Hello,
When it comes to standby, I have some problems with my Intel Bad Axe 2 mobo. These are not the only problems I have encountered but I will continue to add to this thread.
First, in XP SP2, when i switch to stanby, the hdds stop, but the video card fan and the case fans remain on. The case fans are connected to the mobo (front, rear and aux), while the CPU fan is connected through a std molex. Sometimes, when I resume from standby, the System process would keep one core busy (50% of the CPU) continuously, until I restart XP.
In Vista, standby works, and the fans stop. But after the resume, the System process would keep 50% of the CPU busy. Process Explorer reports that actually smss.exe under the System process is the culprit.
I use the latest released NVidia drivers and in BIOS ACPI is set to S3. All the mobo drivers were installed after installing the OS, starting with the chipset and ending with audio and video.
Does anyone know what's wrong and what is the solution for this?
