Page 1 of 3 123 LastLast
Results 1 to 25 of 53
Thread: my Laing ddc2 pump top mod (56k warning)
    Xtreme Guru
    Jun 2006
    Finland, joensuu
    so last week i got my new laing ddc2 pump from england, and since i'm very cheap.. i decided that i'm going to mod the top part of the pump, so i can fit 1\2" tubing to it and at the same time increase the performance of the pump.
    hope you gues enjoy the pics.
    Ok and on with the mod. after dissembling the pump i took out my trusty drill and drilled a hole right at the middle of the top piece:
    i chopped the inlet and the outlet with my dremel clone like so :
    i decided that it would be best if i cut a little bit off from the barb that was going to be glued to the outlet, cos to me it looked that it was too long.
    the barbs glued to the top piece. the glue that i used was araldite, it rocks
    little bit more araldite:
    after i had made sure that the araldite was dry i started to filling process. the stuff i used is called chemical metal putty. good stuff too, when it dry's, it's really hard but it can be sculpted.
    little bit of sanding:
    there was a lot of nasty holes after the sanding, and i noticed that the form was not symmetrical any more so some more putty was needed:
    more sanding:
    when i was happy with the sanding jop i ablyed a couple of layers of primer:
    i assembled the pump and tested if it had any leaks.
    triumph no leaks....
    here it is, assembled and ready to go.
    i'm really happy with the job i made not too hard to make, it looks nice and more importantly it works like a charm.
    this mods source of inspiration were: coolmiester, karhu beer, petras top.
    Evga X58 sli under cascade
    http://www.xtremesystems.org/forums/...d.php?t=219788
    Evga X58 Sli ultimate overclocking/ overview/ discussion thread
    http://www.xtremesystems.org/forums/...d.php?t=221082
    proud owner of E8600 Q822A435
    Oct 2006
    Good job. you got a nice finish of the pump.
    Intel is like Egypt in Rome:total war
    Dec 2005
    Brooklyn, New York
    It's a great mod. I would do it, but then I can't clean the pump.
    Nice work.
    Heatware: 50-0-0
    Quote Originally Posted by Charile
    I believe that GWB, who may NOT be the best overclocking CPU in the tray...
    Quote Originally Posted by -thc-(cZ) View Post
    oh c'mon, maxxx, kick that cat of that monitor and have it poop for you
    Xtreme Mentor
    Sep 2005
    Netherlands
    Quote Originally Posted by thunderstruck! View Post
    Nice work.
    why wouldnt you be able to clean the pump witht is mod?
    the bottom is stil screwed to the top with the 4 standard screws.
    Time flies like an arrow. Fruit flies like a banana.
    Groucho Marx
    i know my grammar sux so stop hitting me
    Jan 2007
    That turned out very nice. Good job!
    Intel I7 920 D0 @ 4.2g------------EK Supreme HF
    EVGA X58 SLI LE------------------EK-FB EVGA X58 LE
    nVidia GTX 580----------------------EK-FC580 GTX
    6g Corsair DDR3----------------DDC 3.2 w/ Petra's top
    OCZ 120g Vertex SSD------------------PA120.4
    WD 150g Raptor
    WD 500g
    ASUS Xonar DS
    HX1000 psu
    Silverstone TJ07 case
    May 2006
    Wow, really great job there, looks seamless.
    Core2Duo E6600 @ 3.0 - Load @ 32c°| Gigabyte P35 DS3P | 2gb Crucial Ballistix Pc2-8500| eVGA 8800GTX| X-fi Fatal1ty | OCZ GameXStream 600w | Custom Watercooled | Custom-built Case
    Dtek Fuzion | DD Maze4 Acetal | Swiftech MCR-320 | DD D5
    3dMark01 3dMark05 3dMark06 Aq3 SuperPi
    Quote Originally Posted by Movieman View Post
    I don't beleive in passive cooling.
    May 2006
    Slovakia Europe
    Quote Originally Posted by Solarfall View Post
    Very nice job Excelent work
    And what about increasing performance of the pump
    // E6600@3900~1.5v // Asus P5K DLX //A-DATA 2GB EE // Samsung F1 1TB // ASUS X1900XTX~735/1680 // Corsair HX520 // Thermaltake Armor VA8000SWA // W. COOLING ~ D-Tek FuZion & Viscool V3 GPU & Swiftech MCP655 & 2x Swiftech MCR-320QP //
    Xtreme Guru
    Jun 2006
    Finland, joensuu
    Quote Originally Posted by soccerswim8 View Post
    wow!!!
    excellent job!!! that looks so smooth!!
    any GPM or head tests?
    LOL sorry i'm not really that scientific i'm just a simple modder
    Quote Originally Posted by SharkerSk View Post
    Very nice job Excelent work :thumbsup:
    this mod was inspired by petras top, and it's well know fact that moving the inlet to the top of the pump will increase flow and and head pressure and i guess that barbs with bigger ID can't hurt.
    Xtreme Cruncher
    Jan 2007
    Denmark
    That looks really nice.
    Good job mate!
    Watercool Project! (Check it out!) (New update: 25/07-2007: Pics of costom made RAM-cooler + lapjob)
    System:
    Intel Core 2 Duo E6420 @ 3600 MHz, 1.52 Vcore
    Asus P5K Deluxe
    Crucial Tenth Anniversary PC-5300 2 x 1024 Mb @ 900 MHz, 4-4-4-9, 2.05 Vdimm (Costom cooled)
    Inno3D 8800 GTS 640 Mb @ 648/1512/1021
    Corsair HX520W
    2 x WD Raptor 74 Gb (RAID0)
    Antec P180B (3 x Scythe S-FLEX SFF21E @ ~ 10 V)
    Samsung SyncMaster 226BW 22"
    Sunbeam Rheobus
    Watercooling:
    Swiftec Apogee GTX (Bowed)
    Swiftec MCW60 (Swiftec MC14 and MC21 ramsinks)
    Thermochill PA120.3 (3 x Shakoon Silent Eagle 2000 @ ~ 6.5 V)
    Laing DCC-2 18W (Aplhacool top)
    EK Multioption 150
    Masterkleer 7/16" ID
    EK High-Flow fittings
    Xtreme Cruncher
    Dec 2006
    Palo Alto, CA
    Nice, I want to do this mod more and more now...
    Lenovo Thinkpad X220 - Core i5 2410m, 4gb
    waiting on 28nm video cards...
    Hamster Powered
    Apr 2006
    Virginia, USA [Krunching since 2001]
    Lookin Good!
    XSWCG Disclaimer:
    We are not responsible for the large sums of money that you WILL want to spend to upgrade and add additional equipment. This is an addiction and the forum takes no responsibility morally or financially for the equipment and therapy cost. Thank you and have a great day.
    Sigmund Freud said... "Failure to CRUNCH is a sign of Sexual Inadequacies".
    Xtreme Mentor
    May 2005
    Westlake Village, West Hills
    Nice mod.
    PC Lab Qmicra V2 Case SFFi7 950 4.4GHz 200 x 22 1.36 volts
    Cooled by Swiftech GTZ - CPX-Pro - MCR420+MCR320+MCR220 | Completely Silent loads at 62c
    GTX 470 EVGA SuperClocked Plain stock
    12 Gigs OCZ Reaper DDR3 1600MHz) 8-8-8-24
    ASUS Rampage Gene II |Four OCZ Vertex 2 in RAID-0(60Gig x 4) | WD 2000Gig Storage
    Theater ::: Panasonic G20 50" Plasma | Onkyo SC5508 Processor | Emotiva XPA-5 and XPA-2 | CSi A6 Center| 2 x Polk RTi A9 Front Towers| 2 x Klipsch RW-12d
    Lian-LI HTPC | Panasonic Blu Ray 655k| APC AV J10BLK Conditioner |
    Sep 2006
    brazil
    really like how it turned out... nice work :thumbsup:
    E8600 - Maximus Formula II - HIS 4870x2 - Mushkin DDR2 1066 2x2GB - Silverstone DA 850W - Silverstone TJ09 - TRUE Black
    May 2005
    earth......among the the others
    very nice work
    i wish i had such skills.......
    STEELBALLZZ - N3RO - MARTAKIS
    ZÉ DO BENCH TEAM
    add a volt or two.....
    Xtreme Cruncher
    Dec 2005
    L.A. ( Latin America)/ 4socket wannabe
    oh man you are talented ... very nice
    "Study hard my young friend"[/B].
    Woody: It's not a laser! It's a... [sighs in frustration]
    Xtreme Guru
    Jun 2006
    Finland, joensuu
    just a simple GPM test, its easy. inlet into your sink and outlet into an empty gallon jug and time it to fill it up and get GPM.
    that would be interesting if you did that
    i'm not promising anything but, i see what i can do.
    Apr 2006
    Out West in the Rockies
    I'm quite impressed with how well it turned out too. At first, I thought it was going to look terrible and couldn't really understand why you were putting that putty on. Of course, at the bottom I saw the light.
  18. #18
    Banned
    Jun 2006
    in a Red Rage D....
    nicely done.
    now test gpm and impress us even further.
  19. #19
    Aug 2006
    Canada
    Wow! thats nice!
    Awesome job there!
    • - Asus P8Z68-V PRO
    • - Intel I5 2500k @ 4.5Ghz (for now)
    • - Asus Geforce 580GTX DirectCUII Fermi
    • - 16GB Corsair Vengeance Low Profile
    • - Ultra X3 1000 Watt
    • - Asus Xonar DX 7.1 \ Klipsch Promedia 2.1 THX
    • - Corsair Vengeance 1300 Gaming Headset
    • - Crucial M4 SSD 128GB \ WD Caviar Black 1TB
    • - CoolerMaster 690II Advanced
    • - Dell UltraSharp 24''
    • - Noctua NH-D14
    January - SLI Rig Of The Month (2008)
  20. #20
    Jan 2007
    Norway
    That is one sweet pump
    Personally, I don't think the original pump is "attractive", but with this mod It's lovely.
    Great job!
  21. #21
    Xtreme Guru
    Jun 2006
    Finland, joensuu
    alright here are the numbers from the GPM test, and i got to say i was rally pleasantly surprised, the mod actually did make a difference.
    i did 5 different fillings and counted the average value of those 5 times i filled the bucket. i took few other pumps as comparison:
    the results:
    Petra'sTech DDCT-01s Custom Delrin DDC Pump Top .............4.11 GPM... 246.6 GPH
    My custom laing top............................................... .........4.2 GPM......252 GPH
    AquaXtreme 50Z-DC12 Inline 12V DC Pump...........................3.08 GPM... 185 GPH
    laing d5 vario............................................. ......................5.2 GPM....317 GPH
    Laing DDC-2 (18W)/Danger Den DDC Inline 12V DC Pump.........2.0 GPM....~ 120 GPH ( <btw this is the pump i modded)
    pretty good results, if i say so my self....
  22. #22
    Banned
    Jun 2006
    in a Red Rage D....
    if that's more that 85&#37; accurate, then congrats on a nice succesful ddc top mod.
  23. #23
    May 2006
    Slovakia Europe
    Hehe, very well increased performance, also nicely done
    I want to do this mod myself. Araladite is like epoxy glue or it has different base
    I look for similar glue from henkel group I'm sure that araladite isn't available in my country. THX
  24. #24
    Xtreme Guru
    Jun 2006
    Finland, joensuu
    SharkerSk yes it's pretty similar to epoxy, it only gets a bit harder when it's becomes dry, almost hard as glass...when epoxy has slightly elastic finish when it's dry..... welll if you have made the mixture correctly of course
    but i think that you will find araldite in Slovakia too, it's not that rare, your local hardware store should have it.
    BTW your avatar is REALLY making me hard to concentrate when i'm writing...gulp.. can't stop drooling on my keyboard.
  25. #25
    Sep 2006
    North East UK
    Nice mod Solarfall - looks very similar to one i did a couple of years ago >>full log here<<
