Mushkin 4GB HP2-6400 Test Report
About two weeks ago, Mushkin launched a new 4gb kit, HP2-6400 5-4-4 modules, designed for both high-performance and value. This kit is priced lower than the 4GB XP2-6400 and 4 GB XP2-8500 kits, (currently at $345 on Mushkin site & Newegg). I got the chance to test a set of this stuff and I must say I am quite pleased with the performance especially in this price range.
That being said, here is your Mushkin HP2-6400 Redline (part 996564) test report:
First I’ll start with a few words on the test platform and shots of the RAM and board. I’m using an E6600 Conroe setup with a DFI LANParty UT ICFX3200-T2R (RD600). The HP2-6400 uses the FrostByte™ (blue) heatspreader spreaders and comes with Mushkin’s new packaging.
Test bed
E6600
BFG GeForce 7800GTX @ stock
Mushkin XP-650
Windows XP, 32bit, untweaked
CPU Cooling - Custom H20 and stock cooler on the NB
RAM Cooling – 120mm Panaflo
Testing methodology:
I don’t plan on killing this kit quite yet so I am sticking to 2.3v for the time being. If I get ambitious later on, Ill run a few 2.4v benches. Also, I realize that I am only using a 32bit OS which can only test a lil over 3gb at a time, however I don’t have a 64bit at the moment so that will have to do for now. Ill try and pick up Vista 64 next week and run a few more tests.
Benches used:
Super PI v1.5 (two instances of 32M)
Tools:
AMD System Manager (clockgen and mem tweeking tool)
Smart Guardian
SetFSB
I am going to test 4-3-3, 4-4-4, and 5-4-4 using 2.0v, 2.1v, 2.2v, and 2.3v for the mem.
Now for some test results:
4-3-3 – 2.0v – 400Mhz
4-3-3 – 2.1v – 435Mhz
4-3-3 – 2.2v – 451Mhz
4-3-3 – 2.3v – 460Mhz
4-4-4 – 2.0v – 411Mhz
4-4-4 – 2.1v – 435Mhz
4-4-4 – 2.2v – 457Mhz
4-4-4 – 2.3v – 472Mhz
5-4-4 – 2.0v – 478Mhz
5-4-4 – 2.1v – 505Mhz
5-4-4 – 2.2v – 534Mhz
5-4-4 – 2.3v – 538Mhz
Summary
A few observations:
1) For secondaries I found that this RAM is quite responsive to loosening trp and trcd a bit. Don’t expect to run the same settings as GMH.
2) tras should be kept above 10 for best results, it actually effects stability in this case
3) Lower drive strength seems to be better than high.
4) CAS has a huge impact on clock speed
Overall I think this is a good bang for your buck if you are looking for a 4gb kit.
