I've made a few posts about this in the 'Harassment and discussion' thread, but I'm still having problems, so I'm taking the liberty of opening my own thread![]()
Recap:
I have a dual core Pentium D, and am running two instances of FoH, set up correctly (Machine ID 1 for the first client and, and Machine ID 2 for the second). The second instance seems to be progressing much slower then the first.
I originally noticed that the CPU time of the second instance was much less then the first, e.g. 1 hour 50 Min vs. 30 Min. I tried setting the priority for both instances to low, instead of idle, but it doesn't seem to have made any difference to the overall progress.
I suspected that each client wasn't actually getting a core to itself. When I closed one of the clients, the remaining one shows activity on both cores. I'm not sure that this isn't normal, but I figured that they were supposed to use a core each (hence the machine ID). I checked the Affinity via task manager, and each client was flagged as having access to core 0 and core 1. Again, I don't know if this is normal. I tried manually changing the setting, so one was assigned to core 0, and the other to core 1, but again, no change to the overall progress.
The difference in progress really doesn't seem right, but I've no idea what the problem could be, if indeed there is a problem.
I've attached a screenshot, what do you think?
Note: WU's:
Client 1 = Project: 3040 (Run 2, Clone 897, Gen 11)
Client 2 = Project: 3040 (Run 0, Clone 496, Gen 11)
Both WU's were started at the same time.
