Results 1 to 25 of 75
Thread: Swiftech is mixing (alu-cover & copper-base) in Apogee GTX
Threaded View
    May 2006
    Slovakia Europe
    Quote Originally Posted by IanY View Post
    Oh.. the color on the inside top of the Swiftech GTX is going to fade and there'll be some black dye coming off. Not to worry. Its perfectly normal. No, the top of the Apogee GTX is not made of delrin, but those who are scared of any use of aluminum are foolish because the plating is of considerable quality. Don't even think of painting anything on the inside of the block. You will wreck the highest performing water block in the market.
    Quote Originally Posted by NaeKuh View Post
    pictures paint 1000 words iany:
    If these bother you, get a soft toothbrush, and scrub the dye off b4 you drop it into the loop. that silver underside is nickle plate.
    And you guys should really listen to iany. He and nikhsub are probably the only people i can think of on this forum whose had the block b4 i did. I was part of the review that went on this forum.
    But YES it does come off, that was done on dual DDC-2. I have a RD-30 now, and i scrubed the dye off, with a soft toothbrush. And it comes out very easily with warm water.
    Had anyone any problems with this stuff
    // E6600@3900~1.5v // Asus P5K DLX //A-DATA 2GB EE // Samsung F1 1TB // ASUS X1900XTX~735/1680 // Corsair HX520 // Thermaltake Armor VA8000SWA // W. COOLING ~ D-Tek FuZion & Viscool V3 GPU & Swiftech MCP655 & 2x Swiftech MCR-320QP //
