Does anyone have any link or guide to a proper 8800GTX volt mod guide? I would be really interested to try it. And when I say a proper guide I mean other than the ancient VR Zone one.
here is a list of pic i got
1
billdavis,
thanks for the pictures! I was trying to find more detailed pictures of this mod.![]()
let us know how it goes! i did one and got 740mhz on water but killed the card buy accident
1
what Voltage was your GPU/Mem at when it died?
"If It Doesn't Overclock Its Broken"
"NexGen Overclocking"
"Overclocking, its a life style"
I've tried to raise the Vgpu up to 1.6V but can only get 5 - 15 MHz increase in GPU clock.
Same as the Vmemory.
Does anyone has the same problem with me ?
Is there an OVP for this card ?
i7 920 D0
eVGA X58 Classifieds
GSkill Trident 1600C6 3x2GB
GTX295 Quad SLI
Hitachi SATA2 1TB
Viewsonic VX1962WM
FSP Kingcraft 1010W
Vista 64bit
http://www.madshrimps.be/?action=get...197&howtoID=72
As the article states, there might be some protection mechanism...
What's your current max oc for core/shader/memory and your voltages, Dihon?
My Core stucks at 660MHz @ 1.45V, haven't change the shader clock so it default.
But I don't check the speed at 660Mhz core.
Memory limited to 975Mhz @ 2.2V.
@ madshrimps said : OVP is only for GTS not GTX ??
i7 920 D0
GTX295 Quad SLI
Hitachi SATA2 1TB
Viewsonic VX1962WM
FSP Kingcraft 1010W
Vista 64bit
You need the OVP mod to go over 1.6v. It is a tricky mod to you gotta be a good solderer. You shouldn''t be running above 1.6 unless your on ln2 though. Also switch the read point for the vgpu to the next one over. People have had bad luck with the way its pictured.
Originally Posted by 3oh6
Originally Posted by Brian y.
i7 920 D0
GTX295 Quad SLI
Hitachi SATA2 1TB
Viewsonic VX1962WM
FSP Kingcraft 1010W
Vista 64bit
if your on air thats what I'd say is holding you back
1
The pics billdavis posted are the same ones I used to do my vmods. I also added a ground pin to the molex from one of the power connectors and you should also glue or tape your wires down because the solder joints (especially the memory) are so small that they are easily broken. I also found that my 3dmark06 score peaked at 729core even though my card can do over 750@1.5v 2.05v gives me the most from the memory which creeps up .06v under max load (2.11) good luck.
right now @ ~1.5 volts i can run ~720
1
HELP!!!!
I just did the volt mods to my Evga 8800GTX card and i have a small tiny prob.. I broke that damn tiny black resistor thats used for the GPU volt mod!
Now i have a few spare card lying around that i can use for parts.. Just find the identical size black resistor? Or could i just use a fixed resistor to replace it?
Oh btw.. Broke the damn thing by tuggin on the soldered wire trying to move another wire that was runing under it. Just tore that resistor right off and it looks like it snapped the end so i dont think i should use it again.
Running now, http://www.evga.com/forums/tm.aspx?m=693435
Intel 3960 @ 5Ghz
Asus Rampage IV Extreme
QuadFire 7970
X-Fi Sound Card
16GB G.Skill 2133Mhz DDR3 Quad Channel Ram 9,11,10 @ 1.65v.
3 Acer 23" 3D Ready LCDs
2x Ultra X4 1600 WATT P/S 's
MM Extension Ascention UFO Case W/ Top of the line Water cooling. Dream build!
Can anyone tell me what the value of this resistor is thats used in this volt mod?? The resistor i have is damaged so i cant use it.
Intel 3960 @ 5Ghz
QuadFire 7970
X-Fi Sound Card
Check your other post on this.
Hello , i am french and new on this very good forum and i have a question for you .
I did the vmod for the 8800 GTX to reach 1.5 V for the GPU but i can't do better score than without the vmod . I am limited at 648 mhz .![]()
I don't understand why because i am using a waterblock for the 8800 , so i don't think what the temperature is the limitation . In fact i reach only 66° Degrees for 648/1674/2160 mhz.
My PSU is an old seasonic S12 600W witch can only deliver 36 A for the 12V line .
On my PC , i have also a E6600 turning at 3400 Mhz for 1.4 volt , 2 DVD driver and 4 hard disc .
So , do you think i should change it for a most powerful one to do better score with my GTX ?
Is anybody here had been yet limited by his PSU ?
Thanking you in advance for your answer .
