Just about everyone seem to have heatpipe solutions. So if I watercool the northbridge do I need to watercool the mosfet area as well or is there some nice heatsink you can buy that works as well as the heatpipe solution (or better of course...
Coolermaster Stacker
Silverstone 850 zeus
Core 2 duo E6600
Asus Commando
2x1 gb team xtreme
Leadtek 8800 GTX
X-Fi ELITE PRO
2X WD Raptors
2x WD 500 KS
Laing DDC 2 pump with petra tech top
12 mm tubing
Apogee and MCW60
Microres reservoir
MCR330 triple rad and radbox.
this is my plan for the SB http://www.newegg.com/Product/Produc...82E16835109131 when i WC the cpu and NB
ive read it works great and you can get it n with SLI installed.
http://www.rageinfected.com
EVGA 680I P25
E6600 stock 1.3v
G.SKILL 2X1GB 4-4-4-12 1.95v
9500 ZALMAN
7950GT KO OVERCLOCKER 512MB
WD RAPTOR 150 GB
THERMALTAKE 850WATT QUAD CORE/SLI CERTIFIED
X-FI EXTREMEGAMER SOUNDCARD
DVD BURNER
SCEPTRE 21' FLATPANEL WIDESCREEN 5ms 1600x1052NZXT LEXA CASE
i don't know what board you gona use, but EK made some blocks for 680i m-b
LD PC-V8 | i7 3930K |Asus Rampage IV Extreme| G.Skill Ripjaws Z | Sapphire 7970 | Acer GD245HQ |OCZ Vertex 2 E 120GB | Intel 510 120GB | Cooling XSPX RX480, XSPC RX360, Swiftech MCP35X-XSPC res top, EK Supreme HF Copper,T-balancer mCubed bigNG |
watercooling the mosfets seems like overkill on watercooling? Or do it really get that hot? I am not planning to run insane voltages itīs going to be a 24/7 platform not benching.
I am not sure weither to go 680i, 965 or 975. Since I do have an 8800 GTX it would be nice to have the option for SLI but otherwise I lean towards 965 or 975 mostly because of money...
I understand 975 and 965 runs cooler then 680i so do you really need to watercool those? I guess the one that needs it the most is the northbridge?
shouldnīt heatsinks be enough for mosfets on all mainboards and a little fan or passive heatsink on the southbridge...
Core 2 duo E6600
Asus Commando
2x1 gb team xtreme
Leadtek 8800 GTX
X-Fi ELITE PRO
2X WD Raptors
2x WD 500 KS
12 mm tubing
Apogee and MCW60
Microres reservoir
I currently use this on my NB and it works great. I have ordered a MCW30 waterblock to take its place so I can overclock further. My BadAxe2 has heatsinks on the mosfets and they seem to do fine. If you can also have a fan blowing on them it would help. I left the stock heatsink on my SB.
http://www.swiftnets.com/
"MCX159-CU series Chipset Heatsinks for AMD® & Intel® platform motherboards"
XSWCG Disclaimer:
We are not responsible for the large sums of money that you WILL want to spend to upgrade and add additional equipment. This is an addiction and the forum takes no responsibility morally or financially for the equipment and therapy cost. Thank you and have a great day.
Sigmund Freud said... "Failure to CRUNCH is a sign of Sexual Inadequacies".
Just had my Danger Den Sliver RBX modded with a 10mm thick top to fit the std Intel hock mounts!
XSWCG Disclaimer:
