Results 1 to 6 of 6
Thread: P5B-E Asus motherboard...looking for optimal settings for DDR2-800 ram
    Apr 2007
    Hi there,
    I have a P5B-E motherboard from Asus with the latest BIOS (v1101) and an E6400. I overclocked the FSB to 333. See pic:
    Click image for larger version.
    This is the RAM I have:
    Brand G.SKILL
    Model F2-6400CL4D-1GBPK
    Type 240-Pin DDR2 SDRAM
    Capacity 1GB (2 x 512MB)
    Speed DDR2 800 (PC2 6400)
    Cas Latency 4
    Timing 4-4-4-12
    Voltage 1.9V - 2.0V
    The issue I am having is that I can get the memory to boot at PC-5300 at 4-4-4-12 but not at PC-6400. Is there a way to do this with this ram and still overclock the BUS for the processor? I currently have the voltage at 2.1v.
    Or, would I get better timings at 5-5-5-15 at PC-6400?
    Thanks a ton. BTW, all the rest of the ASUS timing settings are default aside from the main four above.
    Here are the other screen shots from my CPU-Z readout:
    THANKS!!!
    G.Skill USA Tech
    Sep 2005
    it is running at PC2 6400. there is nothing you need to change
    Feel free to contact ustech@gskillusa.com or use our G.Skill Q&A Sub-Forum, if having any questions about G.Skill products
    Check out our items on NewEgg
    Apr 2007
    When I boot up...it shows PC-5300. If I do not overclock and set the timings back to 5-5-5-15 then it shows PC-6400 at the BIOS post screen...what am I missing?
    G.Skill USA Tech
    Sep 2005
    SPD is set as 5-5-5-15
    user need to manually set to 4-4-4-12 and change voltage to 1.9-2v
    if you use FSB266 DDR2 800 it will show PC2 6400
    if you use FSB333 DDR2 800 it will show PC2 5300
    it is becuase you overclock your FSB and affect the NB memory divider
    Apr 2007
    Ok...forgive the inexperience on my part. Are you saying that by overclocking the FSB to 333, then the RAM is actually transferring at a slower rate of 5300?
    What are my optimal settings for this RAM if I wish to overclock my processor?
    Also...what about the timing settings after the initial 4? I have 10-10-10-10, etc.
    G.Skill USA Tech
    Sep 2005
    4-4-4-12-2-42-3-11-7-13
