05-26-2007, 01:30 PM
#1
Xtreme Guru
Using the Maze4 with the HD 2900XT
The Maze4 does cool the R600 GPU without any modification to the WB.. Also note that DangerDen's website also states that the Maze5 can also cool the R600 without any modification to the WB. The pics will show the Maze4 on the HD 2900XT. Please note that I used the OEM HS to cool the ram and mosfets. I also took measurements to get an idea if the Maze4 contact area would fit inside the Shimmed GPU.
Photos that show the Maze 4 with the HD 2900 XT
Measured the Maze4 contact area
Measured the inner diameter of the shim (space found within the shim)
GPU Print fits the Maze4 contact area (corners of the GPU leave no room)
Front of HD 2900 XT with the Maze4
Back of the HD 2900 XT with the Maze4
Temps of the HD 2900 XT with Stock HS and Maze4 (also comparison with GT360 vs PA120.3)
Idle & Load Temps Before
OEM Stock Cooler
Do to the nature of AMDGPU it shows both idle and highest temps (load temps)
Ambient was either 21C or 22C (from memory).
Video Card OC 858/900 (I believe, agian from memory)
Using 2 Scythe S-FLEX SFF21F at 63.70 CFM at 1600 RPM and 1 Delta Triple Blade 141.96 CFM 3700 RPM
GT360
Load temps at 30C Ambient is only 48C (from AMDGPU)
3DMark06 @ 858/900 11838 (only 14 more then with OEM HS. If that means anything)
Using 3 Scythe S-FLEX SFF21F at 63.70 CFM at 1600 RPM
PA120.3
Load temps at 28C Ambient is only 43C (from AMDGPU).
3DMark06 @ 858/900 11824
PA120.3
Load temps at 30C Ambient is only 46C (from AMDGPU).
3DMark06 @ 858/900 11800
Loop orientation:
Res>Pump>GPU>CPU>Rad..back to res
Side note: Regarding the PA120.3 rad
I find it better to use a 11/16 deep socket to install the plastic barbs to the PA120.3 rad (after you screw the barb by hand). The straighter you install the barb the less likely the barb will tilt, stripping the threading on the plastic barb. Also, do to how you torque the barb there is less force on your part vs the wrench. I had to add 2 to 3 more layers of ptfe tape to the barb's threading as it leaked the first time I installed it. If you want to buy barbs the current ones you have maybe to small. You will need G 3/8" threaded barbs. Most rads, water blocks, res, etc use G1/4" threaded barb. AquaXtreme does use G 9/16" threaded barbs. It's important to note that you must install the neoprene gasket that comes with the rad (well mind came with one). I only tighten the screws until they are nice and snug. Reason behind that is to create as much distance as possible to the fins. The farther away the fans are from the rad itself the less likely noise is created IMHO.
Side note: Regarding the Maze4
I find it better to install the 4 screws in a criss-cross fashion. I try to keep count on the number of turns for each pair of screws (criss-cross). That way there is even pressure on the gpu die. Keep in mind that this gpu die is more diamond shape. Therefore care is needed when you tighten down on the water block. You DO NOT need to tighten it to the point where the screw will no longer turn. The water block should be tight but, there should be some slack when you try to turn the screw as well. You want to make sure there is contact between the gpu die and water block contact area IMHO. Therefore, you may need to make a mental note (or write it down) on the number of turns it took to tighten the wb to the GPU. Next, uninstall the wb and examine thermal compound on the wb to see if there is proper contact (as in the photo above). This is what I did in order to install the GPU onto the Maze4.
Side note: Regarding the HD 2900XT
Passive cooling the mosfets, is not a good idea. Although I still have the blower installed and working, at this time, I still have no control over it's speed. Using AMD GPU Clock Tool the temps can get pretty high under load unless a 80mm fan is used to cool the bottom of the video card (where the mosfets are located). I found that the oem blower (without it's plastic shroud) is less effective at cooling. I found the temps for the HD 2900XT similar to the X1900xtx when water cooling
__________________
05-26-2007, 06:27 PM
#2
Banned
Looking good there! Whats the cooling set up, indervidaul loop or mixed loop? What size rad
05-26-2007, 06:34 PM
#3
Xtreme Guru
mixed loop also cooling C2D cpu. I have a GT 360 rad
__________________
05-26-2007, 10:53 PM
#4
Thats pretty nice for that rad... I wonder what a thermochill 120.3 can do!
__________________
For all of your Watercooling needs, head over to Petra's Tech Shop.
"Never skimp on the Power Supply" -Me ( HEAT)
Do your senses a favor, get the Klipsch ProMedia 2.1 sound system.
Build
E8400 @4.0(for now) | DFI LT X38-T2R | 4x1GB Ballistix PC8500 @Stock(for now) | HD3870 | PCP&C 610 | Creative X-Fi | NEC 1970GX LCD | Heavily modded Aspire X-Cruiser
Watercooling
MCP655 -> Swiftech MicroRes v1 -> Dtek FuZion v1 -> BIP 2X120 [suspended off case DIY] ->MCW-60 -> PA160 w/shroud [Inside of case  ] ->MCP655 Tygon 5/16, PT_Nuke + Pentosin, Yate Loon D12SM-12's for rad's.
05-27-2007, 04:23 AM
#5
Xtreme Guru
Not sure on that one. I was concern about making decent contact between the base of the WB and the GPU. Also making sure that the mosfet/ram HS would still fit.
__________________
05-27-2007, 02:47 PM
#6
Yeah, I know that you were just testing for contact, but it is still something that i'd like to see.
__________________
Build
Watercooling
05-27-2007, 07:29 PM
#7
Xtreme Guru
After looking at DD's website I am not sure why they don't use the stock ram/mosfet heatsink? I wonder if they know it's possible?
__________________
05-27-2007, 09:07 PM
#8
53mm dimensions of block?
__________________
05-27-2007, 09:44 PM
#9
Xtreme Guru
53mm dimensions of what block?
__________________
05-28-2007, 06:52 AM
#10
maze4
__________________
05-28-2007, 08:41 PM
#11
tl;dr
mounting hole locations I would assume..
05-28-2007, 09:29 PM
#12
Xtreme Guru
Wow, this thread is mentioned on front page of DD website
__________________
05-28-2007, 10:26 PM
#13
Not to shabby if you ask me
__________________
Build
Watercooling
05-29-2007, 07:32 PM
#14
Xtreme Guru
I wonder who is water cooling their HD 2900XT?
__________________
05-29-2007, 11:54 PM
#15
I do too, since I might be doing the same thing that you're doing when the R650 comes out.
__________________
Build
Watercooling
06-01-2007, 09:30 PM
#16
Xtreme Guru
Ok I've updated the OP with PA120.3 using 28C and 30C ambient temps.
__________________
06-03-2007, 09:14 PM
#17
Xtreme Guru
Some minor wires here and there but WCing setup gets the job done
__________________
09-20-2007, 02:42 PM
#18
what the???? your maze 4 has holes in it that both of mine don't have O_o no wonder i can't fit it >_>
__________________
09-21-2007, 03:03 PM
#19
hi all!
what is the best fullcover waterblock for 2900xt 1gb?
is koolance r600 real good?
thx
09-21-2007, 03:30 PM
#20
Originally Posted by rioja
hi all!
thx
I wouldn't get the koolance. If you're going to spend that much... it's better to get the EK block. EK makes the best full coverage blocks!
__________________
System
Intel Core 2 Quad Q6600 G0 Lapped @ 3.4 Ghz
4GB G.Skill Pi Black DDR2-800
Asus P5K-Deluxe with WiFi
ATi Sapphire 4870
Creative X-Fi XtremeMusic
Corsair HX620 620W
Lapped Thermalright Ultra-120 Extreme
09-23-2007, 10:38 PM
#21
Xtreme Guru
Ok I got the HR-03/R600 and so far notice a in Voltage regulator current from roughly 40.45C at idle to 25.74C at idel. That's a whopping 14.71C drop (roughly not an exact depending on ambient temps). Because R600 doesn't go into 3d mode using RTHDRIBL I am still testing. But will post results soon. However. It appears that the PWM, mosfet heatsink along with the memory mosfet heatsink is really doing it's job (and its alu not copper!).
Here are some pics
Before the install of HR-03/R600 heatsinks only
After HR-03/R600 install of heatsinks only
Take a look at what I circled. These items apparently needs to be properly cooled. As you look at the pic below you will see that the pwm sink will cover them.
Take note of the extended "arm" on the row of ram sinks to the left of the GPU. It covers 2 other vital components that need to be cooled. One is a pwm I am not sure about the other component.
This photo shows the Arctic Silver Cleaner, the name of the video card heatsink and overall photo of the R600 with the memory/pwm (mosfet) heat sinks
This photo shows the rear of the R600 and the memory ram sinks.
__________________
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
