Page 1 of 2 12 LastLast
Results 1 to 25 of 33
Thread: Extreme 120 vs.Tuniq vs.Ninja (56k warning)
    100% Load 24/7
    Mar 2005
    Seattle
    Just got my Extreme 120 yesterday and decided to do a quick comparison with the Tuniq and Ninja that I also have. Nothing special, just installed them with AS5, and did a quick 30 min orthos small fft's. I have found that this heats things up pretty good. All tests were done with the side panel on, with an Antec 900. Load temps were taken after 30 min of orthos. Idle temps were taken within 5 min of stopping orthos. I'm posting full screen shots so the time in the tray is shown.
    The set-up:
    E6600 9x400 1.465 bios (about 1.4 or so with droop at load)
    Asus P5B Deluxe 804 bios
    Antec 900 case
    Antec 79cfm 2000 rpm fan (This fan is a good noise/air movement compromise.)
    Ambient room temp 21c
    Case temp 25c
    First up: Scythe Ninja
    Idle:
    Load:
    Next: Tuniq 120
    Idle:
    Load:
    Finally: Ultra Extreme 120
    Idle:
    (I accidentally closed orthos after the load shot, but you can see the time in the tray is just after the load shot.)
    Load:
    Some pics of the set-up:
    I suck at taking pics, and my camera is old, so they aren't great.
    Looks like I forgot to take a side closed pic with the Tuniq.
    As you can see, and just as everyone else has stated, the Ultra Extreme 120 kicks ass. With this quick test, the Tuniq 120 is only slightly behind. I think that they would be just about the same for 24/7. The Ninja is still a fine cooler, but I don't think it can keep up with the top ones any more. I think temps would also drop a degree or so after the AS5 sets. I would like to test with a quad core, but I'm not going to get one until after the third quarter price drops. That was the real reason for getting the Extreme 120.
    I used small fft's, (as for me anyway,) this gives maximum temps. I have been running WCG with the Extreme 120 since yesterday, and my load temps are 47-48.
    Also just some thoughts about the temps I've seen reported by others. I just find it hard to believe when I see load temps only 10 degrees above idle. Even when I was running water with my xp-m, (back in the old days ) load temps would be 15-20 degrees above idle.
    Main Rig
    i7 2600k l Asus P8P67 l 2x2gb Gskill l GTS450 l Venomous X l XClio 680
    Feb 2006
    La La Land.
    Your ambient seems to be very high m8.
    As the ambient goes up your idle will go up. and if you dont have good airflow you wont get the 10C difference that many here are getting with U120 extremes. You are idling over 40.
    I am yet to see mine even touch 55C under full load condition but i do have 93 cfm fan on it . But my case is well ventilated with 3x120mm and 2x 92mm.
    Primary Rig
    Intel Xeon W3520 @4200Mhz 24x7, 1.200v load (3845A935)
    Gigabyte X58A-UD7
    Patriot Viper II DDR3 2000 CL8
    Tagan BZ1300
    DeepCool Gamer Storm with 2x120mm DeepCool fans.
    MSI GTX 470 Twin Frozr II
    Zotac GTX 470 AMP edition.
    GPU collection : http://www.xtremesystems.org/forums/...5&postcount=64
    Rig2
    Phenom II x4 965
    MSI 790GX-GD65
    2GBx2 Corsair DDR3 1333
    Tagan tg500-u37
    Arctic Cooling Freezer 7 Pro Rev.2
    XFX 9600GT
    Sep 2006
    Groningen, The Netherlands
    Thank you very much. I've been waiting for a Tuniq vs 120 extreme review.
    I now know that i should buy a tuniq. The diffrence in the netherlands is 20 euro and that's only for 2 degrees. That's too much for me.
    100% Load 24/7
    Mar 2005
    Seattle
    Where do you see idle over 40 Idle is in the low 30's. My airflow is good. My case temp is only a few degrees over ambient room temp. I think everyone has a different idea of what load is
    Main Rig
    Feb 2006
    La La Land.
    ya my bad, i was looking at Ai suit temps.
    But i dont get that much delta here. THis is only at 3.37Ghz but still
    My CPU is lapped though. Dont know about yours.
    difference in load temp is nowhere near to as large as yours.
    oops posted wrong pic. will post again, forgot to take screenie before stopping orthos.
    Primary Rig
    Gigabyte X58A-UD7
    Tagan BZ1300
    Rig2
    Phenom II x4 965
    MSI 790GX-GD65
    Tagan tg500-u37
    XFX 9600GT
    Hiding from the cops and people I ripped off
    Jun 2005
    In Bed
    Very nice comparo.. I ordered the U-120 to replace a big typhoon on my Q6600.. I hope to see some nice temps on this new cooler My load temps right now are at about 65c at 1.38v..
    Feb 2006
    La La Land.
    Ok here is the recent run.
    First Ran the orthos. Took the load temp. then stopped it and took temp again after 5 mins for idle.
    IDLE
    Load
    There is nothing exceptional i have done here. Just lapped the cpu IHS. And cooler is in stock condition with TT blue LED fan on it.
    Primary Rig
    Gigabyte X58A-UD7
    Tagan BZ1300
    Rig2
    Phenom II x4 965
    MSI 790GX-GD65
    Tagan tg500-u37
    XFX 9600GT
    Jul 2006
    Edwardsville, IL
    Wait a second, the Tuniq Idle picture shows 79C...simple goof maybe?
    Core 2 Duo E6600 2.4ghz
    eVGA 680i Rev. A1
    2x1gb Crucial Ballistix DDR2-1066 PC2-8500
    eVGA 8800GTX
    Seagate Barracuda 320gb
    WD Caviar 320gb
    FSP Epsilon 700w
    Mar 2006
    Sweden
    Funky: Is that in a closed case? Which case? What's your case temp?
    Lian Li V1000
    e6600 @ 3,6Ghz (1,36v)
    Ultra 120 Extreme / S-Flex 1600rmp Push-Pull
    Asus P5B Deluxe
    2048 Crucial Ballistix 8500
    Asus 8800GTS
    Tagan 480W
    LG L1980Q
    Xtreme Guru
    Apr 2005
    Finland
    Still I think Ultra Extreme 120 is rather expensive compared to Tuniq Tower 120 which already includes a fan as well. But performance wise Extreme 120 impresses me of course but not from a cost point of view. I would still rather choose a Tuniq Tower 120 today. Thx for the comparision.
    Intel? Core i5-4670K @ 4.3 GHz | ASRock Extreme6 Z87 | G.Skill Sniper 2x8GB @ DDR4-1866 CL9 | Gigabyte GTX 970 OC Windforce 3x | Super Flower Titanium 1000W | ViewSonic VX2268wm 120Hz LCD | Phanteks PH-TC14PE | Logitech MX-518 | Win 7 x64 Professional | Samsung 850 EVO & 840 Pro SSDs
    If all people would share opinions in an objective manner, the world would be a friendlier place
    100% Load 24/7
    Mar 2005
    Seattle
    Guys, don't look at the asus suite. The temps jump all over the place with it. I was only using that to show voltage an frequency.
    Funky, nice! Maybe I should match your clock and see what temps I get. I have checked the ihs, it's pretty flat. I have a 6400 and 6300 that I've lapped, those were way bad. I dropped 10 degrees on the 6400. Also, I should have stated that my e6600 is a 28B chip. They tend to run hotter.
    Main Rig
    Feb 2007
    The Thermalright Extreme 120 is definitely the king of air cooler as of today. Sooner or later I'll get me the Xtreme 120 because it's smaller, lighter, and sexier
    http://www.anandtech.com/casecooling...oc.aspx?i=2981
    Intel C2D E6300 1.86Ghz L629A244 @ 3.78GHz
    Asus P5K-E Wifi/AP Rev.1.02g
    Thermalright Ultra Extreme 120+ 2x 120mm
    ATI x1900 GT Rev.2 256mb 513/657
    G.Skill 2x1gb Hz--540MHz
    Sep 2006
    Quote Originally Posted by tuanming View Post
    Is that a good review?
    Because I see that a tuniq beats a infinity with 2 fans with 10 degrees(load)!! Is that true?
    Feb 2005
    the Tuniq 120 load temp not online
    or anybody has the same problem
    Sep 2006
    Philippines
    i can't see also the tuniq load pic
    Dec 2006
    Alberta, Canada
    Quote Originally Posted by Funky View Post
    Funky, which Vcore of yours is correct, Everest or CPU-Z? Are you running the same Vcore as OP?
    Edit: I noticed they both fluctuate, have you measure actual vcore under load with a DMM? If the CPU-Z one is closer to true, then that is your temperature difference right there.
    Xeon 3060 @ 3,600 MHz [400 x 9, 1.36v] - Ultra 120 Extreme w/ FN121s Push/Pull - P5B Deluxe [1236] - 2 x 1GB G.Skill "HZ" @ 800 MHz [4-4-3-9/2.1v] - EVGA GTX 260 650/1400/1150 - PCP&C Silencer 750 Quad - TJ-09
    100% Load 24/7
    Mar 2005
    Seattle
    Somethings up with image shack. I'll try and reload the tuniq shot.
    EDIT: Look like it is working now.
    Main Rig
  18. #18
    Feb 2006
    La La Land.
    Quote Originally Posted by Comminadian View Post
    My CPU is voltage lover
    The CPU-Z is incorrect.
    The Everest voltage is the correct voltage.
    Its 1.44v in reality.
    Primary Rig
    Gigabyte X58A-UD7
    Tagan BZ1300
    Rig2
    Phenom II x4 965
    MSI 790GX-GD65
    Tagan tg500-u37
    XFX 9600GT
  19. #19
    Feb 2007
    Quote Originally Posted by barzi
    Why is it not a good review? They probably used a weak dual 120mm, mine has a 79 cfm fan!
  20. #20
    Dec 2006
    Alberta, Canada
    Rgr that! Just checkin'
  21. #21
    Xtreme Legend
    Jun 2002
    Hong Kong
    All this hoopla over 2C?
    Still nobody has shown a head to head between the Ultra-120 X and TT120 with a high Vcore, high MHz Kentsfield. So the jury is still out as far as I am concerned.
    DDTUNG
    XtremeSystems - we overclock and crunch you to the ground
    I left the optimized files on three 3GHz P4 HTs. Ban me.
  22. #22
    Xtreme Guru adamsleath's Avatar
    Nov 2006
    Brisbane, Australia
    mmm. me too wood like to see some quad cooling results on air coolers.
    but it's interesting to see that ultra extreme wins by a nose like i thought it wood.
    i7 3610QM 1.2-3.2GHz
  23. #23
    100% Load 24/7
    Mar 2005
    Seattle
    Hey Victor, send me one of yours and I'll test it.
    Main Rig
  24. #24
    Xtreme Legend
    Jun 2002
    Hong Kong
    Quote Originally Posted by [XC] 4X4N View Post
    How about you send me the HSF?
    DDTUNG
  25. #25
    May 2006
    my temps are cold @3,6 v-core@1,41V,thermalright ultra 120X with s-flex 1200min.
    i7 960@4,5 ,GiGa UD5 ,Kingston HyperX 6GB,Asus 5850,Water,OCZ Revo Drive 120GB,OCZ Vertex2@mac pro
