I just managed to kill my E6600. Going to have to order a new one. Thinking of going with a Xeon 3060. Is it worth the few extra dollars? Right now anything faster is a bit over budget for me. Any thoughts are welcome.
how did you kill it? high volts?
i5-750 w/ Thermalright Ultra120X
Coolermaster HAF-932
MSI GD65
2x2GB G.skill Cas7 1600MHz
Sapphire HD6870
Western Digital 640GB.AAKS
2x Samsung F1 1TB
2x Samsung SLC 64GB SSD
Pioneer DVR-212BK
Corsair HX620W
Creative X-Fi Xtreme Music (dead, using onboard -.-)
LG W2286L
Nope. I tried to take the IHS off. It was going good until it fell onto the padding I had under it. It started melting the padding. So I grabbed it up and tried to pull the melted stuff off before it could harden up. I ended up pulling most of the parts off the back side. Guess if I had let it cool down it would have been fine.
So has there actually been a story of a C2D dying from volts or temps yet?
Lu523,
So you ripped some SMT parts off the package?
Why not try soldering them back?
You were not supposed to see this.
I had thought about that, but my soldering skills suck.
BTW, how did you heat the IHS to melt the solder? If you ask me you let it get much too hot. I did remove some Socket775 IHS, but never did I have to heat them so much that the solder on the backside's SMD parts melted.
If the bottom of the processor was that hot chances are good it was ruined before the SMDs were pulled off.
retired computer enthusiast
Yea, too much heat on it. I heard a pop, but it did not come apart. Put some more to it then it went.
My Heat
i5 2500k @4.5ghz Raystorm
Asus P8Z68-V Pro/Gen3 16gb(4x4) G.Skill PC12800 Ripjaws X
x1900xt MCW60
Rad: Thermochill PA120.3 3YL SL/ Pump: DDC2 w/ Petra's top 7/16in ID masterkleer
Corsair 120gb Force GT SSD/ 1TB WD Black Caviar SATA
X-Fi music/SH-203B/H62L/LH-20A1L
Corsair HX620w /Acer AL2223W/modded TJ07
1.75v IIRC
