XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > General Computer Hardware
Reply
Old 05-21-2007, 09:55 PM   #1
s1rrah
s1rrah's Avatar
Samsung 226BW: Samsung MagicTune Software
Samsung MagicTune, anyone?
First off, let me just say that I love the Samsung 226BW; this is a rather exceptional statement coming from a very recent CRT convert, not to mention one from the visual design field:
MagicTune: Released with 225BW but not 226BW?
Prior to being the proud and quite pleased owner of a Samsung 226BW LCD, I had tried it's predecessor, the 225BW; even though I took the 225BW back after a couple days, mostly due to reading some reviews of the 226 model, I still was upset to find that the 226BW LCD did not ship with Samsung's MagicTune software, as the 225BW did.
Maybe I got a bum package or something and everyone else's 226BW shipped with MagicTune, but, for whatever reason, my particular monitor did not.
Anyway, ...
Since I was totally impressed with the MagicTune calibration routine and since I hate using the OSD buttons on the monitor to make changes to my display, and since Magic Tune is freely available for download from Samsung's site, I decided to install it and try it with my 226BW anyway.
What I've found, after two months or so with this Samsung 226BW LCD is that the MagicTune software has become indispensable insofar as a daily tool, especially it's color calibration routine which allows you to save user profiles and load them automatically at startup; furthermore, if I ever need to fine tune the monitor's settings (brightness/contrast/gamma), I don't have to lean forward and actually use the monitors OSD buttons (I've in fact, *never* used the button interface on the monitor).
Anyway, on the chance that all 226BW's shipped without MagicTune, I thought I'd write a short post on my own experiences with it while also highly recommending it to anyone who hasn't installed it.
** EDIT ** 12/24/07 ***
Just got off the phone with Samsung monitor tech and he says MagicTune is perfectly compatible with the 226BW and that it was withheld by Samsung for marketing reasons only.
His words: "Hell, we use it here with our 226BW's every day!"
Anyway ... just thought I'd add that.
Also interesting, the software was originally designed for a Samsung monitor which had *no* external menu buttons on the monitor at all ...
MagicTune Download
The main MagicTune download page, at Samsung's website is here: MagicTune Download
There's quite a few different versions of MagicTune available on the main download page, and it seems some are indicated to only be for certain Samsung monitors; since I'm using XP Home and since, technically, the 226BW is not listed as a supported monitor, I simply decided to go with the 'Premium' version which has no specific model or models associated with it:
MagicTune Premium for XP (direct download): XP Version
The Calibration Function
What I've found most invaluable, and especially since coming from a decade of using high end 21"+ trinitrons (visual design professional) has been the color calibration routine built into Magic Tune's "Color" tab.
Here's the screen in Magic Tune from which you launch the calibration routine:
This feature alone made it possible for me to get rid of most of the main problem I was having with the step up from CRT's to LCD's: the much discussed tendency of colors to look 'washed out,' or otherwise, just not as saturated as one would find in a decent Trinitron CRT, especially greys; this phenomenon is most evident when viewing large areas of continuous tone colors such as those found in windows interface objects, etc.
The grays in Windows XP's default interface start bar, for instance, compared to a CRT and when using an LCD, just look a bit lighter and, well, 'washed out;' I think that's a good term for it.
I found that using the calibration routine that comes with Magic Tune greatly reduced this tendency in my own Samsung 226BW.
Unlike the interface suggests, and especially if your not familiar with other, very similar calibration routines, it's not really that simple of a process.
I did some notes on the main calibration page which might help explain how to go through the calibration process.
Click the smaller image below for details:
Calibration Test Screen Explained
The calibration test itself, unless you've used something like Adobe Photoshops color calibration routines, is not really that intuitive. Once you understand the concept, it's simple, but for any n00bs out there, I thought it might be good to have a visual breakdown:
You'll have to view the linked test screen image at full resolution (1680x1050) for things to be rightly legible; but it should be clear enough.
Also, there's a help file accessible from that same test screen, in the upper right.
Repeat the indicated process for each of the 5 or so calibration test steps and be sure to save your profile when complete; later on, and as ambient light conditions change, you might try re calibrating and saving another profile as the LCD output can be perceived somewhat differently when going from a daylight lit room to one completely dark in the evening.
Anyway, as I've said before ... I found this feature to quite dramatically reduce the somewhat 'washed out' aspects of the typical consumer LCD versus the typical and decent CRT (Sony Trinitron etc.).
The fact that I even noticed this discrepancy between CRT's and LCD's is almost definitely due to the fact that I've worked with CRT's in a field that demands accurate color reproduction (screen-to-print, etc.) and so maybe the majority of you never noticed.
But for those of you, like me, who were initially bugged by the difference in saturation evident when using consumer LCD's ... the above explained calibration routine might just help you acclimate.
I know it did me.
Load MagicTune at Windows Start
As a final note regarding calibration and if you want your last saved profile to load at windows start, make sure you've selected "Enable Task Tray Menu" from the "Option" section of MagicTune's main interface.
MagicTune: Other features
Otherwise, the other main benefit of using MagicTune is that I don't have to lean forward to make the expected and regular changes to my 226BW's brightness and contrast levels.
Brightness/Contrast
Depending on my room ambient light and whether I'm watching a DVD or working on a text application ... or otherwise, I've found I need to adjust general brightness and contrast quite often.
When the MagicTune application is loaded in the system tray, I can simply open it and change the settings with sliders.
Following are those features which are available but for which I've never found any use for (MagicBright, etc.).
Samsung MagicColor
I've never found any reason to use this; just seems a bit like fluff-ware to me:
Samsung MagicBright
Again, as with MagicColor, above, I've never touched this; again, seems like more fluff-ware:
Sharpness Control
I played with this initially, but have found little use for it, other than the default settings because text and otherwise has always been displayed very nice and sharp. The difference in DVD's and otherwise is nominal at best:
Tone Control
As with most monitors, you can adjust the 'tone' of the overall output; I lean towards warm, myself:
Gamma Control
This is another available and somewhat nit-picky item which I've never used much. Mostly, I think, due to the main color calibration routine handling this for me.
The Point?
The main point is that for me personally, and even though (according to Samsung's site) MagicTune is not developed for the 226BW, it still has made a big difference in my personal appreciation of the 226BW LCD.
I mean specifically and most importantly the color calibration routine. I really affected the default 'washed out' sort of appearance of colors that seem to plague all LCD's.
Also ... and this is a huge benefit ... YOU NEVER HAVE TO USE THE CLUMSY ONSCREEN MENU via the buttons on the monitor ... you can just use a mouse with MagicTune which is way easier.
That said, I don't guarantee that you will have similar results using this software with your own 226BW, nor do I guarantee that it won't melt your screen or otherwise cause damage. So, use at your own risk.
But for me personally, and since I used the 225BW for a day or two and since that monitor shipped with a MagicTune CD ... I think it's safe to say that using MagicTune with the 226BW is most likely okay.
Otherwise ... and since I can't sleep ... I thought I'd pass on some of the love.
:thumb:
__________________
- - --++// M6CH1NE //++-- -- - - -- -
E6400 @ 3.6ghz (24/7) / 4ghzClub! / Asus P5B-DLx / 2 gig Mushkin Extreme DDR2-6400 /
eVGA 7900GT- 1.5vmod - 700/852 / vantec iceberq 6 vga cooler / TT Armor Full Tower w/ side panel fan / Scythe Infinity w/ Mount-mod / Does your zalman9500 SUCK BIG ARSE?
- - --++// 7eMPS //++-- - - -- - -
CPUidle:37 | CPUload:54 | MBidle:26 | MBload:27
GPUidle:37 | GPUload: 65
** temps obtained at 22C ambient
** load = six hours dual prime95 torture test
s1rrah is offline   Reply With Quote
Old 05-21-2007, 10:30 PM   #2
EniGmA1987
Send a message via MSN to EniGmA1987
Thanks for this. A friend of mine was actually thinking about buying one of these sometime in the next couple weeks
__________________
Originally Posted by Shintai
Imagine Microsoft said that Windows 7 would only work on Acer/HP/Dell/Lenovo machines.
Its just Apple thats full of BS
Tyan S2932G2NR-SI
AMD Opteron quads @ 2.6GHz (Shanghai) x2
16GB of Kingston DDR-800 ECC RAM
ATI 4890 1GB
ASUS M3A79-T Deluxe
Phenom II 940 @ 3.75GHz w/ 1.4v
NB and HTT @ 2.75GHz w/ 1.4v & 1.3v
G.Skill PI @ DDR1150 w/ 2.1v
ATI 4890 @ 1022MHz core
EniGmA1987 is offline   Reply With Quote
Old 05-22-2007, 06:05 AM   #3
NightRaven
Only Extreme Need Apply
gotta say samsung monitors rock!
thou i must say tuning them is a must... if not ur eyes would hurt after a while! they're pretty clear and i'm really satisfied with my 931bw.
__________________
Buildin
NightRaven is offline   Reply With Quote
Old 05-23-2007, 02:45 PM   #4
s1rrah
s1rrah's Avatar
__________________
Old 06-30-2007, 02:28 AM   #5
NijN of Spades
NijN of Spades's Avatar
Nice thread! Thx
Btw: MagicTune is shipped with the monitor nowadays
NijN of Spades is offline   Reply With Quote
Old 06-30-2007, 04:50 AM   #6
s1rrah
s1rrah's Avatar
Originally Posted by NijN of Spades View Post
Nice thread! Thx
That's good to know ...
I posted somewhere that a conversation with Samsung's tech staff revealed that the software was not included for strictly marketing reasons ...
Good software ... I use it every day ...
__________________
Old 09-27-2007, 02:06 PM   #7
ronss
thanks,,,just ordered the 226bw from dell, proaby get in mon or tues... i have read a lot on this monitor, and their is a lot to read. the different panels, that seems to be the big buzz, s, a , and c panels from what i gather.. i doubt if i look when i get mine, because i have had some say that the c panel just looks great... to it could be a big myth on the s panel. will find out soon, and will try to use magic tune... i almost bought the 225bw...but changed my mind at the last minute...how does dvd movies look, and can i use a blu-ray player on this monitor..i just noticed phylipps came out with a $300 blu-ray player, more my price range
ronss is offline   Reply With Quote
Old 09-27-2007, 02:07 PM   #8
ronss
thanks,,,just ordered the 226bw from dell, proaby get in mon or tues... i have read a lot on this monitor, and their is a lot to read. the different panels, that seems to be the big buzz, s, a , and c panels from what i gather.. i doubt if i look when i get mine, because i have had some say that the c panel just looks great... to it could be a big myth on the s panel. will find out soon, and will try to use magic tune... i almost bought the 225bw...but changed my mind at the last minute...how does dvd movies look, and can i use a blu-ray player on this monitor..i just noticed phylipps came out with a $300 blu-ray player, more my price range.
Old 09-27-2007, 04:07 PM   #9
s1rrah
s1rrah's Avatar
You'll love the monitor whatever panel you get.
I hope magictune works with your video card (some folks with newer cards get a 'not supported' message.
I've found the calibration routine to be ESSENTIAL in getting greys and other colors in the XP interface to look dense and more saturated than your standard uncalibrated LCD.
I just installed a Samsun 914v 19" LCD for a friend and the uncalibrated image when viewing continuous tone colors in the XP interface was just so washed out and thin.
Luckily Magictune worked fine with his system and post the calibration routine (described in my original post) ... it was like night and day.
Coming from CRT's and Trinitrons ... there's simply no way I could use my LCD with out some sort of calibration routine.
Regarding DVDs:
The 226BW is phenomenal with DVD's ... again, if your a purist who can't stand backlight bleed and blacks that aren't really black (big problem with LCD's) ... it'll take some tweaking to get things perfect.
Myself, I use Nvidias PureVideo codec which has a good set of color/contrast adjustments and also, once that is set to the optimum level for Blacks and backlight bleed elmination ... I can use MagicTune's brightness and contrast to polish it up.
Here's a bunch of UNAFFECTED camera shots I took of the monitor's output while watching the film Munich in a completely dark room. Great color and zero backlight bleed:
Otherwise ... enjoy your monitor!
__________________
Old 12-23-2007, 02:29 PM   #10
CaNNibaL
CaNNibaL's Avatar
i've got a prob with my 226BW, sometimes when windows starts it appears a message saying: "your monitor does not support magic tune" or something like that :X what's that :X
Regards
__________________
Config :
-Intel Core 2 Duo E6400
-Asus P5B Deluxe Wi-Fi Ap
-2x1GB Mushkin XP2-PC8500 DDR2
-Samsung SATA2 750 GB 32MB F1 + Seagate SATA2 500GB 16MB (External)
-Powercolor ATI HD4850
-Creative SoundBlaster X-Fi Xtreme Music
-LC Power 560 W Titan
-Samsung SyncMaster 226BW
CaNNibaL is offline   Reply With Quote
Old 12-23-2007, 04:30 PM   #11
s1rrah
s1rrah's Avatar
Regards
If it's happening intermittently ... that is, sometimes MagicTune loads and other times you get that message ... then that's behavior that I see as well.
Doesn't happen much, but usually does after I install some new program that has a tray component or otherwise is a program that runs at startup.
Strange as it may seem ... I believe the MagicTune software load routine, at windows start, is sensitive to load order or is potentially 'messed with' by other things loading.
Things you can try that I have found sometimes work:
1. Just restart your computer.
2. If that doesn't work, then use MSCONFIG (start/run/msconfig) to selectively disable anything you don't absolutely need to run at startup; this has fixed the problem for me many times in the past as, typically, the MagicTune load problem started after installing something else (last time was when I loaded a "keep alive" program to move my mouse every 15 mins so as to prevent my machines autologoff routine, this program had a tray component which I had to disable in order to get MagicTune to run again.
3. Uninstall and reinstall magic tune (but I'd try number 2 first!)
Wierd problem ...
If it's any consolation, I get it too ... about once a month or so ... but can always get it to load again via the above methods. I've never had to reinstall it ...
Good luck ...
__________________
Old 12-23-2007, 07:39 PM   #12
Soulburner
Just deleted over 900 PMs
Soulburner's Avatar
Looks like a solid program.
However, I'll stick to my trusty Spyder2. It always goes a good job of calibration, and its a lot easier than doing it myself.
__________________
Desktop:
NZXT Zero
Central Processing: ABIT IP35 Pro / Core 2 Duo E6850 @ 3.6Ghz / 4GB G.Skill F2-8000CL5D-4GBPQ
Cooling Station: Enzotech Ultra-X / Sharkoon Silent Eagle 120mm / Modded IP35 Pro Heatsink System
Storage Subsystem: WD Raptor 150GB / WD Caviar 640GB / WD GP 1TB / Samsung 18x DVD-R/RW
Networking Department: D-Link DIR-655 / Realtek Gigabit NIC
Visual Processing and Display: EVGA GTX 260 896MB Superclocked / BenQ 24" 1920x1200 LCD
Tonal Processing and Delivery: Auzentech X-Fi Prelude / Onkyo TX-SR304 / Athena S.5 5.1 / Velodyne VX-10
Peripheral Input: Razer Deathadder / Logitech LX710 / Steelseries 5L
Power Delivery: Corsair 620HX / APC BX1300LCD UPS
Midnight Blue Dell Inspiron 1720
Core 2 Duo T7500 @ 2.2Ghz
4GB PQI PC6400
NVIDIA 8600M GT 256MB @ 625/1250/1024
WD Scorpio 250GB (5,400RPM)
17" 1920x1200 LCD
< Nikon D300 >
Soulburner is offline   Reply With Quote
Old 12-23-2007, 09:38 PM   #13
s1rrah
s1rrah's Avatar
Do they have a Free Option(tm)?
I'd love to check it out myself.
__________________
Old 12-24-2007, 05:49 AM   #14
Soulburner
Soulburner's Avatar
No but close, the Spyder2Express is $60 something at Newegg.
__________________
Desktop:
NZXT Zero
4GB PQI PC6400
17" 1920x1200 LCD
< Nikon D300 >
Old 12-24-2007, 09:10 AM   #15
CaNNibaL
CaNNibaL's Avatar
Thank You s1rrah, i uninstaleld it and remove it from the regstry (regedit), isntalled a new version 1.0.56, now let's see !
Merry xmas
__________________
Config :
Old 12-24-2007, 01:57 PM   #16
s1rrah
s1rrah's Avatar
Merry xmas
Try the msconfig bit as well ...
It gave me the incompatible message just this morning but was fixed after I restarted.
One thing I've noticed ... if you've succesfully calibrated your LCD once via the calibration routine ... and if you chose to load the calibration profile at startup ... then that profile will still load even when you get the Magic Tune incompatibility message.
What you don't get, though ... is the interface to control brightness and contrast with the onscreen sliders ... something I find absolutely essential. I haven't had to use the monitors built in menu system once (and this is good cause I'd rather just stay kicked back in my chair and all and just use a mouse!)
__________________
Old 12-24-2007, 02:27 PM   #17
CaNNibaL
CaNNibaL's Avatar
That's true, very nice to have software that adjusts that with mouse
__________________
Config :
Old 02-05-2008, 09:29 AM   #18
freestyler7
Thank you very much for the little guide.
I just bought the monitor and had little problem understanding the calibrate setup on the program.
freestyler7 is offline   Reply With Quote
Old 02-05-2008, 11:56 AM   #19
metro.cl
Xtreme X.I.P.
metro.cl's Avatar
Send a message via MSN to metro.cl
What is your panel? i've read some bad reviews of this monitor and panel C, i can get it pretty cheap but this is holding me back a lot
__________________
metro.cl is offline   Reply With Quote
Old 02-05-2008, 05:00 PM   #20
s1rrah
s1rrah's Avatar
No problem mang. That's what I'm here for.
@metro.cl : mine is an "S" panel (or samsung). The C and A panels are totally redeemable, however but you need to set up a custom color profile to handle the slight blue shift in them. There's a good article on the problem here: http://www.behardware.com/articles/6...e-verdict.html
The above link includes custom downloadable profiles for color correction.
I just went in to Circuit City yesterday (where I bought mine about 9 months ago) and checked the back of the display unit ... and lo and behold, it was an S panel as well.
See if you can buy local and check the panel before buying ...
__________________
Old 02-08-2008, 02:57 AM   #21
Wallboy
I have used MagicTune on my 226BW and it does remove a lot of that blue push, but I'm having a problem with the program staying in task bar with just the logo. It won't go away. How do I fix this. I'm running Vista x64 and downloaded the MagicTune version for Vista x64. I included a screenshot by what I mean.
__________________
CPU: Q6600 G0 @ 3.4GHz w/ TRUE 120
MOBO: Maximus Formula Non-SE
RAM: 4x1GB PC-6400 Ballistix Tracer 4-4-4-12@DDR-907
GPU: (2) HIS HD3870 ICEQ3 Xfire
PSU: Corsair HX620
HDD1: 2x500GB WD in Raid 0
HDD2: 1x500GB WD Data Drive
DVD: Samsung SH-S203B
CASE: Thermaltake Armor
OS: Windows 7 X64
Wallboy is offline   Reply With Quote
Old 02-08-2008, 04:49 AM   #22
s1rrah
s1rrah's Avatar
I'm not sure what to tell you since we're running different versions of Windows and Magictune.
Only thing that comes to mind is make sure "Enable Task Tray Menu" is turned on in MagicTune's options.
And also, when you close MagicTune, don't use the 'minus sign' reduce to start menu button; use the small "X" in the top left of the MagicTune window; this should close the MagicTune interface completely, leaving only an icon in your task tray but not in your main start menu.
Otherwise .. can you PM me to let me know where I can get that background image? It looks awesome.
__________________
Old 02-08-2008, 02:27 PM   #23
Wallboy
Yeah the tray menu is enabled and I always closed it with the X.
edit: If I kill MagicTuneEngine.exe process it goes away.
Wallpaper is dualscreen and I got it here :
http://www.dualmonitorbackgrounds.co...sized.jpg.html
Really nice dual screen wallpapers on that site.
__________________
PSU: Corsair HX620
OS: Windows 7 X64
Old 02-10-2008, 05:40 AM   #24
_Ralph_
I joined this forum a couple of weeks ago and this is my first post . First , let me thank the moderators for an outstanding web site ; I have found several extremely valuable posts while lurking here which have broadened my skills . s1rrah's post led me to MagicTune which has been a god send . I want to thank you s1rrah specificly . My guestion is what is that lcd gamma icon in the notification area and is it needed ? I have a Samsung 226BW .
_Ralph_ is offline   Reply With Quote
Old 02-10-2008, 07:43 AM   #25
s1rrah
s1rrah's Avatar
Hi Ralph.
I too used MagicTune all day every day.
As I've said before: I've never once used my 226BW's hardware menu to change the brightness and contrast, even though I change the brightness and contrast every day ... I always use my mouse and the software to change such settings.
BTW ... the "LCD Gamma" icon is simply the icon that loads when Magictune applies your LCD calibration settings at windows start up.
After your computer starts and the calibration settings are loaded (you should see the change, visually) ... feel free to right click the icon and close it.
Such action will not affect the already applied calibration setting.
It loads on my system as well ... I've just become used to either closing it or ignoring it.
Have fun.
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
