Results 1 to 19 of 19
Thread: MAX safe volts on RAM 24/7?
    May 2007
    Hello all,
    I have been wondering browsering those pages, I saw that many d9s died under high volts. I got myself a Mushkin XP2 8500 ( D9GMH) those are rated up to 2.35v under warranty, I was wondering what is actually max safe voltage for 24/7 , even so it is rated up to f.e. in my case 2.35, those rams getting nasty hot, and I dont like RMAs so , want to avoid it much as possible. I got a 80mm fan mounted on it tho, altho it doesnt covers the whole stick Pic: http://img120.imageshack.us/my.php?i...img0756pr1.jpg and i got 4x intake @ m sidepanel blowing on the mobo, considering this what would be the max safe voltage to run 24/7? Any help appreciated
    • DFI Lanparty LT X48-T2R
    • Intel Q6600 L737B242 ~ VID 1.2125 ~ 4000mhZ @ 1.48 vcore {lapped}
    • eVGA 8800GTS (G92) 512MB {stock}
    • Crucial Ballistix PC8500 Tracer ~ 1200mhZ 5-5-5-12 @ 2.05v
    • Lian Li PC-V1000 {modded}
    • Corsair HX 620W
    • Creative X-FI ExtremeMusic
    • Western Digital Raptor X 150GB
    • Thermalright-Ultra120 Xtreme {lapped} ft. Scythe S-Flex SFF21F S-FDB ~ Push & Pull
    Aussie God
    Feb 2005
    Copenhagen, Denmark
    Depends..?
    Volts isnt the only thing injuring your mem...
    With a 80mm fan above, I wouldnt hesitate giving 2,65v - but hey, thats just me...
    Competition ranking;
    2008; AOCM II, Minfeld/Germany #2 @ 01SE/AM3/8M (w. Oliver)
    2009; AMD-OC, Viborg/Denmark #2 @ max freq Gigabyte TweaKING, Paris/France #4 @ 32M/01SE (w. Vanovich)
    2010: Gigabyte P55, Hamburg/Germany #6 @ wprime 1024/SPI 1M (w. THC) AOCM III, Minfeld/Germany #6 @ 01SE/AM3/1M/8M (w. NeoForce)
    Spectating;
    2010; GOOC 2010 Many thanks to Gigabyte!
    May 2007
    like I stated above would it be good for 24/7?:P
    • Corsair HX 620W
    Aussie God
    Feb 2005
    Copenhagen, Denmark
    Yes... For benchies, 2,9-3,15 is quite alright, but only short session...
    Spectating;
    Xtreme Cruncher
    Jul 2005
    London - UK
    I don't generally go above 2.2v.. my ram gets incredibly hot under load even with just 2.2v
    Core 2 Quad Q6600 @ 3GHz . DFI DK P45-T2RS Plus . XFX 9800GT 512MB . 8GB OCZ Blade PC2-9200 . WD6400AAKS AHCI .
    Creative X-Fi XtremeMusic . Hanns.G 28" LCD . Thermalright U120-E . Seasonic S12 600w . Windows 7 Professional E Retail x64 .
    Oct 2006
    Ontario
    My max is 2.3V, any higher and you'll slowly degrade your ram.
    [SIGPIC][/SIGPIC]
    Diablo 3! Who's Excited?
    May 2005
    Boulder, Colorado
    Was running my DDR2-1000 Firestix at 2.1V, DDR2-667 and I still had a stick die, can't tell if the sticks are dying due to volts or manufacturing defects, had a high-CFM 80mm fan keeping them chill.
    Jun 2006
    2.5
    Oct 2006
    California, USA
    If you want to avoid RMAs I wouldn't go over 2.2v, I tried to run my OCZ up to the warranted voltage (2.35v) and it died. Lucky they replaced it. But now I don't run my RAM over 2.2v, and it's been fine so far.
    May 2007
    Richmond (GVA), BC, Canada
    I'd say 2.2v becouse at this voltage the heatsinks are already warm-hot under full load. 2.25v max with active cooling. it's not like you're going to put your ram sticks under full load for 24/7 so under 2.2v-2.25v they should be only feeling warm to touch.
    I've had my ballistix tracers 8500 OCed to DDRII-1165-1175 at only 2.20v and they're only warm to touch WITHOUT active cooling.
    Xtreme Air-Cooled OC System:
    Mobo: Asus Rampage Formula (X38 Edition) Rev 1.03G (BIOS: 0803)
    CPU: C2Q Q6600 "G0" L723A765, VID 1.2625, 3720mhz, FSB 465*8, Vcore: 1.464, Idle/load temp: 31c/64c
    CPU Heatsink: Thermalright Ultra120 Xtreme lapped (2* Scythe S-Flex SFF21F S-FDB 120mm Push-Pull configuration)
    RAM: Kingston HyperX T1 2x2GB PC2-8500 (DDR2-1116)(5-5-5-15-3-52-6-3-8-3-5-4-6-4-6-14-5-1-5-5)(2.264 Vdimm)(Rated @ 2.3v default clock)
    HDD: Western Digital Caviar Black 640GB WD6401AALS-00L3B (AHCI)
    Video Card: XFX 8800GTS 320mb Xtreme, Core 612 Shader 1420 Mem 900 (Stock cooling)
    Sound Card: Auzentech Meridian 7.1 (8788 chipset)
    DVD: Pioneer 212D SATA DVD-RW
    PSU: Corsair HX620W Modular
    Xtreme Air Cooled Case: Antec 900 case | 3*120mm intake | 1*120mm & 1*200mm exhuast
    OS: Vista Ultimate x64 SP1 Build 6001
    Feb 2007
    For 24/7 use, I wouldn't go higher than 2.1v.
    Jun 2006
    Belgium, EU
    even at 2.1 volt the heatspreaders of my Ballistix start to get quite hot so i personally dont run any higher. maybe 2.2/2.25 with a fan. unless you dont care about your rams health
    Desktop
    Intel Wolfdale E5200 @2.9Ghz
    MSI P6N SLI Fi
    Gigabyte Radeon HD4850ZL @ 680/2000
    2GB Crucial BallistiX D9GMH 800 4-4-4-12 1T
    250GB & 400GB Western Digital SATA2
    Sound Blaster Audigy2 ZS
    Enermax Liberty 500W
    Air Cooling (Arctic Freezer 7 Pro)
    Quote Originally Posted by luihed
    I like my rams like I like my women.... naked and tight
    Dec 2005
    Chambana - U.S.A
    Yep... im wondering 24/7 with active cooling... consider this from Eva2000, a self titled memory addict and very thorough reviewer.
    Quote Originally Posted by eva2000 View Post
    i wouldn't even try 2.1v vdimm without active cooling
    http://www.xtremesystems.org/forums/...&postcount=655
    I have gone through 3 sets of sticks at "rated" specs and its quickly becoming apparent that unless my current mobo is killing RAM, that the voltage is too much.... Im getting a new mobo tomorrow and will run my sticks at 2.30v... if they die, I'll RMA and try 2.1v with the active cooling.
    e8400 4.0Ghz Q747A374 - Thermalright Ultima-90 ES - Asus P5K-D (bios 809) - BFG 285 GTX - 4Gb Mushkin Blackline PC8500 - Deck Legend Keyboard - X-fi Platinum w/BeyerDynamic DT-990pro Headset Mod - Silverstone TJ-07 - Antec Quattro 850w - Samsung 275T - OCZ Vertex 120gb + 1TB WD - Windows 7 64bit Pro
    "The data on the MiG is inaccurate..."
    Jun 2006
    TG are rated safe 2.45v ( at least gkx )
    if 2.1~2.2 is the max, theres a lot of suicidal rams around
    using active cooling with 2.3~2.5 i think ( perhaps you are not a luck guy ) it΄ll resist until you change or upgrade
    but maybe im totally wrong, never tested more than 2.4
    May 2007
    ait thnx all for your replys, well I do have a 80mm fan mounted on it, but I will keep that 2.1-2.2v range dont wana risk endin up with a death ram:X
    • Corsair HX 620W
    Jun 2004
    plan3t 3@rth
    Quote Originally Posted by M.Beier View Post
    gotta laff 2.9- 3.1 volts....rofl
    Stacker830 Watercooled
    windows7 ultimate 64 bit!!!
    heatkiller(rev3) on 2500k@ 4.5ghz 1.35v,8 gigs 2133 ripjaws 1.5v
    Swiftech Mcp-655,1/2in tygon,13x120 sunnons on junk ps,
    (2)triple 120mm rads,Biostar TP67XE(rev 5.2)
    150 gig velicraptor (stable drive) ssds r still buggy!!
    xfi-xtrememusic,klipsch ultras, sen hd-595s
    Evga Hydro gtX 590,co0lermaster-1250 watt,
    24" Sony fw-900 black ops at @ 2304x1440 85hz/85fps SOLID
    G@m3r 4 L1Fe!!
    http://s76.photobucket.com/albums/j1...0VIEW%20ALL--/
    3dmark 11 http://3dmark.com/3dm11/1102387
    3D Team Captain Don_Dan's Avatar
    May 2007
    Munich, Germany
    I would also say 2.1-2.2 volts is safe, but, of course, with active cooling on your ram!
    Quote Originally Posted by chew* View Post
    You can never have enough D9's.
  18. #18
    Jun 2004
    I have a max 24/7 voltage range of 2,0 to 2,15v
    With a fan off course
    Gigabyte P35C-DS3--E6600 L628B123--2x1GB Gskill Pc6400HZ+1GB D9GMH OEM--Sapphire x1900XTX--Tagan 580w--GFX Watercooled--Cpu Cooled By Mach2 GT modded by Jort
  19. #19
    Nov 2006
    Jonesboro, AR
    I was wondering the same thing myself....I have some Micron D9GMH chips in my Ballistix DDR2-800s, and I run 2.25V 24/7 @ DDR2-833, but this isn't my max.
    My modules are pretty much room temp to the touch when idling, and I have a hard time feeling any heat when running Orthos blended or HCI Memtest....I have active cooling and excellent case cooling....
    Q6600 G0 @ 3.8 (475x8) 1.496V || ASUS Maximus Formula X38 || 4x2GB Geil Evo One DDR2-950 5-5-5-15 ||
    Sapphire 4870X2 857/1000 || XSPC Delrin full coverage block || MCP655 || D-Tek Fuzion Nozzled ||
    Black Ice 480GTX 8 120mm Yate Loon push/pull || Silverstone DA850 PSU 70A +12V || Auzentech Prelude ||
    Vantage P15071 in Vista x64
