this is the first time i modded a case and first time i ever played with watercooling i read lot of reviews and did the best i could take a look and tell me what u all think.
MY RIG: BLUE DEVIL
CASE*BLACK SILVERSTONE TJ07-MODIFIED
MONITER*32-INCH SAMSUNG WIDESCREEN LCD TV
OS*MICROSOFT XP HOME EDITION SP3
MB*GIGABYTE P35-DQ6 F9B BIOS
CPU*INTEL E7200 3.6GHZ 1.3v
RAM*2GB G.SKILL PK PC8500**DEAD**
PSU*PC POWER&COOLING BLACK QUAD 750W
HD*SATA MAXTOR 150GB 8MB CACHE & SATA WD 250 GB 16MB CACHE
GPU*GIGABYTE HD4670 @ 811/1100
MY WATERCOOLING SETUP
CPU*SWIFTECH APOGEE GTZ
PUMP*SWIFTECH MCP 655
RAD*SWIFTECH MCR320 W/ 3 SCYTHE ULTRA KAZE MED. SPEED
RES*T-LINE
TUBING*DURELENE PVC
COOLANT*DISTILLED WATER & PT NUKE
WORKLOG-Blue Devil TJ07
idle temp for 3375Mhz
load temp for 3375Mhz
MY RIG: BLUE DEVIL
RES*T-LINE
TUBING*DURELENE PVC
looks pretty damn good to me for a rookie...LOL...way to go man....looks awesome!
750W Thermaltake Modular PSU
DFI UT X58-T3eH8
Core i7 920 @ 20 X 200 1.325V
CORSAIR XMS3 DHX 4GB (2 x 2GB) DDR3 1600
768 MB EVGA 8800GTX
1 X 36GB WD Raptor
2 X 150GB WD RAPTORS
1 X SpinPoint P Series SP2504C 250GB
1 X Maxtor 6L300S0 300GB
16 X NEC DVD Burner
7 120mm Yate Loon LED Intake Fan
4 120MM Yate Loon Exhaust Fan
28" HANNSPREE Monitor
Watercooling Loop:
1 X PA120.3
1 X PA120.2
2 X Laing DDC's w/EK-DDC Dual Turbo Top
7 X Yate Loon Blue LED Intake Fans
4 X Yate Loon Blue LED Exhaust Fans
1 X Swiftech GTZ
1 X GPU EK Fullcover Waterblock
1 X XSPC Dual Bay Reservoir 5.25" with Bubble Window
what fans are you using on your MCR 220? And at what RPM are they running? Are you using a shroud? Where's your rad located at?
Those are pretty nice temps...
MY RIG: BLUE DEVIL
RES*T-LINE
TUBING*DURELENE PVC
rad looks like it is on top of case...looking at the 4th pic...looks like no shroud...
DFI UT X58-T3eH8
768 MB EVGA 8800GTX
1 X 36GB WD Raptor
16 X NEC DVD Burner
Watercooling Loop:
1 X PA120.3
1 X PA120.2
1 X Swiftech GTZ
nice temps...
next on the mod change all 80mm fans to 120mm and watercool that gpu card too...
was going to try but when i measured i didnt have enough space to put 2x 120mm in back i would only be able to fit one and i would have had a ugly looking mad after cutting and as far as the gpu i am fine where its at it runs cool at 49-52c idle i have applied ceramique on gpu and thermal tape on memory but will consider water because i am upgrading to a gtx
MY RIG: BLUE DEVIL
RES*T-LINE
TUBING*DURELENE PVC
you did the best with what you had to work with ......and what you have is a great looking rig . wish my 1st attempt at wc had looked like that
D-TEK fuZion/ 8800 GTS block/ PA 120.3/ PA 160/LATE YOONS D12 SM/2x D-5
Do not walk behind me,Originally Posted by MaxxxRacer
. for I may not lead.
Do not walk ahead of me,
. for I may not follow.
Do not walk beside me either.
. Just pretty much leave me the hell alone!
Looks great man!![]()
Intel E8400 Wolfdale
4 Gb OCZ Flex
8800 GT
Abit IP35 Pro
530w Tagan
Apple Core Duo Project Log @ Bit-tech.net
Simply awesome, great job! 1 quick question though: To make it easier for you the next time you fill your loop up, put the res a little higher then the pump in let. I'm assuming now when you go to fill your loop, you fill up the res, then tilt the case toward the pump?
Nothing anymore
Nice Mods man..
its looking uber awesome![]()
Sound: Asus Essense ST | Wharfedale Diamond 9.1 | Norge 2060 Stereo amp | Wharfedale SW150 sub (coming soon)
Camera Gear: Canon 6D | Canon 500D | Canon 17-40L | Canon 24-105L | Canon 50mm f1.4 | Canon 85mm f1.8 | Rokinon 14mm f2.8 | Sigma 10-20EX HSM | Benro A3580F + Vanguard SBH250 | Bag full of filters and stuff
Looks niceI think if you try draining a big of the PC ice, then replacing it with water, you'll see an improvement
Lenovo Thinkpad X220 - Core i5 2410m, 4gb
waiting on 28nm video cards...
MY RIG: BLUE DEVIL
RES*T-LINE
TUBING*DURELENE PVC
I'd try to get rid of as much of it as possibleSome guys had PC Ice and they said its viscosity was damn high compared to water, and switching to water improved temps by a good bit. Do you still care about the color? The best coolant is water plus some algaecide (preferably this? http://www.petrastechshop.com/pepcobi1.html) and for the bling, add some dye. Its a shame jab-tech doesn't stock their old dye, the D-tek stuff is more expensive...
Well Frozen CPU still has theirs for 5 dollars. http://www.frozencpu.com/products/17...tl=g30c103s186
7.5 shipped for the dye, 5 shipped for the PT nuke, and some water (what? 30 cents???) and you'll see a drop in temps![]()
actually he wont. PCice is pretty good IMO.
I used it b4 and i didnt see that much of a difference from straight distilled. Its nothing like fluidXP.
I personally wouldnt change it. Its expensive coolant that actually somewhat works. You could get simular temps for less cost, but better wont be by much.
And also ranker is correct. It was shown by niksub that having the GT lined up so the barbs are up and down will actually increase its performance and drop your temps by a 2-3C. This was discovered accidentally by nikhsub. But later realized its because the cores are lined vertically, and hence in the path of the direction of flow of water.
Beautiful machine... except I have to cover my prejudiced eyes.. "Toughpower"![]()
Awww come on, those PSU's have got nothing but good reviews. Especially their 1200 Watt version. Yes Thermaltake USUALLY makes some crap products, but these new PSU's are a step in a different direction for them. If you can afford it, it's one bad @ss PSU.
http://www.jonnyguru.com/review_details.php?id=107
http://www.overclockercafe.com/Revie...00w/index.html
http://enthusiast.hardocp.com/articl...50aHVzaWFzdA==
I'm not going to argue with you because its pointless. I should ask Hard H20 to comment. He recently lost a new $500 server motherboard because of a new ThermalTake Toughpower PSU. I think it was a 850watt model.
Anyway, it doesn't matter what I think, although I do not have a high regard for CWT PSUs. I did pay more for my PSU than the $400 price of the Toughpower 1200w.
toughpower is pretty good its been doing good for me but what do you think of the pc power & cooling psu
MY RIG: BLUE DEVIL
RES*T-LINE
TUBING*DURELENE PVC
What's your room temp??
Your temps is very good for me
My e6400@3.0 1.38v
Idle 34-35
Load ortos After 1hour 40 41
Why my idle temps is so high??
Room temp:27-28
Intel Core i7 930@ 4.0Ghz | Gigabyte EX58-UD4P | 3x2Gb OCZ 1600mhz | Palit GTX280 | 1TB Seagate | Samsung P2350 23'' | Silverstone Decathlon DA750W | Lian-Li PC777B | Logitech Z-5500 | Creative X-Fi| Iphone 4
Hardwarena Overclock Team
There's one problem with your loop setup. You need to reorient your GT block. You'll get better temps with the "Swiftech" label in the upright position.
MM Extended U2-UFO CYO (Duality front, Standard back, Horizontal Mobo brace) Anodized Black || eVGA X58 || Intel i7 920 || 6 GB Corsair Dominator PC3-12800|| eVGA 295GTX || Asus Xonar Essence STX || VisionTek 650 TV Tuner || 1 300GB WD Velociraptor || 1TB WD's Black Ed. || LG 22X DVD-Writer || Lite-On 20x DVD-Writer || Corsair CMPSU-1000HX PSU
CPU Loop: DDC-2 w/ XSPC Reservoir Top -> Swiftech GTZ -> Thermochill PA120.3 (Push: 3 Scythe S-Flex G)
GPU Loop: DDC-2 w/ XSPC Reservoir Top -> (Koolance VID-NX295 FC block) ->Thermochill PA120.3 (Push: 3 Scythe S-Flex G)
Chipset Loop: DDC-2 w/ XSPC Reservoir Top -> Alphacool Silentstar Dual HD waterblock enclosure -> Bitspower Black Freezer eVGA x58 MOSFET-> Bitspower Black Freezer eVGA x58 NB -> Thermochill PA120.2 (Pull: 2 Scythe S-Flex G)
2 x Dell 2408FPW LCD || Logitech Z-5500 Digital 5.1 || Logitech G9 Mouse || Logitech G15 LCD Keyboard || Logitech Quickcam Ultravision || Sennheiser Headphones
I agree. Nice setup. Beats my idle temp. I get around 35 with coretemp. My first water setup looked like crap.
