Page 1 of 2 12 LastLast
Results 1 to 25 of 36
Thread: Quick question,TT or Corsair
    HWGurus
    Mar 2006
    What to choose? Thermaltake 750w or Corsair 620w? TT is about 50$ cheaper.That is what I can buy,there is no other competition...OK,there is but it is much more expensive.Tagan 700w Easycon XL is about 250$,so you know what price is it
    Live Long And Overclock
    Sep 2004
    Check the tiered PSU Guide.
    Perkam
    HWGurus
    Mar 2006
    They are in the same section
    Xtreme PSU Tester
    Jul 2006
    The Thermaltake is $50 cheaper than the Corsair!?!?!
    Get the Thermaltake!
    Mar 2007
    The mountains of Wales
    Corsair is the probable favourite but i used a Thermaltake 750 in a pc about 6 months ago and it has proved to be very quiet and stable for the money !!
    Hark children of the Resolution !!
    I am Xtreme
    Jan 2006
    Australia! :)
    i got a TT 750W - & love it!
    DNA = Design Not Accident
    DNA = Darwin Not Accurate
    heatware / ebay
    HARDWARE I only own Xeons, Extreme Editions & Lian Li's
    https://prism-break.org/
    HWGurus
    Mar 2006
    Corsair is cca 230$ and TT is cca 170$.It will be TT 750w,but the problem is also that it is only 1 year warranty in that store...Can I send it to TT after 1 year if it failed?I heard it have 5 year warranty
    Xtreme PSU Tester
    Jul 2006
    It's probably only 1 year in-store for the Corsair too.
    Yes, Thermaltake has a 5 year warranty now.
    http://www.thermaltakeusa.com/support/warranty/ps.htm
    May 2007
    If the TT is really that much cheaper then get it.
    HWGurus
    Mar 2006
    Then I´ll probably get TT,but what is better?Now don´t look at price,just for performance,nothing else. It got 9.5 for performance from you jonny,also the corsair...
    Xtreme PSU Tester
    Jul 2006
    Tough call. They're both very good. Both use the same quality of components. Both are modular. Both are efficient. Both are quiet. Both have 5 year warranties.
    There's one place that the TT shines over the Corsair and that's that it puts out more power, so even if they're the same price I'd probably still get the TT over the Corsair.
    On the other hand.... I just recabled my machine last night and I have an X3 with the FlexForce cables like the Corsair and I'll tell you what.... Those damn cables are SO MUCH EASIER to route under the motherboard and stuff than your typical red black black yellow wires, sleeved or non-sleeved, that it's not even funny.
    HWGurus
    Mar 2006
    Cables are not problem.I always find a way to hide it...Will it be enough for 2xhd 2900xt OC (without voltage modding) and dc cpu,4gb and 200gb hdd?Only CPU and GPU will be overclocked,but nothing too much...Only for benching with water cooling (then you know that it wont be anything required)
    Sep 2004
    The TT will handle two HD 2900s...but barely...
    You'd be better off with a Silverstone, PCP&C or Zippy 750watter...or an 850watter from all other brands for that kind of rig.
    Perkam
    Xtreme PSU Tester
    Jul 2006
    I don't necessarily agree.
    He's not running two HD2900's with a Quad FX board and a four drive SATA raid. The 750 should be fine and I certainly don't think a Silverstone or PCP&C 750W would have to be any better. Certianly not enough to make any difference.
    HWGurus
    Mar 2006
    Well now is 20$ difference for TT...
    TT is cca 150%,corsair is about 174$
    What is quality of caps inside TT? I heard CWT (OEM producer for TT) is bad and the corsair is better choice over TT,that it has more power and lower ripple
    PSU Expert
    Jan 2006
    Saskatchewan
    The TT will be using predominantly Samxon. CWT has learned their lesson about caps and heat
    Jetway HA07-Ultra, Phenom 9600, 4GB G.Skill 1066, Antec CP-1000, 3R Ice Age, Ultra Aluminus, HD2600XT, WD Black 640GB, Seagate 500GB 7200.11, Maxtor 200GB Diamondmax 10, Lite-On 48125W, Pioneer DVR-115D, Plextor PX-716SA
    HWGurus
    Mar 2006
    How good is CWT like OEM producer?
    There is also Silverstone Strider 750w ST75ZF,how is that PSU over this two?It is expensive,about 192$
  18. #18
    PSU Expert
    Jan 2006
    Saskatchewan
    About Seasonic build quality, maybe a bit better. That Silverstone is one of the lesser builds... no competition to either the TT or Corsair.
  19. #19
    Xtreme PSU Tester
    Jul 2006
    Quote Originally Posted by quake6 View Post
    No, there isn't.
    It's either a SilverStone Strider 750W ST75 or a SilverStone Zeus ST75ZF. Two totally different PSU's.
  20. #20
    HWGurus
    Mar 2006
    my bad it is zeus.Then is tt enough?
  21. #21
    Xtreme Mentor dengyong's Avatar
    Nov 2006
    A great place again
    tt 750 never let me down (wish I could say that for my pos enermax galaxy 1000)
  22. #22
    Xtreme Mentor
    Apr 2007
    Idaho
    The TT.
    SilverStone Strider 750 watt is a good choice too
    "To exist in this vast universe for a speck of time is the great gift of life. Our tiny sliver of time is our gift of life. It is our only life. The universe will go on, indifferent to our brief existence, but while we are here we touch not just part of that vastness, but also the lives around us. Life is the gift each of us has been given. Each life is our own and no one else's. It is precious beyond all counting. It is the greatest value we have. Cherish it for what it truly is."
  23. #23
    May 2007
    there are 2 TT 750W's with different model #'s
    one in the "Guru"'s review model# W0116RU "Modular"
    and the other model # W0117RU(standard ps wiring) which has a $30 rebate if I'm not mistaken at NewEgg
    Are they both the same on the insides?
  24. #24
    Sep 2004
    Quote Originally Posted by jonnyGURU View Post
    No, there isn't.
    The ZF is Etasis based...and can handle far more than the TT
    Perkam
  25. #25
    May 2007
    which is better TT 750W or the Enermax Infiniti 650W or Cosair 620HX?
    the TT ~ $149 shipped and the Infinity 650 ~ $167 shipped and
    Cosair 620HX ~ $140 shipped
    i am torn between these 3 since the TT 750W is on sale now.
    building a Q6600, P5K mb, 2gig ram 6400, 2 hdd, 1 dvd writer, 1 DX10 ATI Card(or sub. for a 640mb GTS), one ATI tv wonder, Probably will OC alittle or maybe not at all.
    I'm wanting the Infiniti 650W as you can see or I wouldn't be in this position
    Jonnyguru review of the TT Toughpower 750W modular has me wondering about the 12v rails, that review came out very sketchy about the 12v rail max amp. I probably shouldn't worry bout it with my future setup but I'm wanting something good. the infiniti 650W sounds good from Jonny's review but its pricing is higher.
