what can you try this out on? Will it improve current DX9 games?
Can someone try this on 3dmark?
[SIGPIC][/SIGPIC]
I wonder if it will be any better than software dx10 acceleration.
System
Intel C2D Q6600 @ 3.78Ghz 1.536V (1.55V bios)
TC PA 120.3 , D-TEK Fusion, MCP655, Micro Res, 6 Yate Fans
Mushkin HP2-6400 2X2GB @ 100Mhz 5-4-4-12
Asus Maximus Formula 420x9
4 Samsung Spinpoint 250GB SATA II in raid 0
Crossfire HD 2900XT 512MB 900/900 1.25V
Pioneer DVD-RW
830 Mobo Tray, Wating on MM Duality
PC Power and Cooling 750W , mobo/cpu/gpus/cdrom , Powmax 380W , hd, fans, pump
Acer AL2616W 19200x1200 100Hz (75hz native)
This could be a good thing if implemented the right way. It will be interesting to see if it runs slower then Vista. Now all we need are some fully fledged DX10 games to give it a whirl.
Current Machine is my trusty Dell 8200 Lappy , while i make a decision
I say this would be iffy. I doubt it til I we see some DX10 screenies on it weather its tech demos or what not. If anything its not native its going to be slow, probably run as an emulator.
-=The Gamer=-
MSI Z68A-GD65 (G3) | i5 2500k @ 4.5Ghz | 1.3875V | 28C Idle / 65C Load (LinX)
8Gig G.Skill Ripjaw PC3-12800 9-9-9-24 @ 1600Mhz w/ 1.5V | TR Ultra eXtreme 120 w/ 2 Fans
Sapphire 7950 VaporX 1150/1500 w/ 1.2V/1.5V | 32C Idle / 64C Load | 2x 128Gig Crucial M4 SSD's
BitFenix Shinobi Window Case | SilverStone DA750 | Dell 2405FPW 24" Screen
-=The Server=-
Synology DS1511+ | Dual Core 1.8Ghz CPU | 30C Idle / 38C Load
3 Gig PC2-6400 | 3x Samsung F4 2TB Raid5 | 2x Samsung F4 2TB
Heat
TAMGc5: PhII X4 945, Gigabyte GA-MA790X-UD3P, 2x Kingston PC2-6400 HyperX CL4 2GB, 2x ASUS HD 5770 CUcore Xfire, Razer Barracuda AC1, Win8 Pro x64 (Current)
TAMGc6: AMD FX, Gigabyte GA-xxxx-UDx, 8GB/16GB DDR3, Nvidia 680 GTX, ASUS Xonar, 2x 120/160GB SSD, 1x WD Caviar Black 1TB SATA 6Gb/s, Win8 Pro x64 (Planned)
isnt there an option for dx10 shaders in CoH? Someone with a decent rig should test it
-=The Gamer=-
-=The Server=-
Heat
i wont believe it until its prove to be working
E6600 @ 3.6
IN9 32x MAX
EVGA 8800Ultra
750W
most of 3rd party drivers/port are buggy and unstable, specially on Windows OS (closed source)
MS need to backport in order to make it work right, otherwise it will be buggy/laggy
C2Q QX6800@ 3.75GHz (375x10 - 1.450v) - L725A - G0
4GB PC2-5300 Kingston Micron D9@ 3-4-4-10 750MHz 1:1
Asus P5E-Deluxe - no mods
eVGA 9600gso G92 + XFX 8500 GT (physics)
H4ck3d-Slackware 11.0
kernel-2.6.22.1@MCORE2 Arch Optimized
System
Pioneer DVD-RW
This is a joke...
I would've expected to find DX9 code in his d3d10.dll. Instead I found nothing of that, but I did find opengl code Not very optimal...
So I wouldn't have too high hopes for this thing. Check that forum link as well, they seem to have thing for vaporware and having ppl donate cash for nothing.
Hmm quite clever (if a scam), since so many seems desperate for DX10 on XP.
Could be quite a cashcow.
Crunching for Comrades and the Common good of the People.
Great news indeed! But with Microsofts track record with their newly aquired tactics of forceing people to upgrade hardware just to run Vista and all the crap flying around the net of the power move they have plans to force people into using Vista one way or another wether it be discontinueing support for XP or what ever, I would take that with a grain of salt as it contradicts everything we have been seeing & hearing with the current happening's.
SuperMicro X8SAX
Xeon 5620
12GB - Crucial ECC DDR3 1333
Intel 520 180GB Cherryville
Areca 1231ML ~ 2~ 250GB Seagate ES.2 ~ Raid 0 ~ 4~ Hitachi 5K3000 2TB ~ Raid 6 ~
-=The Gamer=-
-=The Server=-
Heat
First Bold:
You're honestly complaining that they're increasing the hardware requirements for Vista over what was required for XP? You do realize that XP came out 2001, SP2 in 2004... 3 - 6 YEARS worth of hardware advancement there. At the same time, Windows XP requires more than my old Windows 95 did, should I complain about that too (because the time difference was about equal). Now, had you said that you were annoyed that they were doing things like DX10 before hardware was even really available, that'd be a fair argument though.
Second Bold:
Support for Windows 98 was only discontinued late *last summer*, 6 years after the successor (windows 2000) was released. Assuming the same type of trend, this would mean Windows XP would still be supported until around 2012-2015.
M$ is hardly forcing you to do anything - they're simply progressing.
Dual CCIE (Route\Switch and Security) at your disposal. Have a Cisco-related or other network question? My PM box is always open.
Xtreme Network:
- Cisco 3560X-24P PoE Switch
- Cisco ASA 5505 Firewall
- Cisco 4402 Wireless LAN Controller
- Cisco 3502i Access Point
Well, it doesn't seem to work for me nether..
Dammit microsoft, just realease one last servicepack for XP (SP3) with DX10 integrated or something like that
www.teampclab.pl
MOA 2009 Poland #2, AMD Black Ops 2010, MOA 2011 Poland #1, MOA 2011 EMEA #12
Test bench: empty
good enough to hold me till vienna and skip the vista crap altogether
Microsoft won't release DX10 for XP. After the nightmare of writing the code for Vista, it would take a fundamental redesign of XP to get the new driver design into XP. It would likely introduce a myriad of problems and require too much effort to bring the performance of the OS back to what it was. They have their sights set on the future and will have enough work on their hands prepping SP1 for Vista.
I took the corresponding dx files from an actual vista install with name of the files in the test.
This allowed me to atleast get a logical error in a msvcrt.dll dynamic link library, most likely due to it not being the vista one inside xp.
I figure it would just be easier to make dx10 from vista work in xp.
The sad part about this thing is, it can't even run the nvidia direct10 demo, do to not having lighting information.
If it isn't a hoax, I would be amazed.
System
Pioneer DVD-RW
I openly support anyone for trying to do something better than I possibly could.
The greatest strength of the open source community is that anyone can use your work as the basis of making something beyond your wildest dreams.
For DX10.0a yes but it should work better with later versions.
BSD and Linux are far older than XP, age isn't the factor but rather how well made they are.
Fast computers breed slow, lazy programmers
The price of reliability is the pursuit of the utmost simplicity. It is a price which the very rich find most hard to pay.
http://www.lighterra.com/papers/modernmicroprocessors/
Modern Ram, makes an old overclocker miss BH-5 and the fun it was
