Yes I've gotten off my lazy butt... well partially off anyway![]()
Time to dust off my Kayl Black FrozenSS 1/4HP phase change unit for some sub zero action. It's a real winter this year so hopefully lower room ambients with lower humidity and dew point temps will keep condensation to a minimum
Asus Commando getting treated:
This time decided against using red Liquid Electrical tape as it's too messy to clean up for when i revert to water cooling.
Instead I've gone for a different approach:
Now here's where I'm stuck, trying to cut out a perfect closed cell foam piece to fit over the top of the Vinyl tape. I've only done this twice before for AMD64 DFI NF4 board and for Asus P5W DH and both times the foam piece didn't fit as well as I hoped for.
- First, 3 layer coating of Electrolube Clear Protective Lacquer (CPL) (rated for -50C) on backside of motherboard and front (taped off the dimm slots, PCI/PCI-E slots, cpu socket and IDE/FDD connectors).
- Then using clear nail polish for around cpu socket area sealing off under the cpu socket and caps and up to first dimm slot.
- Instead of Liquid Electrical tape, using 3M Scotch Super 88 Vinyl tape for the initial covering layer of the board. Should be much easier to remove afterwards right ???? Or would heat from components eventual cause the Vinyl tape to melt and become sticky and thus hard to remove ??? The 3M Scotch Super 88 Vinyl tape is rated for -18C to 105C.
Then I'm going to cake the entire cpu socket in dielectric grease this time. Learnt my lesson from last time
I'm thinking of further closing off the top closed cell foam piece with another layer of 3M Scotch Super 88 Vinyl tape and to seal around the evap foam with the tape as well.
Questions:
- So guys any tips on how to carve out a perfect fitting piece of closed cell foam for the layer on top of the Vinyl tape ??
- Is the Vinyl tape approach alright ? Is covering the cpu socket are components in Vinyl tape going to okay ?? Or am I trapping alot of heat there ?
