Hi,
Anyone know if this is a G0 stepping chip? I have the option to buy one.
QXUZ ES Malay, 80562PH0678MK, L712A585
Cheers
Hi,
Cheers
ZR30W | 800D | 2600K | MIVE | 580 HydroGen | X25-160 | Aquaero
good news for u
please post ur results when u get it
Soon to be :
ASUS P8P67 Deluxe, Intel SB i7-2600k, G.Skill Rj-X F3-12800CL6D-4GBXH, MSI HD6950 2GB, Corsair 750AX, Intel 80GB G2 SSD, DELL U2410
Used to be: SaFrOuT
nice scores
can u please report the systems specs and the vcore used ?
EDIT:
system specs in the screenshots![]()
Soon to be :
Used to be: SaFrOuT
Well I missed the boat on that chip because I was unsure
Good news is there will be another option to buy one hopefully from the same batch within the next week.
Looks a nice chip. What temps are you getting at 3.6 mate? Idle & Load
Looking at the asus probe 2 27c in idle and 50c in full but...2 things.
I am using right now ac in my room (at this time in my country the temps begin to be really hot) and the asus probe, as always, lies, put it about 10c more in idle and 10-15c more in full (with a Tuniq Tower 120).
I like to try with coretemp but everytime i click on it the system crashes and reset.
which version are u using ? 0.94 or 0.95
Soon to be :
Used to be: SaFrOuT
ya 0.94 works perfectly while 0.95 is very buggy
but it is weird that it is not reporting it correctly
Soon to be :
Used to be: SaFrOuT
nice chip you have
I have few similar things coming
retired computer enthusiast
Mojo
Family
Biostar TP55 XE - Core i7 860(ES) @ 4.2ghz - CNPS10X Extreme - G.SKILL 1600 - Galaxy GTX275 - Velociraptor 300GB x 2 - Zippy TypeR 600w
Criminal
Biostar Tpower X58A - 920~Gulf - G.SKILL2000CL8 - GTX580 - Intel 520 120GB - Antec HCP 1200w
Biostar TP67XE/TZ77XE4 2500k~3770K - G.SKILL 2800 - GTX480 - OCZ Vertex2 50GB - Corsair AX1200
Biostar Tpower X79 i7 3820 ~ E5 2680 - G.SKILL 2400C11 - GTX560Ti - Intel 520 120GB - AX1200i
Kids
P4GD1 - Pentium M 780 - XMS Xpert400 - GTX460 - Raptor 36GB - Aopen 560w
Quick question about the GO stepping:
Will the $266 Q6600 quads be available with such stepping, or is that reserved to the Xtreme parts?
Antec P180 SILVER
Asus P8P67 Deluxe Bios 1602
Intel Core I7 2600K @ 4.8ghz 1.295V Manual 24/7
Thermalright Ultra 120 Extreme
OCZ 700W PSU
4X2GB Corsair Vengeance DDR3 1600mhz
Seagate 1TB Samsung 1TB (X3)
MSI Radeon HD 5850
WINDOWS 7 PRO X64
There will be G0 Q6600, dont remember were i saw but some guy here in XS has ordered a few (ES i supose).
Yeah thats true. I have a Q6600 B3 and is much hotter than this QX G0.Originally Posted by PcCI2iminal
BTW, i tought that i should have the multiplier unlocked upwards but the max i can put is 10 (P5K DLX 0311 bios), is that normal or is a matter of bios/mobo?
ur answer is below
http://www.tankguys.biz/product_info...oducts_id=1712
Soon to be :
Used to be: SaFrOuT
its Q6700 G0 no ? coef max 10 ?
QXuZ G0 on QX6700 is much better then B3 stepping,
better overclocker.
QX6700/QX6850 unlocked up/down anyways so why pay the premium on an
QX6850 G0 when 6700 G0 just as good for cheaper.....![]()
Antec P180 SILVER
OCZ 700W PSU
MSI Radeon HD 5850
WINDOWS 7 PRO X64
The same Cpu but family Xéon![]()
WOW 1066 FSB G0 stepping![]()
i wonder if they are going to have E6700 CPUs in G0 stepping
How can you tell if its a G0 stepping w/ the Stepping/Box/IHS?
CPU : E8400
Motherboard : Abit IP-35 Pro
Memory : GSkill DDR2-800 2GBHZ @ 1:1 445 4-4-4-12
Graphics Card : Palit HD4870 Dual Sonic
Display : Dell E228WFP
Storage & OS : 1TB | Windows 7 64bit
Sound Card & Speakers/Headphones : X-Fi Platinum (HotRod) > Zero DAC > BeyerDynamic DT990 Pro
Peripherals : Razer ProType Keyboard | Steelseries Ikari Optical | Razer Goliathus Speed.
Case : Coolermaster ATCS 840
PSU : OCZ GamerXtreme 700W
Run CPU-Z
Antec P180 SILVER
OCZ 700W PSU
MSI Radeon HD 5850
WINDOWS 7 PRO X64
^^ I know that... I was asking, if theres any way to tell from a Box/CPU IHS.
CPU : E8400
