XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme Bandwidth
Reply
Old 05-11-2007, 05:31 PM   #1
Fr3ak
OC Jedi
Fr3ak's Avatar
Send a message via ICQ to Fr3ak Send a message via MSN to Fr3ak
G.Skill F2-8500CL5D-2GBHK
I got a 2Gb kit of G.Skill PC8500 CL5 this week for review. Though I did not have much time to test so far, I want to show you some screenshots and pictures.
Tests are being done on the following:
MB: Asus P5W DH Deluxe
CPU: Intel Core 2 Duo E6600 ES
PSU: Silverstone Olympia 650W
Cooling: Watercooling and a 120mm fan for the memory
Keep in mind that the Intel 975 chipset doesnt clock memory as high as 965 or 680i. The voltage is what I set in bios. Last time I measured Vdimm, it was slightly less than what was set in the bios.
I use SuperPi 32M for the stability tests simply because it does not take that long and has always been a good indicator for stability to me. But nontheless for 24/7 usage some slight adjustments of 5-10Mhz could be needed to have perfect stability.
I will run Orthos or any other stability programs at request.
I am still testing the ram, so the screenshots I will post are not final yet.
I also did not touch the subtimings at all yet.
I am planning to test the ram on a 965 board next week and as it will clock the memory a lot higher I will tweak the subtimings with that chipset.
Memset is only being used to show all the timings, but the timings the benches were run have been set in the bios and booted into windows without changing anything.
I want to thank G.Skill for sending me this kit. So far I am really impressed with this kit. Its even slightly better than my 2GBHZ PC6400. My sticks have Micron D9GMH on them, but I have been told that some sticks even have D9DKX.
The sticks are rated for 2.3V-2.4V. As I sont feel very comfortable running that voltage 24/7, I focused this part of the test on lower voltage.
But enough of the talk, let the pictures speak for themselves now:
__________________
オタク
"Perfection is a state you should always try to attain, yet one you can never reach." - me =)
Fr3ak is offline   Reply With Quote
Old 05-11-2007, 05:32 PM   #2
Fr3ak
OC Jedi
Fr3ak's Avatar
My FTP server is down and I can upload 5 pics per post, wo I have to reserve a few posts.
2.05-2.1V
Have a look at the pictures for timings and other info. I hope i did not forget anything.
__________________
オタク
Old 05-11-2007, 05:32 PM   #3
Fr3ak
OC Jedi
Fr3ak's Avatar
2.20-2.25v
__________________
オタク
Old 05-11-2007, 05:33 PM   #4
Fr3ak
OC Jedi
Fr3ak's Avatar
2.3V and above
__________________
オタク
Old 05-11-2007, 05:33 PM   #5
Fr3ak
OC Jedi
Fr3ak's Avatar
The sweet spot on 975 is around 400-450Mhz for running 24/7, because running memory 1:1 to the FSB results in the best performance.
I will try to do some more testing and post the 965 results as soon as possible.
Edit:
As promised I tested the Ram on 965 today. Unfortunately I only had half a day for the testing, so I focused on 2.4V. With 2.20V ish the 975 results should be almost the same on 965, because the ram is the limiting factor before the memory controller is maxed out.
Sorry for the small screenshots, but I had to use an old TFT.
The test system being used:
MB: Asus P5B-E Plus
CPU: Intel Core 2 Duo E4300
PSU: Seasonic S12 500W
Cooling: Zalman 9700 LED and a 120mm fan for the memory
2.40V
__________________
オタク
Old 05-11-2007, 05:34 PM   #6
Fr3ak
OC Jedi
Fr3ak's Avatar
Reserved for P35 results.
I need a board first, so no eta
__________________
オタク
Old 05-11-2007, 11:29 PM   #7
jmax_oc
jmax_oc's Avatar
"My sticks have Micron D9GMH on them,"
I want a confirmation : do you have D9GMH on your previous PC6400GBHZ or on this current PC8500 GBHK ?
Thanks for the clarification
jmax_oc is offline   Reply With Quote
Old 05-12-2007, 03:14 AM   #8
Fr3ak
OC Jedi
Fr3ak's Avatar
Oh on both
And I have been told by a GSkill emplyee that the 2GBHK eihter have GMH and in some cases even GKX.
__________________
オタク
Old 05-12-2007, 04:07 AM   #9
nibble
nibble's Avatar
Nice results Fr3ak, but I've always wondered why do G.Skill make so many different kits with the same IC's and PCB's?
nibble is offline   Reply With Quote
Old 05-13-2007, 07:41 AM   #10
webwilli
Send a message via MSN to webwilli
mine have D9GMH too:
__________________
Sorry for my bad english...
System1
System2
webwilli is offline   Reply With Quote
Old 05-13-2007, 07:58 AM   #11
nicepun
Hardware Junkie
nicepun's Avatar
Send a message via MSN to nicepun Send a message via Yahoo to nicepun
They look like the Crucial Ballistix!!
__________________
"Once you accept the inevitable, you'll find happiness or at least you won't be too pissed off" -- Nicepun
nicepun is offline   Reply With Quote
Old 05-13-2007, 08:10 AM   #12
Fr3ak
OC Jedi
Fr3ak's Avatar
I was going to test the ram with the Quad GT today, but it doesnt work with the ES CPU I have :/
So I think I will need another 2 days to post 965 results. But I am very confident that it will clock very good on that chipset
__________________
オタク
Old 05-13-2007, 10:24 AM   #13
Bluebeard
"AKA Alonso"
spreader seems to be a mixed design of Patriot and Crucial
Bluebeard is offline   Reply With Quote
Old 05-13-2007, 10:26 AM   #14
irev210
Xtreme X.I.P.
irev210's Avatar
This is a really nice kit, been testing it also. fr3ak, have you tested on p35 bearlake? It works great on my P5k deluxe, but no dice on my P35-DQ6
__________________
CPU: Intel CORE 2 Duo E6550 @ 3.6GHz w/ 1.29vcore (517*7)
Motherboard:
Gigabyte P35-DQ6
Memory:
Crucial 8500's
Video:
Nvidia 8800GTX
PSU:
Zippy 700W (fan modded of course)
irev210 is offline   Reply With Quote
Old 05-13-2007, 10:55 AM   #15
Fr3ak
OC Jedi
Fr3ak's Avatar
Unfortunately I dont have a P35 board yet, but it looks like I will have one within the next 3 weeks.
So far I was only able to test it on 975. The Quad GT didnt like my Conroe-L :/
But I am hurrying up with finishing a rig for a friend, so I can test the GSkills on a P5B-E Plus as soon as I am done.
__________________
オタク
Old 05-13-2007, 11:25 AM   #16
webwilli
i have a P35 board
A quick 4 gigabyte Test:
__________________
System1
System2
Old 05-13-2007, 11:29 AM   #17
irev210
Xtreme X.I.P.
irev210's Avatar
Originally Posted by webwilli View Post
i have a P35 board
yah it works great on p5k deluxe, but not on P35-DQ6. Hopefully a gigabyte bios update will fix.
__________________
Motherboard:
Gigabyte P35-DQ6
Memory:
Crucial 8500's
Video:
Nvidia 8800GTX
PSU:
Old 05-13-2007, 03:06 PM   #18
Hutch
Send a message via AIM to Hutch
i have a P35 board
The TRC is extremely loose on the HK...
__________________
E6400 L624A768 @ 3600mhz 1.48V
Biostar TP35D2-A7
2x1GB Micron D9JKH, 2x1GB OCZ Gold DDR2-1100
1x250GB WD SATAII 2x120GB Maxtor IDE 1x200GB
EVGA 8800GTS 512MB stock 799/1998/2075
MCW350, Apogee, 120.1 Swiftech Rad
Antec Smartpower 500W
BenQ DVDrw
Logitech z-5300e
Hutch is offline   Reply With Quote
Old 05-15-2007, 07:13 AM   #19
webwilli
the GBHK are really nice:
__________________
System1
System2
Old 05-15-2007, 01:27 PM   #20
Fr3ak
OC Jedi
Fr3ak's Avatar
Updated post #5 with 965 results.
I will test them on P35 as soon as I have a board, but I dont know yet when that will be.
__________________
オタク
Old 07-24-2007, 02:42 PM   #21
caesarean
caesarean's Avatar
Send a message via Yahoo to caesarean
mimi Test with LESS Vdimm, ei ei
SYSTEM
E6320, L648G420
Vdimm 1.95V ( 1.925V bios set ),CL5-5-5-15, 2:3
DFI Infinity P965-S DARK, Bios 0703
Zippy Emacs G1-600W
Cooling System : Water & Air Mixed
One-Way Ticket Test eiei
SuperPI 1M, Single
SuperPI 32M, Single
SuperPI 32M, Dual
ORTHOS, Fritz Chess, CPUmark99, HexusPIfast & Lavalys EVEREST
caesarean is offline   Reply With Quote
Old 07-24-2007, 02:52 PM   #22
caesarean
caesarean's Avatar
SuperPI 32M, Single & Dual
ORTHOS
Old 07-24-2007, 03:01 PM   #23
caesarean
caesarean's Avatar
Old 07-24-2007, 04:08 PM   #24
Don_Dan
Don_Dan's Avatar
Send a message via ICQ to Don_Dan
Very nice review. They have the same heatspreader like my G.Skill 6400 HK, G.Skill seems to use this new design on most of their sticks.
If you want to test them on 680i SLI, just visit me!
__________________
Intel E8600 // Gigabyte GA-EP45-UD3P rev 1.0 // Club 3D CGNX-G882DDC // Thermalright Ultra Extreme 120 Black // Western Digital Caviar RE WD1600YS // Thermaltake Toughpower 750W // Lian Li PC-7B PlusII // Samsung 931C
RAM: 3x2GB Mushkin Redline 998750, 2x2GB Corsair Dominator GT 2000C8, 2x1GB Cellshock 1800CL8, 2x1GB Cellshock 1866CL8, 2x2GB OCZ Blade 1066 CL5 LV, 2x1GB OCZ Titanium Alpha VX2, 2x2GB Mushkin XP2-6400 996561, 2x1GB Patriot 6400 CL5, 4x512MB Corsair 8000UL, 5x512MB Corsair 5400UL, 2x1GB Corsair Dominator 6400C4D, 1x1GB Corsair 6400C3, 1x1GB Corsair Dominator 8888C4D, 2x1GB Super Talent T1000UX2G5, 2x1GB G.Skill 6400 HK, 2x1GB G.Skill 6400 HZ, 2x1GB Crucial Ballistix 5300, 2x1GB Crucial Ballistix Tracer 5300, 2x1GB Crucial Ballistix Tracer 8500, 6x1GB Crucial 10th Anniversary 5300, 2x1GB Crucial Value 6400 CL5, 2x1GB FSC Value 6400 CL5, 2x1GB Cellshock 1066CL5, 2x1GB TeamGroup Xtreem 5300 CL3 and 2x1GB TeamGroup Xtreem 8500 CL5 cooled by Corsair Dominator and Dominator GT Airflow Fan
Don_Dan is offline   Reply With Quote
Old 08-05-2007, 06:58 AM   #25
funkflix
Xtreme 3DTeam Member
funkflix's Avatar
Send a message via ICQ to funkflix
Recieved a kit of this rams a few days ago and they beat my two kits of ballistix easily.
__________________
PC : Gigabyte EP45-Extreme + Intel Core 2 Quad Q9550 + Powercolor HD5770 + 2x2GB PC8500 Chaintech Apogee GT + Creative X-Fi Xtreme Music + Scythe Mugen 2.
Digicam : Pentax *istDL2 + Pentax smc DA 18-55mm F3.5-5.6 AL + Cosina F3.5/100mm Makro.
funkflix is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
