Heyas,
My Abit Fatal1ty F-I90HD just pooped out a few days ago and I replaced it with the most excellent GIGABYTE GA-G33M-DS2R! Athough I’ve run into a few minor problems. I use to have the OCZ Blue LED Ram cooler attached to my 4 Gigs of RAM, but it no longer fits, because the Video cards sits less than 2mm (or less) from the clips that hold the RAM in place on the Mobo. I had to remove one of the clips, because the 8800GTS KO back heatsink won’t sit right with it there. Oh well nothing a little muscle couldn’t fix .
ANy way I need a new RAM cooler, but can’t seem to locate something that has very very narrow end clamps or something that attaches a small fan, 60mm-80mm, to the top of the RAM. Any thoughts?
Here are two I’m considering, but both still make me nervous. SOmething with a clamp that can hold an 80mm would be ideal, no?
Corsair - http://www.frozencpu.com/products/53...html?tl=g40c18
CoolIT - http://www.frozencpu.com/products/55...LED.html#blank
Thanks for the help!!
, E6750 es
