Page 1 of 3 123 LastLast
Results 1 to 25 of 74
Thread: Universal abit IP35 PRO Review
    Sep 2003
    Edinburgh - UK
    Intel has once again lifted the performance bar with the introduction of the P35 chipset bringing with it native support for 1333FSB based cpu's like Yorkfield and Penryn.
    Universal abit has released their gauntlet of P35 boards the IP35, IP35-E and the board being reviewed here, the IP35 PRO.
    The PRO as the name suggest is the top end of the P35 range of boards available from abit, tricked out with a number of nice features:
    • 100% Japanese solid state capacitors
    • uGuru Interface
    • Full RAID0/1/5/10 ACHI via Intel Matrix Storage Technology
    • Full heatpipe/heatsink coverage for PWM northbridge and southbridge
    • External CMOS clearing switch
    • Dual Gigabyte LAN
    • Onboard power, reset and debug code readout
    • HDMI header (for audio)
    • 2 x eSATA
    For full listing please click here
    But enough of the details let’s get down to business:
    First Impressions
    The packaging is reminiscent of the AB9 series of motherboards and its last incarnation the QuadGT. The IP35-PRO and QuadGT share some similarities too. Looking at the two boards side by side is it evident that alot of the PCB placement has been carried over, one big exception is the PWM which had made a return to analogue (which will no doubt please some folk). The IP35 PRO has also gained a PCI slot and second LAN socket, albeit at the expense of an onboard mounted firewire connector.
    In the box we find the usual assortment of cables, I/O shield drivers and manuals. I was a bit perplexed to find an absence of a RAID disk, it would seem that you have to create your own from the driver CD - though this can be down from boot and won't require a previous installation of windows or PhD to get working.
    A closer look at the boards reveals a few other important chips:
    This is the "new" PWM controller chip the Richtek RT8802A which is also on the AB9 boards. The power delivery is a 4 phase design, interesting as the AB9 was a 5 phase design.
    This chip is the Analog Devices AD8402 2-Channel digital potentiometer, those on you with a keen eye will be able to see that is it situated near a bank of resistors at the cpu socket. It's purpose is to allow "on the fly" adjustment of GTL level voltages which can significantly improve FSB overclocking especially on Quadcore cpus. For more reading on this I recommend reading this article by Freecableguy over at thetechrepository.
    Other areas of the board are the same as the QuadGT - the MCH (northbridge) is fed via a PWM power circuit as is the DDR2 while the southbridge is a linear design. VTT is supplied via the MCH power supply and in the BIOS you will find that the available VTT will rise with increased MCH voltage.
    One final touch that is lost on many other competitors’ boards is the fan headers on this and other recent abit boards are supplied via power MOSFETs. This means that you can directly attach high power fans like deltas directly to the motherboard without fear of blowing the header, very handy indeed especially if your doing water cooling - you would be able to control not only the fans but the pump as well via uGuru, a nice touch indeed!
    BIOS
    uGuru reappears as the main hub of overclocking on the board. While their are those who aren’t too keen on the idea that only uGuru is able to adjust clockspeeds ( I myself have found it troublesome especially on the QuadGT) Looking at the program as a whole it is an amazing piece of software. You are given full control over and monitor all voltages, fan headers and clockspeeds all from one program - with the ability to create profiles accordingly. In the BIOS we find a good spread of available voltages as shown below. The memory divider has proven to be a bit confusing for some so here's a table of the various dividers and straps:
    1333 - 1:1 | 1:1.2
    1066 - 1:1.25 | 1:1.5
    800 - 1:2 | 1:1.66
    This is from another forum so I've yet to confirm it all. You will also notice the addition of the GTL voltage levels given in %. 67% seems to be quite good for most people so is a good starting place, don't make rash adjustments here as you can quickly loose stability at higher FSB speeds.
    Also an interesting point to note is that the 12v 4/8pin connector for the PWM and the 12v line for the 24pin connector are now independently monitored in uGuru, useful if you want to see if your PSU supply for the cpu is drooping badly under load.
    Moving onto the chipset configuration it should be noted that the CAS has been limited to 4, 5 and 6. As of yet no reason has been given as to why CAS3 isn't available but apparently it is in the works for the next BIOS update. Also abit have opened up the sub timings with this board which is a Godsend for all the memory nuts out there.
    System Setup
    CPU - x6800
    HSF - Thermalright ultra-120 Extreme and Intel stock
    Memory - Cellshock PC2-8000 4-4-4
    VGA - Radeon 7000 PCI and Nvidia 8800GTX
    Raptor 36GB Samsung DVD-combo PS/2 mouse keyboard
    Initial Observations
    Voltage readings (as always) are a little off from those reported via BIOS/uGuru the table below is a guide only and may be representative for your chosen cpu voltage levels.
    Notice that the droop under load for an x6800 is 0.005volts, impressive enough. The MCH seems to be more strained under load swinging up by 0.012volts which has the knock on effect of swinging the VTT voltage - 0.017volts. VDDR is fairly stable dropping only 0.02 volts under load.
    The PWM is also quite cool running with temperatures rarely topping 50oC under all testing. This is without any directed active cooling as the fan for the Thermaltake ultra 120 wasn't not direct path of the PWM heatsink. More surprising was the coolness the MCH heatsink ran at, even under higher voltages. My initial fear was a poor thermal contact but even after applying paste in lieu of the thermal pad the temperatures were still in the 30s-40s.
    The onboard IDE and eSATA is provided via the JMicron JMB363 chipset. This has gotten its fair share of flak over the last year, some of it well deserved. I found with my testing both using an IDE drive and a CD-combo drive that it was fully functional and detected the drives correctly. HDTach showed that the IDE drive had sub performance compared to a native connection but this is to be expected, as I doubt anyone will be running their OS off this chipset. CD drive performance was roughly on par with that of a native connection. The eSATA performance was not checked due to lack of compatible hardware.
    However not everything was sunshine and roses. The CD-combo drive that I normally use has a PATA interface, and with the advent of none IDE spec’ed boards I decided to purchase a PATA-2-SATA adaptor to allow it to connect via SATA. This has never proven to be a problem until now. On multiple occasions the computer would hang at the "scanning for SATA devices" and it quickly became apparent that the CD-Combo drive was to blame. I've yet to confirm this problem is widespread or an isolated case, but it seems to be eased somewhat by connecting it to the odd numbered ports (I currently run HDD on SATA1 and CD-combo on SATA3). However be aware that "high" FSB speeds (500MHz+) seem to increase the chances of it occurring as well.
    Another oddity that I came across was a curious memory incompatibility. I have used two different sets of RAM when testing this board, my old trusty Crucial 10th anniversary sticks (Micron D9GMH) and my newer Cellshock PC2-8000 4-4-4 sticks (Micron D9GKX). Strangely the Cellshocks don't seem to be quite at home with this board. Rated to run at 500MHz 4-4-4-12, the sticks would hang at the post at these rated speeds. Conversely the Crucial sticks had no problem and run stably. I will have to wait until others with Cellshock memory and this board can run comparative tests to see if it is just my memory or a problem with the board.
    Results
    No doubt many of you will have read other reviews of this board and seem impressive FSB speeds reached with 550FSB+ being achieved. Unfortunately I cannot boast the same sort of results as it would appear the x6800 I have is somewhat FSB limited, peaking at 510MHz. Putting it under phase improved this score somewhat to 530MHz but nothing noteworthy. I hope to get a hold of another cpu to try again and maybe pull some bigger numbers.
    Firstly the maximum FSB for this cpu on air:
    LINK
    Dropping the FSB down a little to 500MHz and run a few memory benchies. Firstly some stability at 500MHz 4-4-4-12 timings:
    Now some stability testing with 4BG of RAM. This is kind of inaccurate as XP can only see 3GB of the memory but the IP35 PRO is able to handle it with ease. It would seem that the memory controller is quite robust on the P35:
    Stepping things up a notch now we run the memory (Cellshock) at the tightest timings allowed in the BIOS. I've included both memory benchmarks and stability testing:
    Changing the memory dividers we are able to ratchet up to 400:600 fully stable:
    Strapping in the 8800GTX and running on the tightest timings I was able to get a 3DMark01 score of 66444, not too shabby for a card running at stock:
    Having spent little over 5 days with this board I must say I've been impressed with its stability. I was always annoyed by the QuadGTs inability to apply saved BIOS profiles correctly regularly hanging on reboot. The IP35 PRO has yet to suffer the same fate, and is remarkably resilient when overclocked too far. Usually simply turning the power off and back on will allow the board to load the previous "good" configuration.
    Apart from the problems with the disappearing CD drive and the Cellshock incompatibility I have been impressed with the performance stability and features of the board. Over the following weeks I hope to delve into the heart of the board a little more and see how to really get the most from it. Expect vmods to follow shortly
    John
    Jun 2005
    Oregon , USA
    WOW the layout on that board looks awesome !!!!!
    Plus the solid state caps rock.
    FOLD for XS WCG ; or Rodzilla kills a kitten
    Xtreme Cruncher
    Jun 2006
    Iowa State
    Great review! I'm interested in some more tests when you get a different cpu to get that fsb higher
    Thanks!
    May 2005
    Italy
    Great job Johnny
    your technical comments are very nice
    Apr 2007
    USA
    edit -srry for that- your review rocks
    Abit IP35-Pro
    C2D E6400 29B @ 3.6GHz
    TR Ultra Xtreme HS 2x120mm
    4x1GB Ballistix 6400 @ 1080MHz 1:1.2
    3xSammy 500GB SATA-II Raid0/Raid5
    Nvidia 8600GTS 750/1200 <=Soon to be hand-me-down for FamPC
    Jan 2007
    J,
    Can the 8800GTX fit when the firewire cables are plugged in to the motherboard headers?
    xtreme energy
    Oct 2004
    Europe, Latvia
    As Cellshock owner I can advise setting all/almost all subtimings as well I had minor problems with p35 ds3r too if I didn't set them
    Champion
    Mar 2005
    Warsaw, Poland
    Please show me how memory clocks on this motherboard. Max Memory MHz
    MSI MOA 2009 POLAND #3
    Gigabyte GOOC 2010 POLAND #2
    MSI MOA 2010 POLAND - NOT ORGANISED
    ASUS Polish Overclocking Championship 2010 #1
    MSI MOA 2011 POLAND - NOT INVITED
    HWBOT Country Cup 2011 - POLAND! #1
    MSI MOA 2012 EMEA - #1
    MSI MOA 2012 WW FINALS - #7
    ASUS Open Overclocking Cup AOOC 2012 - #1
    HWBOT Country Cup 2012 - POLAND! #2
    MSI MOA 2013 EMEA Qualifier - #2
    ASUS Open Overclocking Cup AOOC 2013 - #?
    MSI MOA 2013 WW FINALS - #?
    Egyptian OverClocker
    Mar 2005
    Cairo, Egypt
    515 si not good enough for a 35 based mobo imho
    Soon to be :
    ASUS P8P67 Deluxe, Intel SB i7-2600k, G.Skill Rj-X F3-12800CL6D-4GBXH, MSI HD6950 2GB, Corsair 750AX, Intel 80GB G2 SSD, DELL U2410
    Used to be: SaFrOuT
    Sep 2006
    Grimsby, UK
    Top notch review! I have a question for you in regards to those Cellshock PC2-8000 4-4-4-12's, was you able to boot up with them on the default bios setting vdimm of 1.8v or did you have to use your Crucials & swap over once the vdimm was raised?
    i5 2500K @ 4.9GHz MSI Z77 MPower G.Skill Trident 8GB 2400C10
    EVGA GTX 1070 SC 8GB @ 1784/4004MHz Corsair HX 750 PSU
    Samsung 830 256GB Creative ZxR Thermalright Silver Arrow
    NEC 24WMGX3 24" TFT Fractal Design Define S Win 7/10 64bit
    Mar 2007
    Killadelphia
    Nice review, definitely a keeper.
    CPU: INTEL Q9550 E0 @ 3600 1.28V + CORSAIR H50
    GPU: EVGA GTX 480 @ 725/1450/3800
    PPU: EVGA 9800GTX @ 738/1836/2250
    MB: ASUS P5E X38
    RAM: MUSHKIN 2X2GB
    SOUND: X-FI TITANIUM FATAL1TY | LOGITECH Z-5500 | LOGITECH G35
    HDD: WD 76GB X 2 RAPTORS RAID 0 10KRPM | WD 1TB CAVIAR BLACK 32MB STORAGE
    PSU: CORSAIR HX1000W PSU
    OS: WINDOWS 7 PRO X64 OS
    MON: HANNSPREE 28" 1920X1200 RESOLUTION
    Aug 2004
    Scotland
    Quote Originally Posted by atlr View Post
    J,
    don't know about 8800GTX but an X2900XT can
    abit IP35 Pro, E6600, HD3870, FSP FX700-GLN
    abit AB9 QuadGT, E6400, 7900GTO, FSP FX600-GLN
    abit AX78 x2
    Asus P5N-E SLI, E6600, 8800GTS, Tagan 530W
    Feb 2005
    OZtralia
    A 'cut above the rest' review
    Thanks Johnny Bravo
    lots and lots of cores and lots and lots of tuners,HTPC's boards,cases,HDD's,vga's,DDR1&2&3 etc etc all powered by Corsair PSU's
    Sep 2003
    Edinburgh - UK
    J,
    Yep clearence is fine mate!
    Sep 2003
    Edinburgh - UK
    Quote Originally Posted by mcflurry4321 View Post
    Thanks!
    I’m planning to get one or two cpus off some friends to see if I can’t get it higher
    Quote Originally Posted by SaFrOuT View Post
    SaFrOuT I doubt it’s the board as I said before I feel the cpu may be the limiting factor, there are various folk out there that have got 550MHz+ out of it.
    Quote Originally Posted by Nelly View Post
    Hey Nelly, the Cellshocks were able to boot from stock volts (1.8v) so I’m hoping the problem of peoples RAM not working will be a thing of the past.
    Quote Originally Posted by kiwi View Post
    Cheers Kiwi I’ll give it a try and see if it works
    Champion
    Mar 2005
    Warsaw, Poland
    And please show me absolute max of RAM frequency on this mobo
    Sep 2003
    Edinburgh - UK
    Quote Originally Posted by Miravo View Post
    I'll get right on it Miravo
  18. #18
    Mar 2005
    Cairo, Egypt
    Quote Originally Posted by Johnny Bravo View Post
    ic, thanks for the info
    i really hope Abit can join teh competition in the overclockers market
    Soon to be :
    Used to be: SaFrOuT
  19. #19
    Champion
    Mar 2005
    Warsaw, Poland
    thanks a lot!
  20. #20
    Xtreme Legend
    Mar 2005
    Australia
    nice one Johnny
    keep it up
    Team.AU
    Got tube?
    GIGABYTE Australia
  21. #21
    Xtreme Mentor
    Oct 2004
    SLOVENIJA
    anyone make ABIT IP35-E review?
    ASUS P5K-E // E8400 Q746A519
    G.Skill F2-8000CL5D-4GBPQ
    LC 550W GP// XPERTVISION 9600GT
  22. #22
    Jan 2003
    So far I think its a nice board but unfortunately it looks like setfsb will not work for this board.....
    E8400 DFI LP P35T2R Ballistix
    8800GTS PCP&C 1.2kw Raptors
    E6600 =5400mhz
    E6700=5680mhz
    QX9650= 6000mhz
  23. #23
    Xtreme Guru
    Jun 2006
    Finland, joensuu
    excellent review Johnny i really enjoyed reading it..
    too bad that the overclocking results (fsb results) was not as good at it might of been, considering what kind of results other manufacturers have made with there mobos.. but then again it might be the cpu and not the board thats holding you back..
    Evga X58 sli under cascade
    http://www.xtremesystems.org/forums/...d.php?t=219788
    Evga X58 Sli ultimate overclocking/ overview/ discussion thread
    http://www.xtremesystems.org/forums/...d.php?t=221082
    proud owner of E8600 Q822A435
  24. #24
    Jul 2006
    Haverhill, MA
    Johnny try finding the max fsb while using the new memset 3.3 beta 2. Try increasing the performance level to see if you can hit higher FSBs.
    E6400 L624A768 @ 3600mhz 1.48V
    Biostar TP35D2-A7
    2x1GB Micron D9JKH, 2x1GB OCZ Gold DDR2-1100
    1x250GB WD SATAII 2x120GB Maxtor IDE 1x200GB
    EVGA 8800GTS 512MB stock 799/1998/2075
    MCW350, Apogee, 120.1 Swiftech Rad
    Antec Smartpower 500W
    BenQ DVDrw
    Logitech z-5300e
  25. #25
    Xtreme Mentor
    Apr 2007
    Idaho
    Nice Abit seems be really stepping up to provide good mobos
    "To exist in this vast universe for a speck of time is the great gift of life. Our tiny sliver of time is our gift of life. It is our only life. The universe will go on, indifferent to our brief existence, but while we are here we touch not just part of that vastness, but also the lives around us. Life is the gift each of us has been given. Each life is our own and no one else's. It is precious beyond all counting. It is the greatest value we have. Cherish it for what it truly is."
