@ Computex
The first one, the HSC-100, is in tower format, while the latter is a desktop case. Both are essentially giant heatsinks connecting the processor to fins across the case surface via multiple heat pipes. This form of cooling is efficient enough to remove the need for a fan to cool the processor. Nonetheless, system temperatures should be higher than with a standard fan-cooled setup setup—unless you crank the AC up, Thermalright says.
