Results 1 to 25 of 119
Thread: Work log Project TJ07
Threaded View
    Mar 2007
    Durham, UK
    I thought is was about time to start my work log.
    This is my first attempt at watercooling, so please feel free to voice any concerns or opinions you have about how my build progresses.
    My plan is to have two loops, one for the GPUs, and the other for the CPU and NB. I’m unsure whether to include to also include the SB with the CPU as well.
    One of the reasons I was against adding the SB was because of what I’ve read about flow restriction.
    I plan the watercool the OCZ Flex later, and I thought I might include the SB with that loop.
    The reason I plan to watercool the ram later is because I want to get the first two loops running, also I need to find away to incorporate a third loop. I will have to use ¼ ID tubing on the Flex ram because of the size of the barbs.
    Maybe I should have bought a Mountain Mods case instead of the TJ07 ha ha.
    Loop one will go: RES > D5 > PA120.3 > GPU > GPU > RES
    Loop two will go: RES > D5 > B I P > CPU > NB > RES
    I plan to have the PA120.3 and the two D5 pumps down in the base with the PSU.
    The Black Ice Pro II mounted up were the top case fans are.
    System parts
    Case Silverstone TJ07B-W
    CPU Intel E6600
    Mobo EVGA 680i
    GPU 2 x Asus EN8800 GTX
    Ram 4 x 1gb 6400 OCZ Flex
    PSU Enermax Galaxy 1000w
    Sound Creative SoundBlaster X-Fi Xtreme Gamer
    HDD 150gb Raptor x
    HDD 250gb Deskstar
    MCubed T-Balancer bigNG 4-channel Fan Controller
    Sunbeam Rheostat fancontroller
    Fans Yate Loon 120mm blue led
    Watercooling parts
    CPU block D-TEK Fuzion
    GPU blocks 2 x EKEK-FC8800 8800 GTX – Acetal
    NB block EK-NB EVGA 680i Acetal
    Pumps 2 x D5
    Rads PA120.3, Black Ice Pro II
    Res 2 x EK-Multioption RES 200mm
    Tubing Tygon ½
ID:	60114   Click image for larger version.
ID:	60115   Click image for larger version.
ID:	60116   Click image for larger version.
