Page 1 of 3 123 LastLast
Results 1 to 25 of 59
Thread: eVGA 8800 GTX with a modded AC3 bios
    Dec 2006
    Netherlands
    Last week i downloaded nibitor @ mvktech.net. I also grabbed the latest eVGA 8800 GTX AC3 bios. After testing my normal eVGA 8800 GTX i found that it was stable @ 640/2100. So i used the AC3 bios and changed the board type to the normal GTX and changed the timings to 640/1500/2100.
    End result:
    E6600 @ 3.6 ghz @ 1.4375v @ 9*400 @ DDR800 @ 1:1 @ 4-3-3-3-16 @ 2.4v
    8800 GTX @ stock = 10689 3d06 marks
    8000 GTX @ 640/2100 (Atitool) = 11320 3d06 marks
    8000 GTX @ modded bios @ 640/1500/2100 = 12645 3d06 marks
    It seems a modded bios does pay off as long as you test your 8800 gtx very good at overclokced settings and always have a pci vga card standby in case you need to flash back the old bios. Use NiBiTor to backup your current bios first !
    Asus Maximus 3 Extreme | Core i7 860 | Thermalright Venemous X | Corsair Dominator GT 2000-C8 4gb Kit | 2 WD Black FALS 1 TB Raid0 | XFX HD5870 | Coolermaster ATCS 840 | Corsair HX750 Watt | Samsung 2493 HM TFT |
    Oct 2002
    London
    Well done !!
    What is the significance of changing the board type??
    What types are there and what was it set to before?
    Xtreme Legend
    Mar 2005
    Australia
    wow BIG change man
    Team.AU
    Got tube?
    GIGABYTE Australia
    Dec 2006
    Netherlands
    It seems wise to change the board type because the pc will see a real 8800 GTX AC3 in stead of a 8800 GTX "special". I have read some stories about people who didn't change the board type and got into trouble.
    To play safe = change board type
    Results are very good.
    Aug 2005
    Romania, Transylvania crazyp.ro
    Link?
    3Dmark2006 Score Calculator
    "Frequency Unlimit -Enabled'' by DFI
    Dec 2006
    Netherlands
    Link:
    All the info you need is on the www.mvktech.net
    1. Backup your own bios file with the latest version of NiBiTor
    2. Download a AC3 bios, or use a copy of your own bios
    3. Test your 8800 gtx to be sure to reach the proper speeds
    4. flash the bios with nvflash
    www.mvktech.net
    Apr 2006
    Hong Kong
    Why does flashing the bios to the AC3 version mean increased score in 3dM over the standard OC?
    Is it because the shader clock is OCed?
    "Language cuts the grooves in which our thoughts must move" | Frank Herbert, The Santaroga Barrier
    2600K | GTX 580 SLI | Asus MIV Gene-Z | 16GB @ 1600 | Silverstone Strider 1200W Gold | Crucial C300 64 | Crucial M4 64 | Intel X25-M 160 G2 | OCZ Vertex 60 | Hitachi 2TB | WD 320
    Dec 2006
    Netherlands
    Quote Originally Posted by CedricFP View Post
    Yes, the shader clock is the main reason but i think that the memory timings are slightly faster/fine tuned. The bios file contains memory timings like a spd of a ddr2 dimm.
    Aug 2004
    Sydney, Oz.
    was 640 the limit before and is it now? i mean do the tightened timings limit the overclock possible?
    also do you think this will work with a different brand of board?
    Xtreme Guru
    Jun 2006
    Finland, joensuu
    i'm not totally sure about this, but if i overclock my video card regulary, doesent it increases the shader clocks too at the same time, or will i need to mod my bios file if i want to increase the shader clocks.
    Evga X58 sli under cascade
    http://www.xtremesystems.org/forums/...d.php?t=219788
    Evga X58 Sli ultimate overclocking/ overview/ discussion thread
    http://www.xtremesystems.org/forums/...d.php?t=221082
    proud owner of E8600 Q822A435
    Apr 2006
    Cairo
    Quote Originally Posted by Solarfall View Post
    it does increase the shader clock but with constant rate , with a modded Bios you can push it a little bit further
    Intel Core I7 920 @ 3.8GHZ 1.28V (Core Contact Freezer)
    Asus X58 P6T
    6GB OCZ Gold DDR3-1600MHZ 8-8-8-24
    XFX HD5870
    WD 1TB Black HD
    Corsair 850TX
    Cooler Master HAF 922
    Xtreme Guru
    Jun 2006
    Finland, joensuu
    kemo6600 thanks for verifying this. have to try this ASAP. and test if it will give me a better scores in various benchmarks.
    Apr 2006
    Cairo
    definitely will give you better scores but not ^^^^ that much
    oh that memory in your sig , picked by The Stilt
    Asus X58 P6T
    XFX HD5870
    WD 1TB Black HD
    Corsair 850TX
    Xtreme Guru
    Jun 2006
    Finland, joensuu
    Quote Originally Posted by kemo6600 View Post
    have no idea... but i think that he works in that store were i bought these ram sticks.
    btw actually i have not fully tested the true potential of these stick, they might clock even higher. just can't seem to find the time these days, damn work stuff and life interferes
    Aug 2004
    Sydney, Oz.
    so it will work on your XFX card?
    Xtreme Guru
    Jun 2006
    Finland, joensuu
    Quote Originally Posted by pumbertot View Post
    yep it should be piece of cake. you just have to download the right bios file from MVK tech, load that in nibitor and you can alter your cards settings from nibitor.
    link: http://www.mvktech.net/component/opt...tfolder/cat,4/
    Aug 2004
    Sydney, Oz.
    so yeah use it for shader clock increase but do you reckon the same timings will work on an XFX or is it better to just have a play around with them one setting at a time and test that way?
  18. #18
    Apr 2006
    Hong Kong
    How much should we overclock the shader clock by? Same percentage as memory or core?
  19. #19
    Xtreme Guru
    Jun 2006
    Finland, joensuu
    i would recommend to play it safe, increase mhz with tiny steps and test that card works properly, play some game or run benchmarks like 3dmark.
    if the card seems to run like it should and does not cause artifacting, just increase it little bit more until you find your cards max setting, thats pretty much what i allways do when i overclock my video card, ram or cpu.
  20. #20
    Apr 2006
    Cairo
    I am asking because that ram looks great on paper and I cannot find it any were , on the other hand the Stilt knows every thing about that memory
    Asus X58 P6T
    XFX HD5870
    WD 1TB Black HD
    Corsair 850TX
  21. #21
    Champion
    Jan 2004
    Athens , Hellas
    I have tried 3 XFX and all had trouble with shader clock values higher than 1470Mhz ...
    Besides ... one EVGA , one Foxconn and one BFG can go without problems up to 1570Mhz .
    Maybe the XFX batch i had was bad ...
  22. #22
    Xtreme Guru
    Jun 2006
    Finland, joensuu
    yeah i know what you mean, they are very hard to find. basicly i know only two places were you can get them, 1 here in Finland and the other one i believe was in Germany, if you want to get your hands on these stick it probably would be best to pm The stilt, he could be able to hook you up with the right people. don't expect that he will answer right away, he has said in finish forums that he is really busy.
    Stelios do you mean the XFX 8800gtx xxx oc:ed series or the regular non oc:ed ones ?
  23. #23
    Aug 2004
    Sydney, Oz.
    hehe thanks for the o/c lesson though i know what im doing.
    question was more asking if you knew if the timings were the same across all brands and would tightening them work? but yeah i will try as soon as i have them, they should be here tomorrow. Dynasty's own superclocking set, are all mine! muwahahhaahahahahahaahah.
  24. #24
    Champion
    Jan 2004
    Athens , Hellas
    I have only played with the regular cards .
  25. #25
    Xtreme Guru
    Jun 2006
    Finland, joensuu
    lol sorry man i thought that you were a total newbie
    let us know how you did with your cards.
    Quote Originally Posted by Stelios View Post
    OK i have the regular one, i gess i just have to test my self how my XFX does. so far it has been a great clocker, fingers crossed that mine is not one of the crappy ones
