Hi there. I lost the last of grain of hope but who knows, maybe I'm simply dumb and I'm missing something in the BIOS. Ok let begin from the start. I'm new to AMD, I sold 2 weeks ago my good old Dothan/AGP system and bought a cheap 3600+ windsor with an ASUS M2N-E SLI for veryvery cheap. The mobo was stable but sucked very hard on the OC side. So I sold the windsor+mobo to a friend for ten bucks less than I paid it, and bought a 3600+ brisbane with a DFI Infinity UltraII-M2.
I liked the board on paper (and pictures), very smart layout, tons, TONS of bios settings. Maybe a little too much for an intel/asus guy like me. The board seems to have good reviews too.
First I tried the brisbane on the M2N-E, what I had was a very stable 2.5/2.6 at default (w/ relaxed HT and DDR2). Nice. Then I plugged everything on the DFI, for the record a SATA RAID0 array, 2*1GB cheap Kingston 667, 8600GT powered by a 450W Coolermaster. And the nightmare started. I don't know if I'm missing something stupid, but I can't almost clock the brisb anywhere without black screens and beeps.
The FSB wall is at 295MHz (w/ chipset @ 1.6v), I tried it with a low CPU multi, relaxed DDR2 and HT (SATA RAID maybe? but I can't even POST -.-, I don't have an OS loading error that seems more an indication of a SATA failure).
DDR wall? should be DDR840 or something, with non aggressive voltages (1.9v).
HT wall? I don't know, I never set the HT multiplier over the stock freq (1GHz) and always run at low multis.
CPU wall? Nope! I had the same brisbane at 2.6 at stock default on the M2N-E SLI and now I can't even set 233 of FSB!!
So what I'm doing wrong? I'm using the DDR400/533 divisor with 5-5-5 and sky high Tras and Trc. I'm using ludicrously low HT frequencies. I've tested the possible limiting factors and all I get is a black screen or beeps.
Suggestions? Don't tell me is the PSU, cause it worked with much much higher loads in the past without any problems, and the system I have is quite simple.
Tnx in advance.
PS
yes, I've the latest BIOS.
