It's in early beta.
http://forum.folding-community.org/f...12.html#172012
Trying it now on my Opteron 175.
Post results / frame times here.
It's in early beta.
24/7 Gamer
Q6600 @ 3.6GHz
ASUS P5K
8800GT @ 720, 1800, 950
2GB Mushkin Redlines @ 500MHz 4,4,4,9
Samsung 245BW 24" LCD
Thanx for monitoring official forums... it's work for the team important also
Might as well put the direct link here: click
[warning]As there is said... bugs will happen and work will lost... IT'S BETA! [/warning] (so no whining if EUEs come... those should be reported at official forums)
Great finding again Scimitar... keep us posted!![]()
Looking good so far, about 35 minutes a frame or 600ppd. More than double of 2 Supervillans.
24/7 Gamer
Q6600 @ 3.6GHz
ASUS P5K
Well spotted man, this is great news![]()
Running it now on my borrowed parts from my friend. FahMon doesn't know what it is exactly though so I don't know what PPD I'm getting from it. I'm running a borrowed X2 3800+ @ 2.6GHz right now.
The Cardboard Master Crunch with us, the XS WCG team
Intel Core i7 2600k @ 4.5GHz, 16GB DDR3-1600, Radeon 7950 @ 1000/1250, Win 10 Pro x64
What does this client mean? Faster times for each WU?
Heatware | Abit IP35 Pro | Intel E6750@3.8Ghz 1.56v | Storm R2 | Ballistix DDR2-8500 | Sapphire HD3870 512MB@TBA | MCW60 | WD Raptor 74GB | WD2500KS | OCZ GameXSteam 600w | SoundBlaster Audigy 2 ZS | DT770/80Pro | WinTV PVR-250 | Antec P180 | 7 Yate Loon D12SL-12 | AQ50Z | PA120.2 Custom Painted | BIP GTS 120mm | MasterKleer 7/16 Tubing | VX924 | G15 Keyboard/G5 Mouse/Steelpad QCK+
I think it just saves time from having to load and install 2 versions. Also, this will probably have its own projects (which means no 21XX projects).
right now the benefits is that your CPU is loaded 100% on one client, and the points. upwards of 1760 points on a single WU that takes 11-13mins per frame.
Mac Pro 2X2.4GHZ Quad
40GB OWC SSD
6GB DDR3
6TB Storage
Look here... I do not have the time check through...
Is it working for you guys? I am getting a lot of errors, but no actual CPU usage...
Code:[14:30:03] Verifying core Core_a1.fah... [14:30:03] Signature is VALID [14:30:03] [14:30:03] Trying to unzip core FahCore_a1.exe [14:30:03] Decompressed FahCore_a1.exe (2035712 bytes) successfully [14:30:03] + Core successfully engaged [14:30:03] Deleting current work unit & continuing... [14:30:11] - Preparing to get new work unit... [14:30:11] + Attempting to get work packet [14:30:11] - Connecting to assignment server [14:30:12] - Successful: assigned to (171.64.65.64). [14:30:12] + News From Folding@Home: Welcome to Folding@Home [14:30:12] Loaded queue successfully. [14:30:12] - Error: Attempt #1 to get work failed, and no other work to do. Waiting before retry. [14:30:26] + Attempting to get work packet [14:30:26] - Connecting to assignment server [14:30:27] - Successful: assigned to (171.64.65.64). [14:30:27] + News From Folding@Home: Welcome to Folding@Home [14:30:27] Loaded queue successfully. [14:30:35] + Closed connections [14:30:40] [14:30:40] + Processing work unit [14:30:40] Core required: FahCore_a1.exe [14:30:40] Core found. [14:30:40] Working on Unit 04 [March 19 14:30:40] [14:30:40] + Working ... [14:30:49] CoreStatus = FFFFFFFF (-1) [14:30:49] Client-core communications error: ERROR 0xffffffff [14:30:49] Deleting current work unit & continuing... [14:30:57] - Preparing to get new work unit... [14:31:05] + Attempting to get work packet [14:31:05] - Connecting to assignment server [14:31:06] - Successful: assigned to (171.64.65.64). [14:31:06] + News From Folding@Home: Welcome to Folding@Home [14:31:06] Loaded queue successfully. [14:31:15] + Closed connections [14:31:20] [14:31:20] + Processing work unit [14:31:20] Core required: FahCore_a1.exe [14:31:20] Core found. [14:31:20] Working on Unit 05 [March 19 14:31:20] [14:31:20] + Working ... [14:31:28] CoreStatus = FFFFFFFF (-1) [14:31:28] Client-core communications error: ERROR 0xffffffff [14:31:28] Deleting current work unit & continuing... [14:31:36] - Preparing to get new work unit... [14:31:36] + Attempting to get work packet [14:31:36] - Connecting to assignment server [14:31:36] - Successful: assigned to (171.64.65.64). [14:31:36] + News From Folding@Home: Welcome to Folding@Home [14:31:36] Loaded queue successfully. [14:31:45] + Closed connections [14:31:50] [14:31:50] + Processing work unit [14:31:50] Core required: FahCore_a1.exe [14:31:50] Core found. [14:31:50] Working on Unit 06 [March 19 14:31:50] [14:31:50] + Working ... [14:31:58] CoreStatus = FFFFFFFF (-1) [14:31:58] Client-core communications error: ERROR 0xffffffff [14:31:58] - Attempting to download new core... [14:31:58] + Downloading new core: FahCore_a1.exe
Mine seemed to fire up ok this morning before I left for work, and appeared to be using 100% cpu also. I'll see what state it's in when I get home, I was getting ~20mins a frame on the biggies in VMware, I'm reading that Win32 might not be as efficient as I thought - and that VMware might still be the way to go.... I'll find out later, if it made it past frame #1.
the -1 error ....
5. Troubleshooting:
If the client reports an error code -1, it is likely due to an mpi problem. Try re-registering mpiexec by running mpiexec –register or install.bat.
I had to set a password on my windows account to get it fired up & authenticated too, that & allowing the components when Windows Firewall complains during the install.
edit - are you in the UK at the moment angra? - I ask because the timestamps apear to be ~14:30 on your fah output there![]()
Do you have .Net 2.0 installed?
Mine is at about 28% on a 1,500 point work unit with no errors so far.
24/7 Gamer
Q6600 @ 3.6GHz
ASUS P5K
yeah really, I'm personally thinking that its easier to run it in a VM than it is to do natively. Too much of a pita and too many bugs so far.
40GB OWC SSD
6GB DDR3
6TB Storage
I am not in the UK, sorry!
I don't know what is making the timezones off and I am too lazy to fix it!
everything runs fine now, I just had to do the install.bat thing. far be it for me to actually read instructions.
I've been crunching using the SMP client since yesterday late afternoon and I'm at 39%, running on a borrowed X2 3800+ @ 2.6GHz. No errors yet. This sound about right? It is a project 2610, not sure on its pointage yet. Looking in that link that sc00p provided for the modded FahMon now.
*EDIT* I got it downloaded, 1523 ponts, 645 PPD. I wonder how it would go on my opty 165 @ 2.8GHz. I was getting more PPD from my X1900XT + a separate CPU client going. Guess we'll see what happens, but I'll at least keep running it until I get my parts back from warranty. Now if I pick up a dual core CPU for one of my dedicated crunchers I'll put the SMP client on there for sure.
Getting about 17 mins/frame on a p2652 here...
Project 2610: 1523 points, deadline 4 days
Project 2651: 1760 points, deadline 4 days
Project 2652: 1148 points, deadline 3 days
Doesn't look so good considering VMware kicks out a 1760-pointer at 20 mins/frame. Still not bad though...
edit> on a stock e6400 btw
woops i didn't see this thread when i started the other one... my bad, sorry for the useless thread i made :s
My current aircooled system
Rig: Antec Solo, Seasonic S12-500, Intel D975XBX, Core 2 Duo E6600, Corsair TWIN2X2048-8500C5D, XFX GeForce 7950 GT 512MB, WD Raptor 150GB & 2 * Maxtor DiamondMax 10 250GB
Cooling: Thermalright Ultra120, 2 * Nexus realsilent 120mm & 2 * Nexus realsilent 92mm, gpucooling is passive.
OC: CPU: 3.36GHz, BUS: 373MHz @ strap1066, RAM: 467MHz @ 4:5
Voltage: vCORE: 1.29, vMCH: 1.6, vFSB: default, vDIMM: 2.2
Temps: Ambient: 22C, CPU: 43C/65C, GPU: 54C/80C, MCH: 43C/50C, ICH: 41C/47C
Noise: Whisper Quiet, but not inaudible
now the big question: what if we run the GPU client? should we stick to non-SMP client + GPU or SMP + GPU? Hmm.
The Win32 SMP was using 100% CPU when I ran a unit, so there probably isnt the spare CPU time by default - if you set it to 90% or 80% utilisation, then maybe you'd have enough CPU time to run the GPU client alongside it tooMake a note of your frame times on the SMP & GPU clients running on their own, then have a play with running them together (and setting priority/utilisation in the client setup) & see how the frame times are affected.
With a dual core CPU running the SMP client I wouldn't run the GPU client with it since each core is already busy with 2 threads. Now a quad core system might be worth it - my friend (servin247365) is trying that out on his dual FX-70's and was getting 12 minutes or so per frame on the GPU client with a minimal impact on the SMP client. We'll see how that goes.
I got project 2651 now. It seams much better suited to a dual core Athlon64. Getting better frame times than 2610, despite being worth more than 200 more points.
24/7 Gamer
Q6600 @ 3.6GHz
ASUS P5K
