Results 1 to 19 of 19
Thread: E6420 3.26 gHz @ 1.35v/8800GTS @ 621/986
    Aug 2006
    Phoenix, AZ
    Exclamation *UPDATED* E6420 3.66 gHz @ 1.50v/8800GTS @ 621/986
    I just put together my new system, and I've put it through its paces and found how high it can go with all stock cooling and voltages. My temps aren't great, and neither are my clocks, but I should have the parts and the time to redo the cooling next week. For now, I think I'm doing pretty well for my first overclock.
    System:
    C2D E6420; Batch # L647G476
    DFI Infinity P965-S
    G.Skill F2-6400PHU2-2GBHZ
    eVga 8800GTS 640MB
    Corsair 620HX
    I hope to do a lot better once the new cooling is in, as I'm sure my CPU will really take off when I apply some more volts to it. I'm taking it slow, though, since I'm only about half sure of what I'm doing. Any tips (especially concerning the DFI BIOS) would be appreciated!
    *UPDATE*
    New cooling is in, and I realize I have made a terrible mistake. The fans I installed are way too loud. It sucks that I'm going to have to buy new fans, these ones are just overkill...
    The good news, though, is I have about unlimited cooling potential.
    I have pushed my system up to 1.55v, but I don't seem to get much more out of it. I'll get "Machine Check Exception" blue screens when running Orthos. Best I'm getting at these voltages are between 450 and 460 FSB, just shy of 3.7. This will be good for my 24/7 clock, but while I've got the overkill cooling I want to see how high this chip can go.
    I have some questions about that...
    1) How high can I take my CPU and NB voltages? Default is 1.35v & 1.25v, respecitvely.
    2) Where can I monitor my NB temp? Everest shows an "Aux" sensor in addition to my MB sensor, which is it and about at what temp should it ideally be running?
    3) In the DFI BIOS, there are many settings I have never seen before.
    3a) What is the bootup clock?
    3b) What is the PPM CPU feature?
    3c) For best performance, what should the DRAM config settings (DDR Config Mode, GTL+ Driving Strength, Enhanced Data Transmitting, Enhanced Addressing, DQ Calibration, Channel 1 CLK Fine Delay, Channel 2 CLK Fine Delay) be set at?
    I'll get new screenshots up tonight, the best SuperPI I've gotten is about 13.6 seconds.
    Jan 2007
    Portugal
    you will try with dry ice or ln2?
    Apr 2003
    Belgium
    Ouch 92° on the vidcard
    Ryzen 7 1700X @ 3.9GHz + Noctua NH-D15 - Gigabyte GA-AB350-Gaming3 - 16GB HyperX Savage DDR4-2666 - MSI GTX970 + BenQ XL2411T - Corsair HX620 + Silverstone TJ09B-W
    Aug 2006
    Phoenix, AZ
    I will be doing air cooling, namely Thermaltake HR-03 & Ultra 120
    Now, as far as this video card is concerned, it's really hot! Even at default speeds, it gets up to 89C. Is that really bad?
    Jul 2006
    I like how coretemp identifies the e6420 as e6500
    Nov 2002
    Kent, England
    Quote Originally Posted by oshox View Post
    http://www.desertusa.com/Cities/az/city_phoenixAZ.html
    U live in the desert, so not bad really.
    Mar 2005
    Imladris
    Looks good so far.... I look forward to seeing what that chip will do with better colling and more volts. This might be just what I'm looking for.
    The little air system that could.
    Da Goose
    Oct 2005
    Chicago
    wHERE DID YOU PURCHASE YOUR cpu FROM ?
    i7-860 Farm with nVidia GPU's
    Aug 2006
    Phoenix, AZ
    @rvd: CPU-Z actually shows it as an E6400, it's just I moved the JPEG quality slider down a bit too far and mussed up my screenshot.
    @DAK1640: pcsuperstore.com, recieved CPU Friday afternoon
    Feb 2004
    Home of the Sun Devils
    Hey Oshox I bought one from pcsuperstore as well. How long did it take you to get it after ordering? And did they send you a tracking number? Just curious, never done business with them before. I see you're a fellow zonie. Looking forward to summer I'll bet? LOL.
    i7-3930K
    GA-x79-UD3
    Corsair H100
    4x2GB F3-12800CL6
    X-Fi Xtreme Music
    EVGA GTX 470
    Pioneer BDR-207DBK
    2X128GB Samsung 830's
    3XWD2002FYPS
    Corsair TX850
    Dell U2412M
    ___________________
    Da Goose
    Oct 2005
    Chicago
    Thank you oshox. I am glad you got a great chip. I too am interested in Peakr's questions. I am in the same boat.
    Aug 2006
    Phoenix, AZ
    I ordered my CPU Wed. morning and payed for 2nd day air shipping. My credit card was actually declined when I ordered, but they called me and I had them re-run it after I talked to the anti-fraud from my card issuer. So, basically, the order went through at about 1:30 p.m. PST, and it was delivered about 5:00 p.m. the following Friday. Exactly how online shopping should be, if you ask me.
    Apr 2006
    Hong Kong
    The G batches seem to be doing alright. Keep pushing
    "Language cuts the grooves in which our thoughts must move" | Frank Herbert, The Santaroga Barrier
    2600K | GTX 580 SLI | Asus MIV Gene-Z | 16GB @ 1600 | Silverstone Strider 1200W Gold | Crucial C300 64 | Crucial M4 64 | Intel X25-M 160 G2 | OCZ Vertex 60 | Hitachi 2TB | WD 320
    Oct 2003
    Thumbs up
    Hi,
    On stock cooler, promising O/C.
    E6420 seems to be well born.
    P5E Deluxe x38 @ Rampage Formula (Bios 0802) || E8600 @ 4500mhz @ 1,38v || Ultra 120 Extreme + 2 Yate Loon D12sl + IFX-10 || 2 GB Cellshock PC8500 D9GMH @ 600 (2.3v) 5/5/5/15/2T || 4 x 640gb WD sata II || HD4870 @ 775 - 1000 || CM Stacker STC-01 + 4 Yarte Loon D12SL || Enermax modu82+ 625W || Audigy2 ZS || Logitech Z-5500D || Lacie Electron22BlueIV 22"
    Dec 2006
    Vegas ,NV
    wow i could cook my dinner on your 8800
    thats like way way to warm man. i beilive the g80's max safe temp is at about 85-90 . but yeah being in the desert sucks, i should know being in las vegas, on air cooling it can be a challenge especially when your trying to save power
    luckily now my roomies gf pays the electric , and she likes to blast the ac heh
    Xtreme Guru adamsleath's Avatar
    Nov 2006
    Brisbane, Australia
    below 90c would be preferable i think for da gcard....
    i also heard that up to 100c is ok...but i wouldn't feel too comfy about that temp :/
    i7 3610QM 1.2-3.2GHz
    Xtreme Recruit
    Jul 2005
    Auckland
    im testing mine now hopefully can get better result
    Gaming:
    Intel Core2Quad Q6600 @ 3.3Ghz 1.45V Coolermaster GeminII | Asus Commando | 2x1GB Gskill DDR2-800HZ | XFX 8800GTS 512MB G92 | Creative X-Fi ExtremeMusic | 1x320GB Seagate SATAII 16MB | Enermax 600W
    Shopdemo:
    C2Q Q6600 @ 3GHz Coolermaster GeminII | DFI 680i |4x2GB PCI DDR2-800 CL5 | 2xXFX 8800GTS 320MB xXx | 2x500GB Seagate SATA2 | Silverstone 750W
    Dataserver:
    AMD 4000+ AM2 | Gigabyte Nforce570sli | 2GB DDR2-667 | xfx8600gt | Creative Audigy 2 ZS | 2x750GB+4x500GB | Silverstone 400W
  18. #18
    Apr 2003
    Belgium
    Have you already set a manual fan speed for your vga in rivatuner? If you let it on auto it gets alot warmer than when you would set it at, for example, 75%, which is just on the border of it being able to be heard.
  19. #19
    Aug 2006
    Phoenix, AZ
    In that pic, yes I had fan speed at 100%. With my new HS and fan, I see temps about 20C less.
    Bump, updated thread 4.20.07
