Page 1 of 2 12 LastLast
Results 1 to 25 of 27
Thread: VISTA Control Panel wont open, Computer properties wont open, Aero Glass doesnt work?
    Xtreme Guru
    Aug 2005
    Burbank, CA
    Ok i booted up my new install of WINDOWS VISTA HOME PREMIUM and today all of a sudden, my control panel wont open, my compute properties will not open and aero glass does not work, they are all tied together, what is the cause of this? and is there a fix for it? all i can say is WTF MS???? any help would be appreciated, thanks.
    Apr 2007
    Virtually...Everywhere; Physically in US
    Quote Originally Posted by GAR View Post
    pinging you directly...
    Apr 2005
    check your event logs something there will help you.
    Gaming: SaberThooth X79,3930k,Asus6970DCII_Xfire,32gb,120OCZV3MaxIOPS, ThermaTake Chaser MK1
    HTPC:AMD630,ATI5750,4gb,3TB,ThermalTake DH103
    Server: E4500,4GB,5TB
    Netbook: Dell Vostro 1440
    Moderator
    Nov 2006
    try reinstalling your graphics card drivers.
    May 2007
    run the vista index test again - this will check the score and automatically enable all the eye candy. My computer - righ-click-properties and re-score ur PC.
    Xtreme Guru
    Mar 2004
    steelcity.pa.usa
    you have to Stop two services and restart them, and then it works fine. one of the services is Software Licensing, if you can give me a screenshot of the services.msc window with all the services starting with S, i can tell you what the other services you need to stop and start is.
    EDIT:
    finally found it....... that was driving me insane!
    Here is the fix.... i had to do this a couple times since control panel would be blank whenever i rebooted, then it just seemed to keep working.
    1) Launch services.msc from a run command
    2) Find the SLUNotify service & stop it
    3) Find the Software Licensing service & stop it (it may say that ReadyBoost needs that service to run; stop it anyway)
    4) Restart both services, starting with Software Licensing
    STARSCREAM
    3570k @ 4.6 GHz | Asus P8Z77-V LK | G.Skill F3-12800CL8D-8GBXM | ASUS GeForce GTX550 Ti
    Corsair Neutron GTX 240GB | Corsair Force GT 120GB | SK hynix 128GB | Samsung 830 64GB
    WD Black 640GB (3) | Seagate 7200rpm 1TB | Dell Perc H310 xflashed to LSI 9211-8i
    Corsair AX750 | CoolerMaster Hyper 212 | Antec P280 | Dell Ultrasharp U2410 | BenQ XL2420T
    ROCCAT Savu | Filco Majestouch-2 TKL w/Cherry MX Reds
    MEGATRON
    3770k @ 4.5GHz | Asus Sabertooth Z77 | G.Skill F3-12800CL8D-8GBXM
    SK hynix 128GB | Mushkin Enhanced Chronos 60GB | WD Red 3TB (4) | Seagate 7200rpm 3TB (2)
    WD Green 2TB (3) | Seagate 7200rpm 1TB | Dell Perc H310 xflashed to LSI 9211-8i (2)
    Corsair AX650 | Corsair H80i
    Xtreme Guru
    Aug 2005
    Burbank, CA
    Vista control panel, and computer properties wont open?!?! any ideas???
    Hey, vista runs smooth and stable for the most part, but when i try to access control panel it opens and closes very quickly, preerty much refuses to open, also when right click on computer and try to go to properties, that also doesnt open, windows update doesnt work as well, sometimes when i restart it starts working fine again, and other times it just wont open, any ideas?? anyone else go through this????? thanks.
    Also this started to happen after activation, i have the Vista Home Premium OEM copy, and yes it is a legal copy that i purchased, do not ask me if its a downloaded version, if anyone can help me i would appreciate it, in safe mode they open up properly....
    Xtreme Mentor
    Sep 2006
    Running nVidia drivers? This is a common problem I think for that. Mine has fixed itself in the last few weeks. Either way it is known. Make sure you get all the Vista updates first, that may fix the issue.
    Solution:
    Go to run command line.
    Type services.msc
    Go to software licensing. Turn it off. Now turn it back on.
    Now go to SL UI Notification. Turn it on if it isn't already.
    That should fix it until you power down the comp.
    Xtreme Guru
    Aug 2005
    Burbank, CA
    yes im using nvidia drivers.....
    i just tried that solution, the SL UI wasnt even running, it was on manual and i started it and stopped it, same thing tho, also i am trying to retype my key from the command prompt using the command slmgr.vbs -ipk <key> says syntax of the command is incorrect.
    Xtreme Mentor
    Sep 2006
    My order may be wrong. Google the problem. I had the same thing a while ago and solved it by googling.
    Xtreme Guru
    Aug 2005
    Burbank, CA
    Quote Originally Posted by Speederlander View Post
    I have tried googling, couldnt find anything, do you have the link please? thanks
    Xtreme Guru
    Aug 2005
    Burbank, CA
    ok so i figured a way to get it working intill i reboot, stoping and starting the service software licensing seems to solve it, but what is the long term fix i am still curious to know, because this is annoying.....
    Jun 2007
    Manitoba, Canada!
    wow, i was having the same problem!!!! im running visata ultimate.
    my 3d scroll didnt function, and my control panel kept popping up.
    so i can fix it by doing the same, i also need to rerun the readyboost, as it disables when you stop/restart software licensing..... so, how can i have this work each time i restart windows??? i would hate to manually have to stop/start the service just to get it to work properly.
    on second thought, this all started when i added a ready boos thumbdrive yesterday... maybe if i remove it, itll run properly.
    May 2007
    Lots of people are having this problem, including me. Here is another discussion going on right now over at hardocp forums.
    Nov 2005
    PHX
    Stopping and starting software licensing fixed the issue for me. Have you found anything else out?
    check your pm
    I am Xtreme
    Apr 2005
    Upstate, NY
    When this happens to me I just reboot the PC & its fine afterwards
    Core i3-550 Clarkdale @ 4.2GHz, 1.36v (Corsair A50 HS/F) LinX Stable
    MSI H55-GD65 Motherboard
    G.Skill 4GBRL DDR3-1600 @ 1755, CL9, 1.55v
    Sapphire Radeon 5750 1GB
    Samsung F4 320GB - WD Green 1TB
    Xigmatek Utgard Case - Corsair VX550
    Xtreme Guru
    Mar 2004
    steelcity.pa.usa
    also, this bug was fixed in a Hotfix released in mid May i believe.
    STARSCREAM
    MEGATRON
  18. #18
    Xtreme Guru
    Aug 2005
    Burbank, CA
    Quote Originally Posted by [XC] itznfb View Post
    I have all the latest updates installed, and i still get this sometimes.....do you have a link to the hotfix, maybe i have not installed it yet.
  19. #19
    Xtreme Guru
    Mar 2004
    steelcity.pa.usa
    i could have been wrong about that. i read the hotfix details when they install with windows update, and i could swear one installed in may described this issue, but i can't find it in my update history. i'll keep researching.
    STARSCREAM
    MEGATRON
  20. #20
    Xtreme Guru
    Aug 2005
    Burbank, CA
    Cool, thanks man, much appreciated.
  21. #21
    Xtreme Guru
    Aug 2005
    Burbank, CA
    here is the fix guys, article number KB929637...cheers, if anyone needs the fix just pmme.
  22. #22
    Xtreme Guru
    Aug 2005
    Burbank, CA
    here is the fix guys, its article KB929637...... cheers
  23. #23
  24. #24
    Xtreme Guru
    Aug 2005
    Burbank, CA
    no, but this is the hotfix, wich also addresses the control panel issue.
  25. #25
