Page 1 of 2 12 LastLast
Results 1 to 25 of 28
Thread: E6600@4400mhz on air(4359mhz@SPI 1M)
    Jan 2007
    Iasi<<Romania
    My setup:
    CPU E6600
    Asus P5B-Deluxe wifi/ap (no vmod).
    Team Xtreem Dark 667
    Ninja Plus+Zalman
    vcore=1.62v real
    vdimm=2.2v
    NB=auto (BIOS)
    All on air (temp of air<0)
    and 3600mhz@1.3v <50 grade.
ID:	57429   Click image for larger version.
ID:	57430   Click image for larger version.
    xtreme energy
    Oct 2004
    Europe, Latvia
    Tell us batch/fpo #
    Jan 2007
    Iasi<<Romania
    627b
    Oct 2005
    Netherlands
    very nice chip.
    /edit
    must learn to read
    24/7 setup:|e6600 27B @ 4.1ghz|Commando|8800GTS 640mb @ 600/1000|OZC pc8000 plat. @ 455 4-4-4 2.1v|Frostmachine by Jort|'05 '06 (old amd scores)
    FullSpecs
    Jan 2007
    Iasi<<Romania
    for 4400mhz.
    maybe -9(10) grade celsius;
    Jun 2006
    Russia
    very nice chip.
    You need SS
    Nice Hardware!!!
    Jan 2006
    Finland/Tampere
    What is the whole batch code?
    I have L627B005 and it will do orthos 3600MHz @1.36V. I have some kind of temperature bug, so I can't go over 4GHz, even with chilled water?
    You are as good as your samples are!
    Jan 2007
    Iasi<<Romania
    Quote Originally Posted by JT from Russia View Post
    very nice chip.
    You need SS
    Right
    L627B076
    Jan 2007
    Belgrade, Serbia
    man what a good chip you have
    Xtreme Guru
    Jun 2006
    Finland, joensuu
    Quote Originally Posted by SF3D View Post
    i have the same one mist&#228;s ostit ton prossun?
    @sammurai insane clocks there mate
    Evga X58 sli under cascade
    http://www.xtremesystems.org/forums/...d.php?t=219788
    Evga X58 Sli ultimate overclocking/ overview/ discussion thread
    http://www.xtremesystems.org/forums/...d.php?t=221082
    proud owner of E8600 Q822A435
    Jan 2007
    Nice OC!
    E6600,Asus striker,Crucial pc2 8000,Lianli v1000/koolance pc3-725,7900gt
    Mar 2005
    San Diego, CA
    Very nice chip .
    Core i5 2500K - 8GB Corsair Vengeance, ASUS P8Z68-V, Sapphire 5830, Antec 550w
    [XC] gomeler
    Cars are meant to be driven and then painstakingly cleaned and maintained.
    Oct 2006
    OMG, that chip is insane.
    I thought that I had a great chip, but yours is
    Jan 2007
    Iasi<<Romania
    Quote Originally Posted by Oldscarface View Post
    i need LN2
    xtreme energy
    Oct 2004
    Europe, Latvia
    What kind of bug (what does TAT say?)? Bs are hot, whenever I put more than 1.5V on air throttling kicked in. However, I managed to do a validation at 5ghz under DI
    Nice Hardware!!!
    Jan 2006
    Finland/Tampere
    My temp bug is weird. Like I said it can do 3.6GHz with 1.36V and 3.8GHz with ~1.43V, but anything over that and comp freezes. It's not fsb "wall" it can do 530 easily. and other parts can go much further with other processor. But when I use my waterchiller and temperature is around 0c same thing happens in around 4GHz. Never have this issue with other conroes.
    Dec 2005
    arles/france
    good cpu on aircooling
    c2d e6600 step6 @ 4230mhz-asus p5b deluxe-2x1go crucial ballistixx @ 574mhz 4448-xfx 8800 gts 640 mo
  18. #18
    Jan 2007
    Iasi<<Romania
    with 1.65v (real) and -10grade i will take 4.5ghz jst for CPU-Z.
  19. #19
    Apr 2007
    nice
  20. #20
    Nice Hardware!!!
    Jan 2006
    Finland/Tampere
    Did some testing today with cold water (~7c) and my L627B needs 1.46V to 4GHz. When I use low voltages there is now "temperature bug". This chip must be very well cooled and then it can fly
  21. #21
    Jan 2007
    Iasi<<Romania
    If air temp ~ 23-24 grade C, i need ~1.54v (real) for 3dmark`s (2001/2003...2006).
  22. #22
    approaching aphelion
    Nov 2005
    Aix-en-Pce | France
    L627B are great You need extreme cooling now
    http://beforeoverclock.com/blog/?p=37
    Best Regards,
    Xavier
    "I prefer to fly alone... when alone, I perform those little coups of audacity which amuse me..." Col. René Fonck (1894-1953), the Ace of Aces.
  23. #23
    May 2006
    Philippines ^_^
    very nice chips before..
    Asus P5W64 WS Professional , DFI Infinity 965P-S (testing)
    X6800 , E6750 es
    Micron Fatbodies , Micron D9gkx oem, Crucial 8000, Crucial Tracer 8500 (incomming)
    Ati FireGL V5100, Elsa FireGL V3100
    water cooling setup (EK 775 cpu block, swiftech NB Block, Swiftech pump, BI dual pass dual 120mm)
    Silverstone OP650
    raptors, baracuda
  24. #24
    Jul 2005
    ATX
    omg. wow. very very nice chip + weather
  25. #25
    Feb 2006
    The Netherlands - Rotterdam
    Nice chip indeed.
    Besides some more cold, you also need a board that can handle the chip...
    Like 650Mhz FSB
