Well I got thrown another wrench in my testing (thanks for that Gabe) and if you run conroe and an apogee GT you will want to pay attention. I conveyed to swiftech that the GTX is performing MUCH better than the GT on my bench, was told this should not be, not by as much as I'm seeing (more that 2c fwiw). Anyway, the key is to rotate the block! Duh, why did I never think of this? Of course this only works for socket 775 as the mount points are perfectly square. It seems the apogee GT performs best when the flow goes over the WIDTH of the die and not flowing the LENGTH. So far 2 mounts have confirmed this by me - better on the order of 1C or so. Now I will need to see what other blocks will show some improvement. So thanks for the wrench. Oh, incase you have no idea what im talking about, perhaps these pictures will explain.
This is the die orientation of conroe.
This is how I tested the 5 mounts of apogee GT - this is how I would normally mount every block as would most people me thinks.
Now here is the vertical mount which performs ~1C better.
![Send a message via MSN to [XC] DragonOrta](images/misc/im_msn.gif)
![Send a message via Yahoo to [XC] DragonOrta](images/misc/im_yahoo.gif)
