For those of you that missed it in the Abit thread here is another link to the bios.
Rename it from .zip to .B03 or .ROM, this was done to aide some browsers downloading.
http://fugger.netfirms.com/M629B_11.zip
Intel 9990XE @ 5.1Ghz
ASUS Rampage VI Extreme Omega
GTX 2080 ti Galax Hall of Fame
64GB Galax Hall of Fame
Intel Optane
Platimax 1245W
Intel 3175X
Asus Dominus Extreme
GRX 1080ti Galax Hall of Fame
96GB Patriot Steel
Intel Optane 900P RAID
Nice!![]()
RIG 1: Asus Rampage Extreme X48
RIG 2: Foxconn BloodRage X58
E8600 Q820A349 @ 4.75Ghz: http://valid.canardpc.com/show_oc.php?id=596270
links not working...
Tested twice, it works.
Intel Optane
Platimax 1245W
Intel 3175X
96GB Patriot Steel
It works here![]()
RIP GrandDad , I'll miss you-15/07/1985
RIP GrandMother, I'll miss you-08/08/2007
Dave is the man!
I don't have the board so I should have kept my mouth shut.... D'oh![]()
but the ip35 is award bios... not ami
also now hosted at abit-USA forums
this file is a zip & needs extracting
abit IP35 Pro, E6600, HD3870, FSP FX700-GLN
abit AB9 QuadGT, E6400, 7900GTO, FSP FX600-GLN
abit AX78 x2
Asus P5N-E SLI, E6600, 8800GTS, Tagan 530W
jesus people just delete the .zip from the file name and flash your board, how hard is it
its not a zip file.
.zip was added as some browsers may alter the file or reject it
"These are the rules. Everybody fights, nobody quits. If you don't do your job I'll kill you myself.
Welcome to the Roughnecks"
"Anytime you think I'm being too rough, anytime you think I'm being too tough, anytime you miss-your-mommy, QUIT!
You sign your 1248, you get your gear, and you take a stroll down washout lane. Do you get me?"
Heat Ebay Feedback
nice..I hope my friend got this..
Asus P5W64 WS Professional , DFI Infinity 965P-S (testing)
X6800, E6750 es
Micron Fatbodies , Micron D9gkx oem, Crucial 8000, Crucial Tracer 8500 (incomming)![]()
Ati FireGL V5100, Elsa FireGL V3100![]()
water cooling setup (EK 775 cpu block, swiftech NB Block, Swiftech pump, BI dual pass dual 120mm)![]()
Silverstone OP650![]()
raptors, baracuda![]()
how do you people flash?
ASUS P5K-E // E8400 Q746A519
G.Skill F2-8000CL5D-4GBPQ
LC 550W GP// XPERTVISION 9600GT
first uncompress the M629B_11.zip
i found a ROM file is "M629B_11.B03
NO need to change file name, using winflash and it works well
New beta bios available today.
http://fugger.netfirms.com/11B04.zip
Test at your own risk
Intel Optane
Platimax 1245W
Intel 3175X
96GB Patriot Steel
DO sata dvd drives disappear from the bios with this one?
Asus P6T6 Revolution/Core i7 965EE
Vista Ultimate 64bit
BFG GTX295
6x2gig OCZ Platinum DDR3-1600
Samsung SH-S223Q
2 640gig WD's in raid 0
Areca ARC-1210
Auzentech X-FI Forte/Z-5500's
Corsair 1000w psu
Will this bios work on the non pro version of the IP35 ?
ABIT IP35 LGA on the way
e6400
Ballistix 2x1gb or Patriot 2x1gb
XFX 7900gs
Seagate 320gb sata
Sony NEC Optiarc DVD burner
3.5 floppy
OCZGXS600 PSU
Swiftech Apogee GT/MCR220/MCP600
Ubutnu 7.04 / Vista
No, the IP35-E & IP35 share 1 BIOS & the Pro has it's own.
abit AX78 x2
