JumperFree Configuration Settings
AI Overclocking: Manual
CPU Ratio Control: Manual
- Ratio CMOS Setting: 7
FSB Frequency: 410
PCI-E Frequency: 101
DRAM Frequency: DDR2 1230
DRAM Command Rate: not Option
DRAM Timing Control: Manual
CAS# Latency: 5
RAS# to CAS# Delay: 5
RAS# Precharge: 5
RAS# Activate to Precharge: 15
TWR: 15
TRFC: "30" or 35 or 42
TWTR: 14
TRRD: 13
TRTP: 13
Transaction Booster: Disabled
Boost Level: (only displayes when Transaction Booster is set to Disable or Enabled)
Clock Over-Charging Mode: AUTO
CPU Spread Spectrum: Disabled
CPU Voltage: 1.35v
CPU Voltage Reference: Auto
CPU Voltage Damper: Enabled
CPU PLL Voltage: 1.7v
DRAM Voltage: 2.55v
FSB Termination Voltage: 1.5v
North Bridge Voltage: 1.7v
North Bridge Voltage Reference: x0.67
South Bridge Voltage: AUTO
Advance CPU Settings
- Ratio CMOS Setting: 9
C1E Suppport: Disabaled
Max CPUID Value Limit: Disabaled
Vanderpool Technology: Disabaled
CPU TM Function: Disabaled
Execute Disable Bit: Disabaled
PECI: Enabled
