Results 1 to 7 of 7
Thread: Antec P182 fan configuration
    Oct 2005
    Unhappy Antec P182 fan configuration
    hi everyone, would like some advise on cooling configuration for an antec p182 casing, which i am intending to purchase.
    i'm intending to remove the tri-cool fans that come as standard on the case to Scythe S-Flexes (or Minebea if I'm going for a high-speed fan option).
    currently running a C2D E6600 @ 3.6GHz with ultra-120 extreme & thermaltake silentcat 120mm. and i have a single 8800GTX installed as well.
    attached is an image of what i intend to do. i'll remove the top exhaust, but i don't know if i should add a low speed fan to blow in from the top in place of the stock tricool which exhausts up. any suggestions?
    all outta gum
    Dec 2006
    Poland
    The top fan should suck the air out of course. Hot air travels up.
    www.teampclab.pl
    MOA 2009 Poland #2, AMD Black Ops 2010, MOA 2011 Poland #1, MOA 2011 EMEA #12
    Test bench: empty
    Xtreme Cruncher
    Sep 2006
    Lancaster, UK
    You want to keep a negative pressure within the case - so the top fan should be sucking out of the case, therefore it pulls cooling air into the case from other vents.
    Crunching:
    Main Rig: Dual Opty 2536s, SM H8DA8-2, 6gb DDR2 ECC
    Pentium Dual Core E2180 2.0GHz, 2GB PC5400.
    HTPC - Core 2 Duo T7200 @ 1.6, 1GB DDR2, Philips HDTV
    Pentium 4 3.0E @ 3.8GHz, 1GB Ballistix PC4000
    1.0GHz Pentium !!! 384MB PC133
    Apple MacBook Pro 2.4GHz, 4GB 667MHz.
    Pentium D820, 2GB DDR2, 1TB Hard Drive.
    I'm not like you - I won't Overclock the toaster until it can cook a whole Turkey in 15 Seconds
    Oct 2005
    how loud is that case? i was thinking of getting one.
    E6420 @ 3.2gHz
    Asus P5K Deluxe
    2GB OCZ DDR2-1066 Platinum
    Powercolor HD 2900XT
    OCZ 700W Gamexstream
    May 2007
    Quote Originally Posted by trajik78 View Post
    well it is a quiet case but the fans can be changed between 3 settings
    http://www.antec.com/uk/productDetails.php?ProdID=09182
    there is a cool video review there by a well known reviewer.
    Gaming Rig
    Intel E6300
    Intel Mobo
    2 Gig OCZ 800 (800 5,5,5,15)
    Saphire Ati 4870
    22inch LG Flatron W2230S
    May 2007
    as said above all back fans sucking out and all front fans sucking into case to balance the airflow.
    Gaming Rig
    Intel E6300
    Intel Mobo
    Saphire Ati 4870
    Oct 2005
    Recommended to change out the default TriCool? I got a friend with Antec P180 and one of his TriCools failed in less than a year.
    My fear is reliability and cable management.. If I change to Scythe fans, I could use the 3-pin mobo fan headers, and do not need to run extra 4-pin molex cables behind my mobo just to connect the TriCools.
