Page 1 of 3 123 LastLast
Results 1 to 25 of 56
Thread: >> Micron DDR3 / Corsair @ DDR3-1960 CL7-6-5 >> very fast SPi32M runs, 13k Everest <<
Hybrid View
    Xtreme X.I.P.
    Dec 2003
    Cool >> Micron DDR3 / Corsair @ DDR3-1960 CL7-6-5 >> very fast SPi32M runs, 13k Everest <<
    Hey,
    After some consideration, I decided that since we have already seen and proved that Micron 1Gbit parts will do DDR3-2000+ at CL10 or CL9 with better modules, it was time for some fast & tight action. Let me then introduce what DDR3 is capable of in terms of high frequencies at tight latencies, with some good help of good 'ol voltage
    What I have here is a 2x1GB kit of DDR3 Micron-based modules, that happens to be coming from Corsair - yeah, no surprise here this time, right? For those unaware, I work in Corsair's lab, and deal with all kinds of memory/motherboard related testing, validations, overclocking, etc.
    Anyway, fasten your seatbelts because 13k Everest Bandwith is coming real fast. How about we warm up with 2000+ at "slack" timings, and easier 4GHz CPU, shall we? Something worth noting is, that all overclocking was done solely from BIOS and FELIX's latest Memset was used only for those interested what memory settings/timings were used,
    - Asus P5K3 Deluxe, 0504 BIOS
    - Core 2 Duo E6850, 1333FSB
    - Corsair DDR3 modules
    - Corsair HX520 PSU
    - eVGA 8800GTS
    DDR3-2040 8-8-8-18 @ 2.30v, E6850 @ 510x8=4080MHz --- CPU-Z Valid @ 8-8-8 --- CPU-Z Valid @ 8-7-7
    Click for larger version
    Now, let's do that again, but below both 4GHz on CPU and 2GHz on memory
    DDR3-1960 7-6-5-15 @ 2.30v, E6850 @ 490x8=3920MHz
    Next up, rather fast 32M run, isn't it?
    DDR3-1940 7-6-5-15 @ 2.30v, E6850 @ 485x8=3880MHz
    Couple of Sandra XI Professional benchmarks - Buffered Memory Bandwith and Random Latency tests...
    ... and Unbuffered Memory Bandwidth
    Those would make for good and I think first DDR3 entries for coop's "32m Low Clock Challenge" contest
    ... one for 11:xx category - I was so close to do it below 3.90GHz, but memory would just stop at above DDR3-1940. So I had to step down a bit. Still, a very fast run, right?
    DDR3-1660 7-6-5-15 @ 2.00v, E6850 @ 498x8=3884MHz
    ... and one for 12:xx as well. This would make the best result so far, If DDR3 results are to be accepted in that contest.
    DDR3-1700 7-6-5-15 @ 2.00v, E6850 @ 510x7=3570MHz
    While I was at it, I run a quick ORTHOS test at above settings as well.
    DDR3-1703 7-6-5-15 @ 2.00v, E6850 @ 511x7=3577MHz
    So, there you have it guys! There is some even better stuff coming along on DDR3 front as you can see. Let me just point out, that this is in no way presentation of what all Micron DDR3 based modules will do, but just a sample of possibilities out there, for those if you curious to see what happens when more than default 1.5v is applied. But let me say, that 2.3v that I was pushing through these modules DOES NOT seem safe for extended periods of time.
    Thanks for clicking through and see you next time If you have any questions or requests, let me know and I will try come up with something...
    Xtreme Guru
    Jul 2004
    Holy crap! @
    & 11M 58s!!
    I wish i had a ddr3 board to play with.
    Champion
    Nov 2004
    Hungary
    Great tests
    Thanks for sharing
    "We are competing, competing to win. And the main motivation is to compete for victory" - Ayrton Senna
    Xtreme 3DTeam Member
    Aug 2003
    Germany
    That is really fast! Nice results.
    PC : Asrock Z68 Extreme3 Gen3 + Intel Core i5 i2500k + 2 x Asus HD6870 DirectCU + 2x2GB PC12800 G.Skill Eco 7-8-7-24 + Creative X-Fi Titanium PCIe + Scythe Mugen 3.
    Digicam : Pentax *istDL2 + Pentax smc DA 18-55mm F3.5-5.6 AL + Cosina F3.5/100mm Makro.
    Heimkino : Samsung LE-46B450 FullHD + Arion AF-4000HDCI + Onkyo TX-SR505E + Quadral Quintas 5.0 + Heco Victa 25A.
    Wanna look under my kilt?
    Jun 2005
    Glasgow-ish U.K.
    The important question I think needs to be asked is...
    What voltages are currently considered extreme/damaging etc for DDR3, or is it still too early to tell?
    Have the Corsair labs tested module voltages until they fry?
    The MHz, timings and Spi times are impressive
    you sigged that?
    why?
    ______
    Apr 2006
    Cairo
    Nice work BA , really impressive , but i have a questions ,,, Is that is a handpicked or random kit ? those ICs are as hot as D9s or run cooler ?
    Thanks for sharing
    Quote Originally Posted by bachus_anonym View Post
    Is that an answer for my question or you are talking about different Micron ICs
    Jun 2006
    smyrna, TN
    very impressive, makes me want to dump my ddr2, and jump on these
    KiSUS
    Nov 2006
    Russia / Moscow
    I need this ))))))
    Thanks.
    Lights, Music, Camera, Action !
    May 2004
    Sherbrooke, Quebec, Canada
    Under 13minutes Spi 32M at 3570Mhz. Wow!
    Wolfdale e8400es @4.5Ghz / Ultra-120 Extreme
    2GB Ballistix @ 589Mhz 4-4-4-x @ 2.5V - SPI 32M
    *** Motherboards tested: DFI Blood Iron (current), Asus P5K3-dlx, DFI P965-S, P5B-Dlx, DFI RD600, Bad Axe 2, EVGA 680i, DS3 and P5W DH ***
    Fan modded Zippy 850W, 500GB 7200.11 and EVGA 8800GTX @678/1062
    Xtreme X.I.P.
    Dec 2003
    Thanks for good words, guys!
    Quote Originally Posted by K404 View Post
    What voltages are currently considered extreme/damaging etc for DDR3, or is it still too early to tell? Have the Corsair labs tested module voltages until they fry? The MHz, timings and Spi times are impressive
    The voltage I applied in parts of this test (2.3v) does NOT seem safe for prolonged use, and should be definetely reserved only for those that are are aware of a danger that could arise from 50&#37; voltage increase from default 1.50v. On the other hand, I have not seen Micron DDR3 being damaged with up to 2.0-2.1v. But again, early to say, I think. Also, some ICs will benefit from anything higher than 1.8v and some won't.
    Quote Originally Posted by kemo6600 View Post
    Nice work BA , really impressive , but i have a questions ,,, Is that is a handpicked or random kit ? those ICs are as hot as D9s or run cooler?
    Not really handpicked, but consider it a result that may or may not be representative of all Micron DDR3 based modules. That's all I can say at the moment. Plus, it's to early to say as these Micron chips (if you look it up at Micron website) are still technically ES. The above results are intended as an early pre-preview, and be considered as such.
    Xtremely Bad Overclocker
    Jan 2005
    East Blue
    that's what I've waited for since release of DDR3 - nice ddr3 timings on sweet mhz - thanks for the detailed results
    | '12 IvyBridge - "ticks different"... | AwardFabrik IvyBridge round I by SoF | AwardFabrik IvyBridge round II by angoholic & stummerwinter
    | '11 The SandyBridge madness... | AwardFabrik / Team LDK OC-Season 2011/2012 Opening Event
    | '10 Gulftown LaunchDay OC round up @ASUS RIIE | 3DM05 2x GPU WR LIVE @Cebit 2010 @ASUS MIIIE | SandyBridge arrived @ASUS P8P67
    | '09 Foxconn Avenger | E8600 | Foxconn A79A-S | Phenom II 940 BE | LaunchDay Phenom II OC round up
    | '08 7.438s 1m LN2 | AMD 1m WR LN2 | 2nd AOCM | Phenom II teasing
    | '07 100% E2140 | 106.5% E2160 | 100% E4500 | 103% E4400 | 5508 MHZ E6850 | 7250 MHZ P4 641 126.5% by SoF and AwardFabrik Crew all on Gigabyte DS3P c? and LN2...
    | '06 3800+ X2 Manchester 0531TPEW noHS 3201MHZ c? | 3200+ Venice noHS 3279MHZ c? | Opteron 148 0536CABYE 3405MHZ c? all on Gigabyte K8NXP-SLI compressorcooled
    | '05 3500+[NC], 3000+[W], 2x 3200+[W], 3500+[NC], 3200+[V] 0516GPDW
    Quote Originally Posted by saaya
    sof pulled a fermi on all of us !!!
    Xtremely Addicted
    Dec 2004
    NL
    Insane 32M for the clocks and glad to see tests from you again
    Team KOC2.com
    Nov 2005
    Indonesia
    OMG 3570mhz sub13 were just amazing..... great memory, great tweaks, great ocer.... very cool...
    E8600 Q820A750
    DFI LanParty UT P35-T2R - Abit IX38 QuadGT - Asus P5B Deluxe - Biostar TP45 HP
    Team Xtreem PC-5300 C3 2GB - Crucial 10th Anniversary 2GB - Team Xtreem PC8500 C5 2GB
    Winfast 8600GT
    Silverstone Olympia 1000w
    andre X_X -72c CO2 Cascade
    My R22/CO2 Cascade Project
    Xtreme Legend
    Mar 2005
    Australia
    hey BA i was waiting for this thread
    crazy ICs
    so much for someone saying the other day DDR3 die instantly at 2.3v lol
    Team.AU
    Got tube?
    GIGABYTE Australia
    Xtreme X.I.P.
    Aug 2004
    Chile
    lol i might have a picture of you Bachus, i took some pics of corsair tech lab :P
    Corsair Rep
    Nov 2005
    Quote Originally Posted by metro.cl View Post
    He's the guy with the shaved head whose lab table has like $50,000 in memory on it at any given moment!
    Xtreme X.I.P.
    Aug 2004
    Chile
    Quote Originally Posted by Redbeard View Post
    Hey havent seen you here nice to know corsair is here
    I'll have to look at the picture to see if Bachus is in there
    p.d. i found him (had to cut the picture couse of nda:
    and you also had lots of toys to play:
  18. #18
    Xtreme X.I.P.
    Dec 2003
    I think I remember you were on a tour with a bunch of other guys from South-America.
    That's probably correct...
    I'll have to look at the picture to see if Bachus is in there. p.d. i found him (had to cut the picture couse of nda:
    Yup, that's me
    Quote Originally Posted by Gautam View Post
    Very very fast results bachus...but I've got a feeling that DDR2 properly tweaked with P35 can match those. Anyways its about time someone made the new tech look...new.
    I might be wrong, but out of those three 32M runs above, 12:02 @ 3.88GHz might be the hardest to match with DDR2, even on MCH register tweaked up P35. Time will tell, of course.
    Quote Originally Posted by eva2000 View Post
    Yeah DDR2 properly tweaked on P35 could do it or get close, but very fast stuff Bachus especially 10k everest copy bandwidth.. that's what stuck out at me.. 13k read too Obviously higher cpu FSB helps with such bandwidth too
    Thanks George! Yeah, 13k Read and 10k Copy should be out of reach on curent C2D DDR2 platform, at this CPU speed that is (3920Mhz). I was messing with P5KD, and Striker Extreme, and did not see 12k+ happenning...
    I'm a bit busy at work right now, but I will make another shot at 11:xx below 3900MHz. Those 3s were driving me crazy, and still could not loose it... Only tweaks I used at that time was maxmem=600 (which seems to be a bit overrated, from what I have seen during that test) and copywaza (which shaved about 5-7s of each of those 32M runs, compared to "untweaked".
    Thanks again
  19. #19
    Memory Addict
    Aug 2002
    Brisbane, Australia
    Time will tell, of course.Thanks George! Yeah, 13k Read and 10k Copy should be out of reach on curent C2D DDR2 platform, at this CPU speed that is (3920Mhz). I was messing with P5KD, and Striker Extreme, and did not see 12k+ happenning...
    i'll see what i can do.. only 1:1 on DDR2 so have yet to play with mem divider
  20. #20
    Jan 2003
    I think its very possible.... Send me 5x Dominator pc2 8888 and 5x Dominator pc2 6400 c3df and ill give it a try...... Ill return them ... promise hehe...
    E8400 DFI LP P35T2R Ballistix
    8800GTS PCP&C 1.2kw Raptors
    E6600 =5400mhz
    E6700=5680mhz
    QX9650= 6000mhz
  21. #21
    Admin
    Dec 2003
    Hillsboro, OR
  22. #22
    Memory Addict
    Aug 2002
    Brisbane, Australia
  23. #23
    May 2006
    Philippines ^_^
    very nice BA
    DDR3 is looking good.. I hope there are more memory players here unlike DDR2 that is mostly micron..
    where is samsung or hynix??
    looking forward for more of your test..
    btw.. BA.. can you test using 1066 conroe's any E6600 retail there in your lab..
    Asus P5W64 WS Professional , DFI Infinity 965P-S (testing)
    X6800 , E6750 es
    Micron Fatbodies , Micron D9gkx oem, Crucial 8000, Crucial Tracer 8500 (incomming)
    Ati FireGL V5100, Elsa FireGL V3100
    water cooling setup (EK 775 cpu block, swiftech NB Block, Swiftech pump, BI dual pass dual 120mm)
    Silverstone OP650
    raptors, baracuda
  24. #24
    I am Xtreme
    Aug 2003
    Good stuff B_A DDR3 looks good for once! Hopefully prices will come down soon.
    Those 32m times are damn fast. That 3880mhz run is only 1 second slower than my 4.45ghz run on p5b Ah the raw power of 1333 strap + no 32m tweak knowledge.
    Phenom II 940 BE / ASUS M4A79 / HD5770 Crossfire
    3770mhz CPU 2600mhz NB | DDR1040 5-5-5-15 | 900/1250
  25. #25
    Nov 2005
    Porto, Portugal
    On Asus ftpserver there's a 0501 bios for P5K3 Deluxe, but no 0504...
    ftp://ftp.asus.com.tw/pub/asus/mb/so...P5K3%20Deluxe/
    Windows 7 Ultimate 64bit, SP1 Power By:
    Asus Rampage IV Formula
    Intel SBE 3930K
    Gskill RipJaws Z 14900 (1866 DDR3) 16GB 10-11-10-24
    EVGA 570 GTX SLI
    SSD Samsung P830 240GB
    Corsair AX850
