Results 1 to 7 of 7
Thread: Quick P5K Deluxe Quad-core FSB Test
    Feb 2004
    Picked up my P5K Deluxe from Novatech on Tuesday (quick hint to the UK guys, they have stock of the P5K and the Deluxe, and significantly cheaper than OcUK) but had been using my X6800 initially.
    Dropped in my Core 2 Quad Q6600 today to have a little play and currently running Orthos at 7 x 420MHz, 2940MHz overall clockspeed.
    CPU voltage and memory voltage have been tweaked but all other voltages have been left stock.
    Unfortunately my memory is a limiting factor, P35 doesn't offer anything less than a 1:1 memory ratio and I'm stuck with some old DDR2-800 CAS5 which won't go much higher than this.
    Know its not much information but have seen people crying out quad-core for results so thought I might as well throw in what I could
    Aug 2006
    Portrush, Co. Antrim
    480mhz has been reached on the P5K Deluxe with a QX6700 over at the OcUK forums. Looks like 500mhz is possible.
    Q9450 @ 4ghz + ASUS P5Q Deluxe on H2O
    2x36gb Raptors RAID 0, 4gb OCZ PC2-8000
    x64 XP Pro, x64 Vista and x64 Ubuntus SMP goodness
    Q6600 @ 3.8ghz + Abit IP35 Pro on H2O
    XFX 8800GS Alpha Dog, 4gb OCZ PC2-8000
    x64 XP & x64 Ubuntus SMP goodness
    Apr 2007
    Sweden
    not more than 1:1 ? what kind of MB is that
    Intel i7 920@ ???| Inno3D 8800GT OC Edition | 3x1 Corsair 1600 DHX | DFI UT-X58 | TT ToughPower 850W
    Watercooling: D-Tek FuZion V2, DDC Ultra Plexi top, PA120.3, MCW60, Ek's Res.
    Nov 2006
    Does quad demand somehow more from nb or why only 500MHz "might be possible"?
    Feb 2004
    Quote Originally Posted by Cuthalu View Post
    Kentsfield is made up of 2 dice, these place a heavier electrical load on the front side bus and therefore generally do not scale as high as Conroe's.
    I am Xtreme
    Oct 2004
    U.S.A.
    could you post your cpu-z?
    Asus Z9PE-D8 WS with 64GB of registered ECC ram.|Dell 30" LCD 3008wfp:7970 video card
    LSI series raid controller
    SSDs: Crucial C300 256GB
    Standard drives: Seagate ST32000641AS & WD 1TB black
    OSes: Linux and Windows x64
    Mar 2006
    Hastings, England
    Quote Originally Posted by Infa View Post
    it says no less than 1:1
    If you are really extreme, you never let informed facts or the scientific method hold you back from your journey to the wrong answer
