Page 1 of 4 1234 LastLast
Results 1 to 25 of 100
Thread: Gigabyte P35-DQ6... 500MHz FSB NO PROBLEM! + dual 32M 603MHz 4-4-4-5 RAM STABLE!
    Xtreme X.I.P.
    Dec 2005
    Here are some shots of my P35-DQ6.
    Overall, it is a nice board, few quarks here and there. Early testing allowed me to easily sail past 500MHz FSB on a dual core E6320.
    I will update the following shortly:
    1) How to remove crazy cool on the back of the board correctly
    2) Max FSB, Max RAM tests
    3) More pics!
    4) Any requests anyone has (sorry I dont have any quad core CPU's atm, so cant test that)
    ICS 9LPRS587EGLF clockgen
    Realtek ALC889A audio codec
    Classic TI firewire, very curious how this performs against the Agere FW3227 P5k deluxe counterpart
    Heatpipes galore.
    Scythe Ninja fits
    Thermalright Ultra-120 fits
    Tuniq Tower ALMOST fits, fan hits heatpipe above northbridge, fits enough to get by
    They kept the same I/O layout from their P965-DQ6. I personally like the way asus refreshed the rear, I think gigabyte should at least ditch the printer port and add some E-SATA ports. Dual NIC's wouldnt be bad either.
    Realtek PCI-E Ethernet
    Every cap on P35-DQ6 has a plastic skirt on the bottom for perfect seating and alignment. Something you dont see on any other boards.
    Take note of the screws that secure the north and south bridges. Unlike other boards that use plastic clips, you can remove a little more heat with a tighter clamp.
    Not sure why they use a MITSUBISHI battery made in China when all other major mobo makers use batteries made in Japan. This sorta bothers me.
    ISL6327 enhanced 6-Phase PWM (BUCK) Controller, exciting stuff...
    For reference, the P5K Deluxe I have uses an Analog Devices ADP3198 4-Phase Buck controller
    Gigabyte DUAL BIOS
    TUNIQ TOWER Clearance issues-
    CPU: Intel CORE 2 Duo E6550 @ 3.6GHz w/ 1.29vcore (517*7)
    Motherboard:
    Gigabyte P35-DQ6
    Memory:
    Crucial 8500's
    Video:
    Nvidia 8800GTX
    PSU:
    Zippy 700W (fan modded of course)
    Xtreme X.I.P.
    Dec 2005
    BIOS photos (coming soon)-
    gigabyte has made a LOT of BIOS improvements, while there is room for improvement... well just check out the photos, you will see why it is cool
    This is by far the COOLEST bios feature that gigabyte has introduced. 8 NAMEABLE profiles to save your settings in. Excellent for us RAM benchers.
    Standard stuff here, the key is remembering to disable that (C1E) and Thermal Monitor... dont want anything to get in the way of my overclocks
    Lame that they dont report voltage, not that it is very accurate anyway. My DDR2 fails, since it is set to +.65
    to see ram timings in gigabyte boards, just hold down ctrl+F1 in the main screen
    700MHz max FSB... sadly, I cant hit that
    150MHz FSB for PCI-E, no limits there either
    nice range of mults for the memory
    not sure what this does
    I think it should read XTREME instead of EXTREME, but that is just me. Not sure how this works either.
    Lots more voltage
    more voltage
    For those that really need 3.35V of ram voltage. I should note that my multimeter reads about .1 over what it is set. So 2.45 (+.65) reads 2.55 on my multimeter.
    More voltage than is really needed, for pretty much any situation. cant complain though, i like options.
    Some decent screen shots-
    Yes, P35-DQ6 got some ram clocking ability. What was only reserved on ASUS boards and 680i boards we see on the P35-DQ6! 4-4-4-5 @ 603MHz DUAL 32M stable (2.5vdimm in bios, 2.6Vdimm REAL)
    This is using top bin crucial ballistix 8500.
    500MHz+ on the FSB is easy. I hit a wall at 525, not sure if it is the CPU. Same CPU in a commando hit ~550, ill try other CPU's.
    Motherboard:
    Gigabyte P35-DQ6
    Memory:
    Crucial 8500's
    Video:
    Nvidia 8800GTX
    PSU:
    Jul 2006
    Total n00b, but what are those green pins stack up on each other for? The ones in the first picture that look like jumper pins to the left of the "SilentPipe".
    Jun 2006
    holy heat pipes batman!
    Xtreme X.I.P.
    Dec 2005
    Quote Originally Posted by PrometheusCon View Post
    heh, that is for the front audio.
    Gigabyte made it extra long because of the heatpipe. This way you dont really have to fight plugging it in.
    Motherboard:
    Gigabyte P35-DQ6
    Memory:
    Crucial 8500's
    Video:
    Nvidia 8800GTX
    PSU:
    Memory Addict
    Aug 2002
    Brisbane, Australia
    nice.. now the big question for me.. in bios will it show actual voltage/temps instead of the traditional ''Ok"
    Apr 2005
    Norway
    Hi nice post, with some good lookin pictures
    For u intrested.. I`m posting some Quadresults here
    http://www.xtremesystems.org/forums/...d.php?t=144365
    RIG 1:[Intel® Core i7-3960X Extreme][Asus Rampage IV Extreme][16GB G.Skill RipjawsZ ][AMD HD 7970 CF][Corsair AX 1200W][Corsair Obsidian 800D][Custom Watercooling][Dell U2711)
    RIG 2:[Intel® Core i7-990X Extreme @4.6Ghz][Evga X58 Classified 760][12Gb Muskin Redline][EVGA GTX 580SLI][TT TP1200W][Lian Li V2000BPLUSII] [Custom Watercooling][Dell U2711]
    RIG 3:[Intel® Core i7-2600K@4.4Ghz][ASUS P8H67 B3][8 GB Corsair Vengeance] [Evga GTX 570SLI][Corsair AX 850W][Lian Li V2000BPLUSII][Corsair H70][Custom Watercooling][Dell 2407wfp]
    RIG 4:[Intel® Core 2 QX9650 Extreme @4.0Ghz][ASUS P5E3 PRO INTEL X48 ][8GB Muskin Redline][MSI GTX 470][Corsair AX 850W][Lian Li V2000BPLUSII][Custom Watercooling][Dell 2407wfp]
    May 2006
    Philippines ^_^
    is it real copper??? or painted??
    Asus P5W64 WS Professional , DFI Infinity 965P-S (testing)
    X6800 , E6750 es
    Micron Fatbodies , Micron D9gkx oem, Crucial 8000, Crucial Tracer 8500 (incomming)
    Ati FireGL V5100, Elsa FireGL V3100
    water cooling setup (EK 775 cpu block, swiftech NB Block, Swiftech pump, BI dual pass dual 120mm)
    Silverstone OP650
    raptors, baracuda
    Xtreme Mentor
    Jan 2005
    Quote Originally Posted by irev210 View Post
    Gigabyte DUAL BIOS
    Thats not the dual bios, its the two larger chips close the clear CMOS jumper.
    Gigabyte EP45-DQ6 - rev 1.0, F13a bios | Intel Q9450 Yorkfield 413x8=3.3GHz | OCZ ProXStream 1000W PSU | Azuen X-Fi Prelude 64MB X-RAM| WD VelociRaptor 74HLFS-01G6U0 16MB cache 74GB - 2 drive RAID 0 64k stripe | ASUS 9800GT Ultimate 512MB RAM (128 SP!!) | G.SKILL PC2-8800 4GB kit @ 1100MHz | OCZ ATV Turbo 4GB USB flash | Scythe Ninja Copper + Scythe 120mm fan | BenQ M2400HD 24" 16:9 LCD | Plextor 716SA 0308; firmware 1.11 | Microsoft Wireless Entertainment Desktop 8000 | Netgear RangeMax DG834PN 108mbps; firmware 1.03.39 + HAWKING HWUG1 108mbps USB dongle | Digital Doc 5+ | 7 CoolerMaster 80mm blue LED fans | Aopen H700A tower case | Vista Home Premium - 32bit, SP1
    Xtreme Mentor
    Jan 2005
    Quote Originally Posted by eva2000 View Post
    It just shows "OK"..the early 965P-DQ6 bios used to show the actual voltages, but they removed it...pity.
    Xtreme Mentor
    Jan 2005
    Please post how you accomplished 500x7...as in what bios options you altered.
    To reach 444x7 i adjusted the Vcore to 1.3750V and increased the DDR2 voltage to +0.4V, as in 2.2V.
    I left the (G)MCH/FSB and PCI-E voltages set to Auto, PCI-E frequency was also set to Auto. Memory timings were manually adjusted to 5-5-5-12.
    Apr 2005
    Melbourne, Australia
    Nice clear photos, thanks for sharing irev210.
    Signature? are you kidding? with new stuff coming out every day, why bother ?
    Xtreme Guru
    Dec 2006
    Philly/NJ
    id buy it just for the fact that they put plastic skirts around all the caps, now thats quality!
    I am Xtreme
    Feb 2005
    SiliCORN Valley
    thats just the way their doing the Solid capacitors.
    its a new way thats for sure but i think its a mfg upgrade to install them easier.
    also prevents caps from being bent over.
    but it is cool for sure.
    "These are the rules. Everybody fights, nobody quits. If you don't do your job I'll kill you myself.
    Welcome to the Roughnecks"
    "Anytime you think I'm being too rough, anytime you think I'm being too tough, anytime you miss-your-mommy, QUIT!
    You sign your 1248, you get your gear, and you take a stroll down washout lane. Do you get me?"
    Heat Ebay Feedback
    Apr 2006
    Brasil
    Quote Originally Posted by Richard Dower View Post
    Those are the dual BIOS indeed. Gigabyte now uses a serial bus based flashrom for BIOS and there are two of them.
    May 2006
    UK
    Quote Originally Posted by doompc View Post
    no he means these two ICs are the BIOS chips
    i5-750 w/ Thermalright Ultra120X
    Coolermaster HAF-932
    MSI GD65
    2x2GB G.skill Cas7 1600MHz
    Sapphire HD6870
    Western Digital 640GB.AAKS
    2x Samsung F1 1TB
    2x Samsung SLC 64GB SSD
    Pioneer DVR-212BK
    Corsair HX620W
    Creative X-Fi Xtreme Music (dead, using onboard -.-)
    LG W2286L
    Xtreme X.I.P.
    Dec 2005
    Hi Richard, the two larger chips you are refering two are Pericom P12PCIE switches used for ATI Crossfire.
    This is so you dont have to manually use jumpers or a slot card (like on nvidia 650i) to configure SLI/Crossfire.
    I am still testing the board, but I hit a firm WALL at ~525. Not really sure what is causing it. On the P5k deluxe, same wall is ~535.
    It could be the CPU, but this same CPU I was able to do 550 on ASUS commando. I will try other CPU's later such as E4300 and E6420.
    Motherboard:
    Gigabyte P35-DQ6
    Memory:
    Crucial 8500's
    Video:
    Nvidia 8800GTX
    PSU:
  18. #18
    Oct 2002
    Wisconsin
    Really nice looking motherboard. I almost had mine last night but FedX screwed up and dropped it off at the wrong place and can't find it.
    eVga 780i SLI
    E8400@4.2ghz(483x9)@1.44v Cooled by Coolit Elite
    2xXFX Alpha Dog Edition 8800GT's 702/1890/2000 on stock cooling.
    2x1GB OCZ pc8500 4,4,4,12 1T@2.75v
    2xWD 150GB Raptor-X in Raid-0
    PC Power & Cooling 750Watt Quad Silencer
    Creative X-Fi ExtremeMusic
    Samsung 244t 24" Widescreen LCD
    20,001 3DMark06 WinXP SP2
    http://valid.x86-secret.com/show_oc.php?id=302461
  19. #19
    Mar 2007
    The plastic skirts around the caps, will those prevent whining or squealing? How quiet is this board in that regard?
  20. #20
    I am Xtreme
    Oct 2005
    Grande Prairie, AB, CAN
    The heatsinks look silly but they do look like they'll do a very good job.
  21. #21
    Feb 2007
    Indonesia
    Thanks for info...Benchmark please..
  22. #22
    Xtreme X.I.P.
    Dec 2005
    Quote Originally Posted by mrcape View Post
    The skirts are just a fancier way to mount. I cant talk about all the advantages simply because i dont know them... but these skirts are what you see on high-end electronics.
    I think the squealing comes from coils, someone maybe able to answer better. To me, this board is dead quiet, but I wouldnt know until I put a quad core with 1.5Vcore+
    Quote Originally Posted by lowfat View Post
    The key is the fact that they are clamped with screws, not push-pins. I think this helps in a HUGE way.
    Motherboard:
    Gigabyte P35-DQ6
    Memory:
    Crucial 8500's
    Video:
    Nvidia 8800GTX
    PSU:
  23. #23
    Dec 2006
    AAAAAAARGH,choices,choices....All those mobo's and i still haven't a clue what to pick....I'm buying around august and so far i had 4 mobo's picked out for my rig,untill this board and teh Msi P35 came out...And now,i still haven't a clue lol
    Quote Originally Posted by verndewd View Post
    Then we devise an nda breaking method that reroutes the broken nda from china and points to a pig name zhiang in a mud pit in hubei farmlands. The pig would have to have no owner.
    This can be done.
    SPECS:TT Kandalf LCS Case,Asus P5K Deluxe mobo,Intel Q600 CPU,XFX 8800Ultra,Samsung 500Gb HD,Gskill PC6400 ghz memory,Nec DVD-Writer,Creative Xfi Xtreme Music, Corsair HX620Logitech:G15 keyboard,MX518 mouse and Z-5450 Speakers
  24. #24
    Feb 2005
    Smurf in My Loop
    Wow great pics, subscribed. Keep 'em coming!
    MSI Big Bang XPower
    Core i7 930 @ 3.38 Ghz
    6 x 2GB Patriot DDR3 1600
    XFX Double D 7850
    Therltake Toughpower 1200
    Thermalright Ultra 120 Extreme
    OCZ Revodrive 3 120GB
    Corsair 700D
    Dell 2405FPW
    W7 Pro 64 bit
  25. #25
    Xtreme X.I.P.
    Dec 2005
    Quote Originally Posted by bloodbanger View Post
    P5K Deluxe is an excellent board. My board died shortly after installing for no reason, but I am RMA'ing and have a new one coming shortly.
    Right now I cant recommend. Stick with a 965 based chipset or hang in there for another month. Then decide.
    Motherboard:
    Gigabyte P35-DQ6
    Memory:
    Crucial 8500's
    Video:
    Nvidia 8800GTX
    PSU:
