled Case: Antec 900 case | 3*120mm intake | 1*120mm & 1*200mm exhuast
    OS: Vista Ultimate x64 SP1 Build 6001
    Apr 2005
    Toronto, ON
    Great results! I've been following Eva's and your own progress as something to emulate while clocking my E6700. Currently have it at 9x389 for 3.5GHz at 1.400V BIOS (1.36V according to Asus probe).
    Did you have to put a fan over your NB to get your overclock stable? I found that @ 8x400 I don't need it, but at 9x389 I do.
    i7 3770k - p8z77-v pro - 4x4gb - gtx680 - vertex 4 256gb - ax750
    i5 3570k - z77-pro3 - 2x4gb - arc-1231ml - 12x2tb wdgp r6 - cx400
    heatware
    May 2006
    Philippines ^_^
    very nice.. congratz on your OC..
    eva2000 is really an asset of the community.. I can also name FCG, raju, Tony, dinos22, and many more..
    Asus P5W64 WS Professional , DFI Infinity 965P-S (testing)
    X6800 , E6750 es
    Micron Fatbodies , Micron D9gkx oem, Crucial 8000, Crucial Tracer 8500 (incomming)
    Ati FireGL V5100, Elsa FireGL V3100
    water cooling setup (EK 775 cpu block, swiftech NB Block, Swiftech pump, BI dual pass dual 120mm)
    Silverstone OP650
    raptors, baracuda
    May 2007
    Quote Originally Posted by zoob View Post
    Nope, no fan over NB and Ram sticks (Recommanded, I know)
    However, becouse I've massive air flow and ventilation within my Antec 900 so I can probably still get pass by without active cooling on the NB. The Asus P5K-Dlx stock heatpipe based chipset heatsinks should be adequately enough for high OC but may be not enough for Xtreme OC beyound 550+FSB or 4Ghz+ for example. In that case, active cooling or water cooling should take in place. Overall it's still a satisfying OC result on air.
    Please check my sig for detail hardware configurations (ie. fans setup)
    Quote Originally Posted by erwinz View Post
    defintely, yeah I recognize most of the names you mentioned. Those guys are awsome! I can never come close to those guys but I still would like to share my OC findings with others here
    Xtreme Cruncher
    May 2007
    Sydney, AUS
    Awesome. Thanks for the results, as this is pretty similar to the system I am building right now...makes me strive to see if I can at least get to your clocks
    Jun 2007
    Good work Tiramisu!
    Are you still going to go quadcore even after you have gotten such terrific results with your e6700?
    were the settings like the fsb strap, dram static read control, and PCI-E frequency necessary for this OC result?
    Also, can we see some pi 32m times?
    Congrats Tiramisu!
    Xtreme Guru
    Jun 2006
    Finland, joensuu
    nicely done XtremeTiramisu
    my e6600 can work on high clocks and low voltages too.
    Evga X58 sli under cascade
    http://www.xtremesystems.org/forums/...d.php?t=219788
    Evga X58 Sli ultimate overclocking/ overview/ discussion thread
    http://www.xtremesystems.org/forums/...d.php?t=221082
    proud owner of E8600 Q822A435
    I am Xtreme
    Oct 2004
    U.S.A.
    have you tried 9x400 or 10x365? see how much vcore they take.
    Asus Z9PE-D8 WS with 64GB of registered ECC ram.|Dell 30" LCD 3008wfp:7970 video card
    LSI series raid controller
    SSDs: Crucial C300 256GB
    Standard drives: Seagate ST32000641AS & WD 1TB black
    OSes: Linux and Windows x64
    May 2007
    Quote Originally Posted by derekchinese View Post
    Good work Tiramisu!
    Congrats Tiramisu!
    1. In terms of the applications I use, a highly OC'ed C2D would actually yield better performance than a OC'ed quad on air. I'm not an user who'll fully utilize all 4 cores because the applications I use aren't mutil-threaded and most of today's applications aren't written to benefit the usage of an quad.
    But having said that, the trend is moving towards quad. A year from now, statements about C2D vs C2Q could change and I'm in the situation of building my second PC so in the end I might ended up choosing a Q6600 G0 stepping. I think the biggest challenge I'll face will be the heat issue even I'm using high-end air cooling and the G0 is suppose to run cooler than the current B3 stepping from quads. The E6850 may be the best choice for air cooled OC'er but reading from some overclock-ability of an ES E6x50 and actual retail E6x50 indicated that the OC result may vary. When I take this into account, I really don't want to take my risk eventhough an E6850 is capable of OC up to 4Ghz on air but the amount of voltage is through the roof as well from most of the results I've seen so far. Since I already have a golden C2D that's capable of doing what some of the better E6x50 can do but with less volt, I don't think I want to take the risk of buying a E6850 and ended up not doing AS good as the current one. Temp wise it's going to get much better than my rather hot E6700 with its given volt.
    Simply, I feel it's time to start a new chapter, thus Q6600 G0 should be my next investment in a CPU. At roughly ~$300, it's really hard to turn down. For Vista users such as myself, I think the OS alone will benefit the quads as well.
    2. FSB Strap: I've being testing it with it set to 266 strap but I was told that AUTO gives you a little more bandwidth. This I'm not certain becouse I havn't done any in-depth testing on it but I don't think it matters much anyways. Set it to AUTO will give you all choices of dividers.
    3. Dram Static Read Control should be set to Enable for P5K-Dlx. It gives you more bandwidth and there will be no strap change when it's set to enabled. Strap change occurs after FSB499.
    4. PCI-E set to 105 isn't really necessary but I changed it anyways just to get rid of a potential problem due to overclocking. Setting it too high isn't favorable for 24/7 use.
    Quote Originally Posted by safan80 View Post
    9x400=3600 and 10x365=3650
    If I remembered correctly, I think I only need ~1.35v Orthos loaded to get those clock stable.
    Becouse I'm using vista x64, I can't open coretemp or Intel TAT but my CPU VID is 1.25000v and that's my E6700's stock voltage.
