Yes, as i promise to you, i start my case modification.I wanna make an extreme Silverstone TJ 07 case. Main part is this modification, not so much hard modding especially soft and visual mod.![]()
Today, i demontage case :
Here is the empty case. All parts are free now.
First, i will paint black, Zalman fan controller for getting suitable with case.i use dark black for painting panel.![]()
for demontage panel, i open screws.
For a smooth surface and making good paint and removing texts, i emery with 600 water emery.
After a good work, we paint surface with a spray paint. Here is the result.
Update:
Making a suitable exhaust fans, i paint them. I use dark red and shiny polisher.
Here is our fans :
After Painting :
Then i montage fans in case :
Angle View :
And finally…
I finish painting. This paint named “ Fiat Fire Red”, i use 600gr paint, for 4-5 time without shiny polish and undercoat.Making mirror effect so hard but i made it haha. Now im waiting for inside parts. I will continue modding..
Will be continue![]()
