Hey guys
I just received the Gigabyte DS4 P35 motherboard and i went testing right away
I was curious about this new chipsets from intel and especially the new products from gigabyte
Already prepared to 1333 cpus and with much more ram dividers it promises very good performance at a reasonable cost…
Would it deliver…?
For now lets see some generic and bios pics
The board prepared to mount the waterblock
The bios is very easy…..too easy for my taste ……the drawback is that you need to CTRL-F1 every time you want to access advanced options
Much more ram divisors allowing more flexibility and giving the chance to run high ram speed with low fsb
Concerning voltage options, Gigabyte was very generous offering 2,3 V vcore and 2,9 V vdimm, enough even for the most extreme overclocker
The 2nd setback in this bios was the page where you can see the voltages and temperatures…(hardware monitor).instead of a nominal value it only say vcore (ok) or (fail) wich is very little information
I also got a pair of thermalright HR-07 to go with my D9 ram
1st impression is very good….all worked out of the box….and i even used my former 965 OS
I already have XP and VISTA with a clean install and a set of mushkin 2x2048 to run more tests
For now this is what I have
Test bed
X6800 (cooled by apogee WB & 2 x 240 BIX)
Gigabyte DS4 intel P35
2 x 1024 teamgroup 5300 D9GMH (cooled by HR-07)
Twintech 8600 gts (158.18 nvidia driver)
Lc-power 850w
Xp sp2
I know that everybody is waiting for Max fsb on this board but the Max with this cpu was 500
It’s the 2nd board where I get stuck at 500…so I assume it’s the cpu fsb wall
I have a 6600 arriving that i know can do 540 fsb no problems
On the other hand i went for Max benchable speed/ low cas with my ram using this board and the HR-07 solution
And I was pretty happy with it
Only a couple of hours running this board and everything comes so easy
The board is very easy to tune
Excelent voltage options
Everything seems so natural
