mini cell ???
mini cell ???
nice
ASUS P5B Deluxe 1.03G (C1) Vdroop penciled [FSB 1.20V, NB 1.25V, SB 1.50V, ICH 1.0V]
C2D E6400 [L631B #002] @ 3800Mhz 1.391V
Noctua NH-U12F Lapped
2x1GB Transcend 667 (Powerchips) @ 950Mhz 4-5-4-15-3-30-10-20-10-20 2.05V
XFX 7900GS 480M @ 620Mhz/1920Mhz [stock voltages/cooling]
Sirtec 420W
:love:
Infos and more infos and more infos and more slides and more slides and more slides....
kinda a repeat but ok
Fast computers breed slow, lazy programmers
The price of reliability is the pursuit of the utmost simplicity. It is a price which the very rich find most hard to pay.
http://www.lighterra.com/papers/modernmicroprocessors/
Modern Ram, makes an old overclocker miss BH-5 and the fun it was
slides slides slides tech bs no real result , hope this doesnt turn out to be another r600 release![]()
Now i am become death , the destroyer of worlds.
Old info again :/
Btw, it looks alittle bad for R600 if its only directly 50% faster than R580...
Crunching for Comrades and the Common good of the People.
estimated X4 perf.
Thuban @4 GHz + Big Typhoon VX
Windows 3.1 starts on Phenom II X6 4GHz | Форум СЦБиcтов - Railway Automation Forum
i think AMD compare clovertown 5355 2.66ghz and opteron X4 2.5ghz. Agena Fx could be clocked at 2.7ghz. intel need 2P Kentfield at 3.2ghz even more to be competitive in very high end.
Anyone notice that in the GFLOPs chart where they have the two R580s and two R600s...the Gflop performance of the A64 and Barcelona are different by only a few 10s of GFLOPs ...
Perkam
4670k 4.6ghz 1.22v watercooled CPU/GPU - Asus Z87-A - 290 1155mhz/1250mhz - Kingston Hyper Blu 8gb -crucial 128gb ssd - EyeFunity 5040x1050 120hz - CM atcs840 - Corsair 750w -sennheiser hd600 headphones - Asus essence stx - G400 and steelseries 6v2 -windows 8 Pro 64bit Best OS used - - 9500p 3dmark11(one of the 26% that isnt confused on xtreme forums)
| '12 IvyBridge - "ticks different"... | AwardFabrik IvyBridge round I by SoF | AwardFabrik IvyBridge round II by angoholic & stummerwinter
| '11 The SandyBridge madness... | AwardFabrik / Team LDK OC-Season 2011/2012 Opening Event
| '10 Gulftown LaunchDay OC round up @ASUS RIIE | 3DM05 2x GPU WR LIVE @Cebit 2010 @ASUS MIIIE | SandyBridge arrived @ASUS P8P67
| '09 Foxconn Avenger | E8600 | Foxconn A79A-S | Phenom II 940 BE | LaunchDay Phenom II OC round up
| '08 7.438s 1m LN2 | AMD 1m WR LN2 | 2nd AOCM | Phenom II teasing
| '07 100% E2140 | 106.5% E2160 | 100% E4500 | 103% E4400 | 5508 MHZ E6850 | 7250 MHZ P4 641 126.5% by SoF and AwardFabrik Crew all on Gigabyte DS3P c? and LN2...
| '06 3800+ X2 Manchester 0531TPEW noHS 3201MHZ c? | 3200+ Venice noHS 3279MHZ c? | Opteron 148 0536CABYE 3405MHZ c? all on Gigabyte K8NXP-SLI compressorcooled
| '05 3500+[NC], 3000+[W], 2x 3200+[W], 3500+[NC], 3200+[V] 0516GPDW
Anyone know what the 9% faster than X5355 benchmark is? The specFP_rate is a bloated memory bench. The other one is alot more interresting.
the other is OLT-P, which is a memory bandwidth benchmark
Actualy Intel Caneland platform with quad-FSB, 20% higher FSB freq. and bigger snoop-filter will not leave many chanses to Barselona in the server area.
5000X is already quadchannel FB-DIMM.
Not exactly. STREAM is a memory bandwidth benchmark. OLTP stands for "Online transaction processing." It is not a benchmark, but a type of server application, often related to database use. Typical OLTP benchmarks are TPC-C or the newer TPC-E. AMD do not specify which benchmarks they use to measure "OLTP performance".
SPECfp_rate is basically a floating point high-performance computing (HPC) benchmark. It consists of a suite of fp-intensive applications that includes ray tracing (povray), quantum chemistry, protein folding, speech recognition, weather forecasting, etc.
With all the powerpoint slides I feel like falling a sleep. that projector will probably break before any real hardware gets released! I'm dying for a live demo of all this cool hardware (barcelona & R600)! I'm starting to wonder if DNF will come out first. Anybody want to start a pool?
Asus Z9PE-D8 WS with 64GB of registered ECC ram.|Dell 30" LCD 3008wfp:7970 video card
LSI series raid controller
SSDs: Crucial C300 256GB
Standard drives: Seagate ST32000641AS & WD 1TB black
OSes: Linux and Windows x64
Sad to confirm from the page linked to by Oldblue that the SpecFP_rate is indeed a memory benchmark, or "throughput" as they call it. Not much real life performance gain from that one for 1P systems. 9% gain is what i would expect from Barcelona then.
http://www.spec.org/cpu2006/results/
BadAxe2, WC'ed L631B115 Xeon3060 3.4GHz 1.27v summer OC, 2GB BallistiX 4:5,
2x250GB-16 Raid-0 + 400GB-16, 7900GTO 512MB, Acer 22" Wide, Nexus 500W.
